DocBlack Posted August 9, 2008 Report Share Posted August 9, 2008 After a recent wreck, I need to reset the fuel pump. It's not behind the passenger side kick panel. Any other suggestions? Thanks, Doc Link to comment Share on other sites More sharing options...
kaylan1521 Posted August 9, 2008 Report Share Posted August 9, 2008 After a recent wreck, I need to reset the fuel pump. It's not behind the passenger side kick panel. Any other suggestions?Thanks, Doc I'm not 100% certain but I believe it's in the trunk behind the plastic panel Link to comment Share on other sites More sharing options...
gradona Posted August 9, 2008 Report Share Posted August 9, 2008 Should be behind the drivers side kick panel. Link to comment Share on other sites More sharing options...
RogerS Posted August 9, 2008 Report Share Posted August 9, 2008 Should be behind the drivers side kick panel. Link to comment Share on other sites More sharing options...
DocBlack Posted August 9, 2008 Author Report Share Posted August 9, 2008 Many Thanks! Link to comment Share on other sites More sharing options...
RogerS Posted August 9, 2008 Report Share Posted August 9, 2008 Many Thanks! Doc, You do not need to remove the panel. Here is pic with the panel installed. You can clearly see the top of the red reset button. Link to comment Share on other sites More sharing options...
gradona Posted August 9, 2008 Report Share Posted August 9, 2008 Many Thanks! As they say in Germany, You're Velcome Link to comment Share on other sites More sharing options...
kaylan1521 Posted August 9, 2008 Report Share Posted August 9, 2008 Right! It's the the older bodystyle that is in the trunk. Link to comment Share on other sites More sharing options...
gradona Posted August 9, 2008 Report Share Posted August 9, 2008 Right! It's the the older bodystyle that is in the trunk. Right Link to comment Share on other sites More sharing options...
NCStangFanatic Posted August 9, 2008 Report Share Posted August 9, 2008 Good information. I hope I never have to use it. Link to comment Share on other sites More sharing options...
DubbsFaris Posted August 9, 2008 Report Share Posted August 9, 2008 Yeah, I slammed my trunk closed on my '93, and it triggered the cutoff switch. Luckily, my brother new exactly what had happened. Its too bad we cant put a double switch in the current spot, would be a good mod to cut the fuel supply to prevent theft or 'unauthorized' use... Link to comment Share on other sites More sharing options...
DocBlack Posted August 10, 2008 Author Report Share Posted August 10, 2008 Great! She fired right up. Car is totalled but I bought the salvaged vehicle largely for the purpose of selling the motor and tranny. I already knew it would turn over smoothly at the wrecking yard, but nice to hear it still purs like a kitten. Link to comment Share on other sites More sharing options...
