pottydr Posted February 28, 2009 Report Share Posted February 28, 2009 I have not been paying attenion to my fuel pressure gauge, was down to 20lb at 3/4 throttle, changed the fuel filter and now it's about 60lbs at 3/4 throttle, so change your filter, mine was at 11,000 miles, now I will change it at every other oil change, The filter is located under the car right below the driver seat and 10 mm socket with 4 nuts, Rick BTW, that is the cover for the fuel filter, watch out for the fuel, there will be pressure and the gas will come out quick and spray, you have to pinch the little green tabs to get the filter off Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted February 28, 2009 Report Share Posted February 28, 2009 Good catch! I think I'll go change mine right now! Sam AKA: Link to comment Share on other sites More sharing options...
Dig-It Posted February 28, 2009 Report Share Posted February 28, 2009 Thanks Rick! Link to comment Share on other sites More sharing options...
rnoggle Posted February 28, 2009 Report Share Posted February 28, 2009 Hmmm, I've got 13000 miles now. Guess I'll get it changed with the next oil change. Did you notice any drop in WOT performance before you changed it? Thanks for the heads up!! Link to comment Share on other sites More sharing options...
Michael Morris Posted February 28, 2009 Report Share Posted February 28, 2009 I have not been paying attenion to my fuel pressure gauge, was down to 20lb at 3/4 throttle, changed the fuel filter and now it's about 60lbs at 3/4 throttle, so change your filter, mine was at 11,000 miles, now I will change it at every other oil change, The filter is located under the car right below the driver seat and 10 mm socket with 4 nuts, Rick BTW, that is the cover for the fuel filter, watch out for the fuel, there will be pressure and the gas will come out quick and spray, you have to pinch the little green tabs to get the filter off Hey Rick, When did you change the wheels? This is the first time I have noticed them. They look great!! MM Link to comment Share on other sites More sharing options...
07SGT4578 Posted February 28, 2009 Report Share Posted February 28, 2009 I'll have mine changed at the next oil change, too. By that time I will be at 10000 mi. Chris Link to comment Share on other sites More sharing options...
clark17357 Posted March 1, 2009 Report Share Posted March 1, 2009 Hi Rick Did you use a stock replacement part for the fuel filter itself? If we released pressure by taking off the fuel cap, do you think that would help? Jim Link to comment Share on other sites More sharing options...
rnoggle Posted March 1, 2009 Report Share Posted March 1, 2009 If we released pressure by taking off the fuel cap, do you think that would help? While I haven't done this yet, I don't believe you can release fuel line pressure via the fuel cap. The pressure would be in the line itself, between the fuel pump and the engine. The tank may have a little pressure in it, but not like the fuel line. Link to comment Share on other sites More sharing options...
BAD SNAKE Posted March 1, 2009 Report Share Posted March 1, 2009 Great advise, thanks! Link to comment Share on other sites More sharing options...
pottydr Posted March 1, 2009 Author Report Share Posted March 1, 2009 Hi Rick Did you use a stock replacement part for the fuel filter itself? If we released pressure by taking off the fuel cap, do you think that would help? Jim I used the Steeda high flow filter, if there is really such a thing, Its probley just a stock ford filter and there was no way to release the pressure as it was from pump to motor, Rick Link to comment Share on other sites More sharing options...
torquewrench1807 Posted March 6, 2009 Report Share Posted March 6, 2009 I have not been paying attenion to my fuel pressure gauge, was down to 20lb at 3/4 throttle, changed the fuel filter and now it's about 60lbs at 3/4 throttle, so change your filter, mine was at 11,000 miles, now I will change it at every other oil change, The filter is located under the car right below the driver seat and 10 mm socket with 4 nuts, Rick BTW, that is the cover for the fuel filter, watch out for the fuel, there will be pressure and the gas will come out quick and spray, you have to pinch the little green tabs to get the filter off Thanks for suggesting a fuel filter replacement. Today I paid $45 to have the filter replaced after 27,944 miles on the original filter. The mechanic showed me the gunk as it flowed out of the filter and into the drain pan, it was between the color of tea and coffee. The SGT had been less than smooth when accelerating, and on start up when I left the parking garage at the end of the day. Now accel is smooth as butter. Link to comment Share on other sites More sharing options...
kahmann Posted July 6, 2009 Report Share Posted July 6, 2009 Good call on the filter for sure. Just a note for anyone doing this themselves. It's wise to cycle your fuel pump a couple of times, after you've opened up the fuel lines for any reason. Once your filter is replaced, I'd suggest turning the key on (not the engine), till you hear the fuel pump cycle on for a few seconds. Key off and back on and you're good to go. This just ensures that you're not sending a pocket of air to your injectors (but is probably more important when you break the line at the rails, I would assume, but this certainly can't hurt). Ken Link to comment Share on other sites More sharing options...
CudaFly Posted July 7, 2009 Report Share Posted July 7, 2009 BTW, that is the cover for the fuel filter, watch out for the fuel, there will be pressure and the gas will come out quick and spray, you have to pinch the little green tabs to get the filter off Here are the instructions for releasing the fuel system pressure before you change your fuel filter (or do any other fuel line work). NO SMOKING!!! Fuel_System_Pressure_Release.pdf Link to comment Share on other sites More sharing options...
yellow pony Posted July 7, 2009 Report Share Posted July 7, 2009 Here are the instructions for releasing the fuel system pressure before you change your fuel filter (or do any other fuel line work). Thanks for posting the instructions for releasing the pressure. A lot better than taking a high pressure gasoline shower! -yellow pony Link to comment Share on other sites More sharing options...
WildAzCat Posted July 7, 2009 Report Share Posted July 7, 2009 Thanks for posting the instructions for releasing the pressure. A lot better than taking a high pressure gasoline shower! -yellow pony Thanks +1 Link to comment Share on other sites More sharing options...
kahmann Posted July 7, 2009 Report Share Posted July 7, 2009 Not much gas poured out and what little did I caught with a rag. I used a $25 Motorcraft filter tonight and noticed a pressure increase of around 10-15 at 1/2-3/4 throttle. The first pump cycle sounded terrible, lots of cavitation. By the 3rd cycle, it sounded normal and I had 50 psi of head pressure. Anyway, thanks again for the reminder. I have 27,661 miles and obviously needed it done. Ken Link to comment Share on other sites More sharing options...
