Jimmy Sugan Posted September 3, 2008 Report Share Posted September 3, 2008 Before I go to the track, what is the shift point on the Shelby GT? Is there a RPM/ Rev control on this car, or is that only on when the traction control is on? Thanks, new to this fuel injection/computer stuff. Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted September 3, 2008 Report Share Posted September 3, 2008 If you're talking about a rev limiter yes there is one. Tasca installed a race light for me and it works awesome. Link to comment Share on other sites More sharing options...
clark17357 Posted September 3, 2008 Report Share Posted September 3, 2008 If you're talking about a rev limiter yes there is one. Tasca installed a race light for me and it works awesome. Hi Adam, I thought I had looked at every part of your car but I guess not. Can you post a photo of the race light? Thanks. Jim Link to comment Share on other sites More sharing options...
Jimmy Sugan Posted September 3, 2008 Author Report Share Posted September 3, 2008 (rev limiter) Thats the word I was looking for. When RPM does this come on? Link to comment Share on other sites More sharing options...
TClark1976 Posted September 3, 2008 Report Share Posted September 3, 2008 I've hit this rev limiter in 2nd a couple times already - stock HP begins to fall off right at about 6000 RPM I believe the rev limiter kicks on at about 6200 RPM or something like that. . . . . with or without the Traction Control turned on. Don't quote me on that . . . . but that's what I'm seeing with my SGT. Trevor Link to comment Share on other sites More sharing options...
ilmor Posted September 3, 2008 Report Share Posted September 3, 2008 I have heard that the limiter kicks in at 6200. Some say that she's still pulling at that point. I know I've been close to it, but either I haven't hit it or it doesn't work (I hope the former)! Link to comment Share on other sites More sharing options...
LuLu Posted September 3, 2008 Report Share Posted September 3, 2008 I've hit this rev limiter in 2nd a couple times already - stock HP begins to fall off right at about 6000 RPM I believe the rev limiter kicks on at about 6200 RPM or something like that. . . . . with or without the Traction Control turned on. Don't quote me on that . . . . but that's what I'm seeing with my SGT. Trevor Sorry...You're quoted! Hehehe, just kidding, but you are correct. I have heard that the limiter kicks in at 6200. Some say that she's still pulling at that point. I know I've been close to it, but either I haven't hit it or it doesn't work (I hope the former)! Just last week, I ventured into this territory with a custom tune for LuLu. The factory/OEM speed limiter (aka "rev limiter") is set to 6200 RPM. Hit this wall with a stock SGT/SAI/FRP tune, and the EEC will shut things down until RPMs are reduced to 5800. No damage will occur, or result, it's a safety barrier. You will hear some "popping" from the engine bay, because the EEC is pulling spark, timing and fuel allocations to the injectors, but only to reduce engine RPM. No damage to the engine will result. In addition, turn off your Traction Control! if you're planning any highway adventures. My tuner (Corey Simpson/Simpson Performance) bumped LuLu's speed limiter to 7000 RPM, and we found (thanks to accurate dyno reports) that there is no power available beyond 6200 RPM. The shortcoming of a "square" engine design? But, there is power up to and at 6200 RPM. Corey told me "that's you new shift point, Mac, 6200 RPM". Guess I need a shift light now. After 6200 RPM, the 4.6L-3V engine will "roll over" and cause/suffer a loss of power. You will (should) know you have exhausted any power on tap, and either get up off the throttle, or, change gears. IMHO...There is power up to 6200 RPM, but nothing to reach for after that. If you do reach, you are risking a blown engine, and I don't mean by Paxton/Whipple/KB... Link to comment Share on other sites More sharing options...
FordRocks1 Posted September 3, 2008 Report Share Posted September 3, 2008 IMHO...There is power up to 6200 RPM, but nothing to reach for after that. If you do reach, you are risking a blown engine, and I don't mean by Paxton/Whipple/KB... Link to comment Share on other sites More sharing options...
CudaFly Posted September 4, 2008 Report Share Posted September 4, 2008 For anyone looking for a shift light I installed a Raptor shift light about a year ago and it's a great product. It has three wires: ground, power, and any coil-on-plug connection. Very easy install and you can change the shift point setting anytime with a small screwdriver. Here's the link: http://www.raptorperformance.com/products/Shift_light.htm Link to comment Share on other sites More sharing options...
Jimmy Sugan Posted September 4, 2008 Author Report Share Posted September 4, 2008 Sorry...You're quoted! Hehehe, just kidding, but you are correct. Just last week, I ventured into this territory with a custom tune for LuLu. The factory/OEM speed limiter (aka "rev limiter") is set to 6200 RPM. Hit this wall with a stock SGT/SAI/FRP tune, and the EEC will shut things down until RPMs are reduced to 5800. No damage will occur, or result, it's a safety barrier. You will hear some "popping" from the engine bay, because the EEC is pulling spark, timing and fuel allocations to the injectors, but only to reduce engine RPM. No damage to the engine will result. In addition, turn off your Traction Control! if you're planning any highway adventures. My tuner (Corey Simpson/Simpson Performance) bumped LuLu's speed limiter to 7000 RPM, and we found (thanks to accurate dyno reports) that there is no power available beyond 6200 RPM. The shortcoming of a "square" engine design? But, there is power up to and at 6200 RPM. Corey told me "that's you new shift point, Mac, 6200 RPM". Guess I need a shift light now. After 6200 RPM, the 4.6L-3V engine will "roll over" and cause/suffer a loss of power. You will (should) know you have exhausted any power on tap, and either get up off the throttle, or, change gears. IMHO...There is power up to 6200 RPM, but nothing to reach for after that. If you do reach, you are risking a blown engine, and I don't mean by Paxton/Whipple/KB... THANK YOU FOR THE INFO!!!!! Link to comment Share on other sites More sharing options...
SWEDEMAN Posted September 6, 2008 Report Share Posted September 6, 2008 Sorry...You're quoted! Hehehe, just kidding, but you are correct. Just last week, I ventured into this territory with a custom tune for LuLu. The factory/OEM speed limiter (aka "rev limiter") is set to 6200 RPM. Hit this wall with a stock SGT/SAI/FRP tune, and the EEC will shut things down until RPMs are reduced to 5800. No damage will occur, or result, it's a safety barrier. You will hear some "popping" from the engine bay, because the EEC is pulling spark, timing and fuel allocations to the injectors, but only to reduce engine RPM. No damage to the engine will result. In addition, turn off your Traction Control! if you're planning any highway adventures. My tuner (Corey Simpson/Simpson Performance) bumped LuLu's speed limiter to 7000 RPM, and we found (thanks to accurate dyno reports) that there is no power available beyond 6200 RPM. The shortcoming of a "square" engine design? But, there is power up to and at 6200 RPM. Corey told me "that's you new shift point, Mac, 6200 RPM". Guess I need a shift light now. After 6200 RPM, the 4.6L-3V engine will "roll over" and cause/suffer a loss of power. You will (should) know you have exhausted any power on tap, and either get up off the throttle, or, change gears. IMHO...There is power up to 6200 RPM, but nothing to reach for after that. If you do reach, you are risking a blown engine, and I don't mean by Paxton/Whipple/KB... Mac - Thanks for the reply, uhmmmm, on another post though! That is why I feel my car pulling strongly when it craps at 6200 RPMS, because it still has power at 6200, but no power @ 6300. Even though I find that interesting there is one thing numbers don't do, they don't lie. So thank you for the reply once again. Swede Link to comment Share on other sites More sharing options...
ingram4868 Posted September 6, 2008 Report Share Posted September 6, 2008 For what it's worth, RPM limiter is set at 6250 but by the time your tach displays that it is too late. Many tuners will up it to 6500 but with the right gearing the real sweet spot is right around 6000. It does vary with each car. Link to comment Share on other sites More sharing options...
