08SGT/SC Posted September 17, 2010 Report Share Posted September 17, 2010 I have been trying to install my brake duct bezels, but cannot get them to go in. The brake duct will fit in, but I can't manage to maneuver it in to get the fog light tube through. I cut them out just the way the template shows, and measured to confirm that it was to scale. Is there trick to get it in, or has everyone just been cutting the tabs that crucible mentioned? 08sgt1289 Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted September 18, 2010 Report Share Posted September 18, 2010 I have been trying to install my brake duct bezels, but cannot get them to go in. The brake duct will fit in, but I can't manage to maneuver it in to get the fog light tube through. I cut them out just the way the template shows, and measured to confirm that it was to scale. Is there trick to get it in, or has everyone just been cutting the tabs that crucible mentioned? 08sgt1289 If they are the OLD STYLE, (not the new style with the pressed in honeycomb grill), they are a tight fit! I found you need to cut the holes slightly larger than the template shows, then tilt the bezel slightly, (top towards you), and push gently into place, seating the bottom of the bezel first, then the top. You can overdo the cutting! Just make sure you leave enough material for the rivets/bolt holes! Sam Link to comment Share on other sites More sharing options...
