dragpack70 Posted September 18, 2008 Report Share Posted September 18, 2008 Where can I find an OEM-style (3-finger Long-style) pressure plate, clutch disk and throw-out bearing for my 1970 Mach I 428 SCJ? My searches over the years have not turned up anything other than kits for the smaller V8's, or more modern pressure plate configurations that require machining the flywheel in some fashion. I know the original clutches were very durable, but surely somebody makes a replacement, as they can't all have lasted 38 years. Link to comment Share on other sites More sharing options...
robertlane Posted September 19, 2008 Report Share Posted September 19, 2008 I purchased a center force for my SCJ. That was back in 1998. Link to comment Share on other sites More sharing options...
dragpack70 Posted September 19, 2008 Author Report Share Posted September 19, 2008 The Centerforce kits talk about having to machine the flywheel and change the clutch linkage return spring arrangements. Did you have to do either or both? My SCJ is externally balanced using the flywheel (11 1/2" clutch), and I would really prefer an OEM-style replacement if I can find one. Link to comment Share on other sites More sharing options...
