angrrmgt Posted October 6, 2008 Report Share Posted October 6, 2008 hi to all, i am getting a set of CS'69's 20 inch in chrome and i want to swap the tire pressure sensors to the new rims. i"ve read that they have to be reprogrammed? or will the sensors from my stock wheels just swap to the new rims. if there is a reprogramming protocol, can someone provide me with that. thanks to all. Link to comment Share on other sites More sharing options...
twobjshelbys Posted October 6, 2008 Report Share Posted October 6, 2008 hi to all, i am getting a set of CS'69's 20 inch in chrome and i want to swap the tire pressure sensors to the new rims. i"ve read that they have to be reprogrammed? or will the sensors from my stock wheels just swap to the new rims. if there is a reprogramming protocol, can someone provide me with that. thanks to all. You will need the reprogramming tool you can buy from Ford. The people mounting your tires should be able to do it for you. Link to comment Share on other sites More sharing options...
RmGardner Posted October 6, 2008 Report Share Posted October 6, 2008 Speaking of tire pressures I have to add to mine about once a month. Anyone else having problems with slow leaks? Link to comment Share on other sites More sharing options...
SLB8SNK Posted October 6, 2008 Report Share Posted October 6, 2008 It is basically a magnet donut that goes around the value, and works with reprogramming in the car. Best have the tire place do it save yourself the cost of buying it, it is free for them to do! Link to comment Share on other sites More sharing options...
Kelsey Posted October 7, 2008 Report Share Posted October 7, 2008 Speaking of tire pressures I have to add to mine about once a month. Anyone else having problems with slow leaks? Are they nitrogen filled? That should help if they're not. Link to comment Share on other sites More sharing options...
sleepless Posted October 7, 2008 Report Share Posted October 7, 2008 I just went to the dealer and let them reprogram the system; took about 3 minutes. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted October 7, 2008 Report Share Posted October 7, 2008 I thought you needed new sensors for 20" rims? Link to comment Share on other sites More sharing options...
mywickedshelby Posted October 7, 2008 Report Share Posted October 7, 2008 not if you get the new adjustable bands (they are good to 22 I believe!) Link to comment Share on other sites More sharing options...
mciarochi Posted October 7, 2008 Report Share Posted October 7, 2008 Speaking of tire pressures I have to add to mine about once a month. Anyone else having problems with slow leaks? Air will leak, but not a lot. You might lose a couple of pounds in a month due to normal loss, and also due to temperature fluctuations as we move into the cold season. Are you just losing pressure as the temperature drops, or losing air out of one of the tires? If it is a small amount all around, that's normal. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted October 7, 2008 Report Share Posted October 7, 2008 not if you get the new adjustable bands (they are good to 22 I believe!) Gotcha! Thanks! Link to comment Share on other sites More sharing options...
RmGardner Posted October 9, 2008 Report Share Posted October 9, 2008 Air will leak, but not a lot. You might lose a couple of pounds in a month due to normal loss, and also due to temperature fluctuations as we move into the cold season. Are you just losing pressure as the temperature drops, or losing air out of one of the tires? If it is a small amount all around, that's normal Losing just enough to set of sensorabout once a month. Was told it is only about 3 or 4 lbs to set iti off. Link to comment Share on other sites More sharing options...
LuLu Posted October 9, 2008 Report Share Posted October 9, 2008 Well, I'm not going to be much help here because my experience has been different. I swapped the stock SGT 18" "Bullet" wheels for the FRP 18" "Marauder" wheels almost a year ago. They appear to be the same wheel, and no one has every commented on the difference. However, the "Marauder" wheel (FRP #M-1007-M188P, also listed as an option in the 2007 Mustang accessory catalogue)) has some features to it. A 50mm offset, rather than the 45mm offset of the stock wheel. This difference allowed me to explore the aftermarket brake options without buying new 20" wheels and tires. The sensors were never more than 10 feet from LuLu during the upgrade at Discount Tire. Take off the old, band to the new (with adjustable bands) and re-tire with the stock BFG 235/50-18 tires,then drive away. I'm planning on new tires soon, Pirelli 255/45-18 Assymetricos, and I don't expect my changeover to be any different. As long as the wheel sensors do not lose contact with the message center, you should be fine. However, this is just my guess. Keep us posted? Link to comment Share on other sites More sharing options...
