SWEDEMAN Posted August 17, 2008 Report Share Posted August 17, 2008 My steering wheel has a small blemish on the lower spoke and I want to replace the spoke only. Has anyone ever done this? If so can you explain where to buy it and how to do it? Thanks- Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted August 17, 2008 Report Share Posted August 17, 2008 Never seen just aspoke, my guess would be a salvage part. I've seen the entire wheel on ebay many times. Link to comment Share on other sites More sharing options...
SWEDEMAN Posted August 18, 2008 Author Report Share Posted August 18, 2008 I too saw the wheel on ebay. But I'd like to swear that you could just replace one spoke, I could be wrong, but it would make it alot easier. Thansk Jeff. Link to comment Share on other sites More sharing options...
RogerS Posted August 18, 2008 Report Share Posted August 18, 2008 Swede, the steering wheel "aluminum trim" pieces are avalible as individual pieces. Call your dealer. He should have the part number. Roger Link to comment Share on other sites More sharing options...
shelbydream1 Posted August 18, 2008 Report Share Posted August 18, 2008 My steering wheel has a small blemish on the lower spoke and I want to replace the spoke only. Has anyone ever done this? If so can you explain where to buy it and how to do it?Thanks- I have the same "blemish" Swede-must have been a bad batch. Link to comment Share on other sites More sharing options...
07SGT-C Posted August 18, 2008 Report Share Posted August 18, 2008 I have the same "blemish" Swede-must have been a bad batch. Mine have a couple dings...they must be pretty fragile Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted August 18, 2008 Report Share Posted August 18, 2008 Mine have a couple dings...they must be pretty fragile Yes. I have scratched mine, too. Ahh. The hard life of a DD. Link to comment Share on other sites More sharing options...
ilmor Posted August 18, 2008 Report Share Posted August 18, 2008 Mine looks fine at the moment, but if it got too messed up I might consider switching to the GT500 / Bullitt wheel and avoid that issue in the future. Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted August 18, 2008 Report Share Posted August 18, 2008 Swede, the steering wheel "aluminum trim" pieces are avalible as individual pieces. Call your dealer. He should have the part number. Roger Once ordered, does anyone know how to install them? Are they bonded on? Thanks, Link to comment Share on other sites More sharing options...
motorjock205 Posted August 19, 2008 Report Share Posted August 19, 2008 Once ordered, does anyone know how to install them? Are they bonded on? Thanks, I saw where a young man had replaced all of the lights in his steering wheel to match his chosen color, and if I remember correctly, they just pop off and on...they have some small clips that hold them on... Link to comment Share on other sites More sharing options...
shelbydream1 Posted August 19, 2008 Report Share Posted August 19, 2008 Mine have a couple dings...they must be pretty fragile Mine came that way when I got it, but I didn't notice it until the next day-if I were going to try to describe it, I would say it looks like file marks. Link to comment Share on other sites More sharing options...
RogerS Posted August 19, 2008 Report Share Posted August 19, 2008 Here is the pdf on the steering wheel. You will see the spoke cover and the part number listed. Hope this helps. Roger steeringwheel.pdf steeringwheel.pdf Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted August 19, 2008 Report Share Posted August 19, 2008 Here is the pdf on the steering wheel. You will see the spoke cover and the part number listed. Hope this helps. Roger Thanks, Rgoer Link to comment Share on other sites More sharing options...
SWEDEMAN Posted August 19, 2008 Author Report Share Posted August 19, 2008 Here is the pdf on the steering wheel. You will see the spoke cover and the part number listed. Hope this helps. Roger Roger you know your stuff, thanks again. Link to comment Share on other sites More sharing options...
