Greg Abarr Posted August 7, 2008 Report Share Posted August 7, 2008 Have a friend with a 08 Cobra that sent it to Las Vegas for the 700 HP upgrade. I have an 08 Mustang GT with the 4.6 in it. He said he will sell me all the take off stuff from his Cobra for $3000 and I will buy it if the 5.4 blower part's will fit my car of if I can buy a conversion to make the blower work on my car. Anybody know if this will work. Thank's Greg Link to comment Share on other sites More sharing options...
RUFDRAFT Posted August 7, 2008 Report Share Posted August 7, 2008 Hi Greg - you might get more responses if you put this in the Shelby 500 Mod-Tech forum? Link to comment Share on other sites More sharing options...
Greg Abarr Posted August 7, 2008 Author Report Share Posted August 7, 2008 Hi Greg - you might get more responses if you put this in the Shelby 500 Mod-Tech forum? Link to comment Share on other sites More sharing options...
Greg Abarr Posted August 7, 2008 Author Report Share Posted August 7, 2008 Thank's I will try it over there Greg Link to comment Share on other sites More sharing options...
RUFDRAFT Posted August 7, 2008 Report Share Posted August 7, 2008 Only because there are a lot more members on the Shelby forums than here! And - I hope it works for you! :happy feet: Link to comment Share on other sites More sharing options...
RUFDRAFT Posted August 8, 2008 Report Share Posted August 8, 2008 I talked to my Ford tech today. He says it won't work. We have the same block (just different material) but the heads on the 5.4 are 4v - which translates into a different V-spread. Sorry. Link to comment Share on other sites More sharing options...
Greg Abarr Posted August 9, 2008 Author Report Share Posted August 9, 2008 Thank's for the info. I kind of thought there must be a reason I hadn't heard of anyone trying it out before Greg Link to comment Share on other sites More sharing options...
Willie Posted September 7, 2008 Report Share Posted September 7, 2008 I talked to my Ford tech today. He says it won't work. We have the same block (just different material) but the heads on the 5.4 are 4v - which translates into a different V-spread. Sorry. Wait a minute. This is not what I've been told. Both the 4.6 and the 5.4 have the same bore dimensions. The 5.4 has a longer stroke which means the deck height is raised. This causes the intake valley to be wider on the 5.4, not a difference in the heads. These modular motors have many interchangeable parts, including the heads. You can bolt the 3-valve heads onto a 5.4, four valve heads onto a 4.6, etc.. The bottom line is the 5.4 has a wider intake valley than the 4.6, making intake manifolds (or superchargers) not interchangeable. This is similar to the Mopar 383 & 440. The 383 is called the "B" block and the 440 is the "RB" (for raised block). Intakes are not interchangeable because the 440 variant is wider. Now, please correct me if I've been mislead. Link to comment Share on other sites More sharing options...
Greg Abarr Posted September 7, 2008 Author Report Share Posted September 7, 2008 I talked to my Ford tech today. He says it won't work. We have the same block (just different material) but the heads on the 5.4 are 4v - which translates into a different V-spread. Sorry. Wait a minute. This is not what I've been told. Both the 4.6 and the 5.4 have the same bore dimensions. The 5.4 has a longer stroke which means the deck height is raised. This causes the intake valley to be wider on the 5.4, not a difference in the heads. These modular motors have many interchangeable parts, including the heads. You can bolt the 3-valve heads onto a 5.4, four valve heads onto a 4.6, etc.. The bottom line is the 5.4 has a wider intake valley than the 4.6, making intake manifolds (or superchargers) not interchangeable. This is similar to the Mopar 383 & 440. The 383 is called the "B" block and the 440 is the "RB" (for raised block). Intakes are not interchangeable because the 440 variant is wider. Now, please correct me if I've been mislead. Hi Willie You are right on the deck height. That was one of my concern's and why I posted the question. I might still buy a used serup and see if i can do some sugury in the shop and make it work. Shouldn't be to hard if the intake can be modified with shop tool's. Greg Link to comment Share on other sites More sharing options...
