08BlueCoupe Posted August 6, 2008 Report Share Posted August 6, 2008 Will Corsa Axle Back Exhaust, JLT CAI, and a tune void my warranty? If so, which one(s) will and if possible which one(s) won't? Link to comment Share on other sites More sharing options...
FiaCobra Posted August 6, 2008 Report Share Posted August 6, 2008 As far as i know, you can go with any axle back exhaust. As for the CAI and tune, you'll be safe if you stick with the FRPP CAI/tune. Link to comment Share on other sites More sharing options...
Grabber Posted August 6, 2008 Report Share Posted August 6, 2008 Will Corsa Axle Back Exhaust, JLT CAI, and a tune void my warranty?If so, which one(s) will and if possible which one(s) won't? I have both and my warranty is intact. If the mod causes a failure....then that could be a different story. Example: Tranny and clutch problems are not caused by these 2 mods....thus the warranty is being honored. You need to get a relationship with your dealer too. Link to comment Share on other sites More sharing options...
08BlueCoupe Posted August 6, 2008 Author Report Share Posted August 6, 2008 I have both and my warranty is intact. If the mod causes a failure....then that could be a different story. Example: Tranny and clutch problems are not caused by these 2 mods....thus the warranty is being honored. You need to get a relationship with your dealer too. What can be considered a failure by the mod? Like with CAI is it anything wrong with the motor? Link to comment Share on other sites More sharing options...
ingram4868 Posted August 6, 2008 Report Share Posted August 6, 2008 The only component that you listed that will not void the warranty is the axle back exhaust. While the FRPP CAI and tune is the only kit that is 50 state smog legal the dealer COULD still refuse to do warranty repairs to the drivetrain. If your dealer wants to take the position not to honor warranty work because of your mods then the burden shifts to you to prove the mods did not cause the problem. There are Ford field reps, regional reps and then the corporate offices for you to appeal to. Having said all that if you stick to only a CAI and tune and something does go wrong then you might want to remove the CAI and flash the factory tune back into the car before you take it to the dealer for repairs. Link to comment Share on other sites More sharing options...
RStangsOC Posted August 6, 2008 Report Share Posted August 6, 2008 Will Corsa Axle Back Exhaust, JLT CAI, and a tune void my warranty?If so, which one(s) will and if possible which one(s) won't? They cant just void your warranty - they have to be able to show that the item is question was the cause for a failure. Here is some light reading you may want to take a look at. http://www.magnusonproducts.com/magnusonmoss.htm http://www.semasan.com/main/main.aspx?id=60128 http://www.semasan.com/main/main.aspx?id=60127 Link to comment Share on other sites More sharing options...
chuckstang Posted August 6, 2008 Report Share Posted August 6, 2008 FRPP CAI and Ford Tune will not void your warranty, it just reduces the warranty on the CAI itself to one year Link to comment Share on other sites More sharing options...
tglockner Posted August 6, 2008 Report Share Posted August 6, 2008 Ford Motor Company January 2008 3-131 Other Cancellation Categories In some instances Ford may cancel all or part of a vehicle’s warranty due to customer abuse, racing, damage caused by modifications or weather, improper conversion to a limousine, etc. In these instances a specific message will appear in OASIS such as: Engine warranty coverage cancelled; Powertrain warranty coverage cancelled; Total Cancellation; Rear Axle Cancelled; – Regional request, etc. Below are common types of vehicle damage that require warranty cancellation; Infrequent or No Vehicle Maintenance • Cancellation Criteria: Infrequent or no vehicle maintenance has caused engine or transmission damage or failure * Cancellation Types: Engine, Transmission, Powertrain. Modification or Alteration • Cancellation Criteria: Vehicle has been modified or altered for performance enhancement (for example chips, etc.), resulting in damage to the engine, transmission, or other vehicle components. • Cancellation Types: Engine, Transmission, Powertrain, Rear Axle or, in extreme cases, entire vehicle coverage. Water Ingestion / Damage • Cancellation Criteria: Water has been ingested into the vehicle’s powertrain compartment or elsewhere in the vehicle causing damage to one or more components. • Cancellation Types: Engine, Transmission, Powertrain or, in extreme cases, entire vehicle coverage. Abuse • Cancellation Criteria: Vehicle abuse whether intentional or inadvertent, resulting in damage to the engine, transmission or other vehicle components. Types of abuse may included fuel contamination, aggressive driving behavior, racing, aftermarket fluid additives, etc. • Cancellation Types: Engine, Transmission, Powertrain, Rear Axle, Body/Paint or, in extreme cases, Entire Vehicle Coverage. Odometer Tampering • Cancellation Criteria: The odometer shows signs of tampering. • Cancellation Types: Entire Vehicle Coverage. Unauthorized Repair or Parts • Cancellation Criteria: Vehicle repair or service has been performed by an unqualified repair facility or a non-Ford part has been installed, resulting in damage to the engine, transmission, or other vehicle components. • Cancellation Types: Engine, Transmission, Powertrain, Rear Axle or, in extreme Link to comment Share on other sites More sharing options...
ingram4868 Posted August 6, 2008 Report Share Posted August 6, 2008 It makes your head spin after awhile Link to comment Share on other sites More sharing options...
tglockner Posted August 6, 2008 Report Share Posted August 6, 2008 It makes your head spin after awhile Always go to the same Ford dealer and stay with one service adviser! If you become loyal to the dealer and staff they will go to bat for you with Ford. I have been in the car business a long time and this is the best way to get great service from you local Ford Dealer. Thanks, Tom Link to comment Share on other sites More sharing options...
mciarochi Posted August 6, 2008 Report Share Posted August 6, 2008 Ford Motor CompanyJanuary 2008 3-131 • Cancellation Criteria: Vehicle has been modified or altered for performance enhancement (for example chips, etc.), resulting in damage to the engine, transmission, or other vehicle components. The mod itself does not cancel the warranty. The mod must result in damage before they can cancel the warranty. Certainly a Corsa axleback won't cause damage. Neither will the CAI. The CAI without a tune may cause damage, but if you apply a tune that prevents a lean operating condition, that will prevent damage, not cause it. I suggest that if you ever bring your car in for warranty work, just put the old air cleaner and tune back in. [editted out a word...] Link to comment Share on other sites More sharing options...
rsfdiver Posted August 6, 2008 Report Share Posted August 6, 2008 Keep all your old parts Link to comment Share on other sites More sharing options...
Justin00Stang Posted August 7, 2008 Report Share Posted August 7, 2008 Will Corsa Axle Back Exhaust, JLT CAI, and a tune void my warranty?If so, which one(s) will and if possible which one(s) won't? Even the most anal dealers probably are not going to make a big deal about axle back mufflers. As for the tune and CAI, they can easily be removed, so if you have a picky dealer it would just be best to remove them before going in. I also make a 2.65" upper blower pulley that looks like stock, and will fool people unless they start measuring two cars side by side. You can drive to the dealer with this pulley on the stock tune/stock intake if you don't go over 5000rpm (maf pegs above that). Link to comment Share on other sites More sharing options...
1FSTHRSE Posted August 7, 2008 Report Share Posted August 7, 2008 have the dealer install the FRPP parts and the waranyt stays intact...... they just sent me a post card flier with all the FRPP stuff on it and it it keeps the warranty..some if it may only be for a year but that way they do the work and they warranty it... Link to comment Share on other sites More sharing options...
