dmctag Posted October 27, 2006 Report Share Posted October 27, 2006 Hi Guys, Have any of you experienced brake squeal noise and slow creap to a stop? Is due to lining material. I am at 1967 km's on the car. Awesome car other than the brake squeal. Link to comment Share on other sites More sharing options...
Jolly Roger Posted October 27, 2006 Report Share Posted October 27, 2006 Nope Link to comment Share on other sites More sharing options...
mastersmech1 Posted October 27, 2006 Report Share Posted October 27, 2006 Not here Link to comment Share on other sites More sharing options...
Orf Posted October 27, 2006 Report Share Posted October 27, 2006 I hear the squeal every once in a while. I'm thinking dirt on the pads. Very infrequent. Link to comment Share on other sites More sharing options...
rpretzel Posted October 27, 2006 Report Share Posted October 27, 2006 From what I've read from others around here, the pads generate a ton of brake dust. That's probably what's making your brakes squeek. Shoot some air in there with a compressor...that should help. Link to comment Share on other sites More sharing options...
Orf Posted October 27, 2006 Report Share Posted October 27, 2006 The dust is almost as bad as the 03 Expedition I had. I plan to order the R4-S pads from Porterfield, probably before the stock pads are gone. I hate that dust. Link to comment Share on other sites More sharing options...
shel-b001 Posted October 27, 2006 Report Share Posted October 27, 2006 A good high pressure washing or air pressure should take care of the squeal. I suggest high pressurewater spray then your not breathing the dust particles. Link to comment Share on other sites More sharing options...
gt50035 Posted October 29, 2006 Report Share Posted October 29, 2006 A good high pressure washing or air pressure should take care of the squeal. I suggest high pressurewater spray then your not breathing the dust particles. I had the same thing and used a high pressure spray. It worked. Link to comment Share on other sites More sharing options...
TAHOE GT Posted October 29, 2006 Report Share Posted October 29, 2006 NONONONONONONONONONO!!!!!!!!!!! NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!!NO AIR!!!! Just drive the car harder. Usually, some good hard stops will make any squeal go away. If it does, then you just arn't using the brakes hard enough. Link to comment Share on other sites More sharing options...
1BADGT500 Posted October 29, 2006 Report Share Posted October 29, 2006 Not here None here! Link to comment Share on other sites More sharing options...
Jolly Roger Posted October 29, 2006 Report Share Posted October 29, 2006 You could spray some Teflon containing oil right on the rotors. That might help. Link to comment Share on other sites More sharing options...
