Michael Morris Posted July 29, 2008 Report Share Posted July 29, 2008 I had to change the oil today in the Super Snake. While we were doing it I needed to SLIDE the rear housing over just a hair. I think the suspension had settle and moved. No big deal it just need to be done while it was in the air. Also needed to adjust one of the mufflers we installed. It looked just a slight bit longer than the other side. Went ahead and took a couple of pictures for yall. Thought yall might like to see what it looks like under there. michael morris Link to comment Share on other sites More sharing options...
srk1959 Posted July 29, 2008 Report Share Posted July 29, 2008 Thanks for the pic's. Link to comment Share on other sites More sharing options...
INDYSHELBY Posted July 29, 2008 Report Share Posted July 29, 2008 Thanks first pictures of the underside interesting to see Link to comment Share on other sites More sharing options...
Alexandros Posted July 30, 2008 Report Share Posted July 30, 2008 Stop teasing MM, you know I still did not get my SS lol ........Nice thanks for the pics..... Link to comment Share on other sites More sharing options...
MB GT500SS Posted July 30, 2008 Report Share Posted July 30, 2008 Thanks for the pics! :happy feet: :happy feet: Link to comment Share on other sites More sharing options...
Michael Morris Posted July 30, 2008 Author Report Share Posted July 30, 2008 MM, I don't follow any of the SS stuff. What are they ducts under your car?I assume to the rear brakes.Did you add these?Are they available separate somewhere?If not, how about some better pics of them.They are for the rear brakes. They do come with the SS package. Now that the car is on the ground I dont know if I can get better pictures. They thing just sits so low. I will try Thursday while its on the showroom. I dont know if they are availble thru SPP or not. michael morris Link to comment Share on other sites More sharing options...
acetrader Posted July 30, 2008 Report Share Posted July 30, 2008 If that is the 725 MM would be so kind to post a sound clip of the exhaust? It would help tie ease my hunger for my SS as I am still waiting for it to get completed at SAI. Thanks a million Link to comment Share on other sites More sharing options...
carrera Posted July 30, 2008 Report Share Posted July 30, 2008 Michael-did the rear suspension actually shift to one side ? If so, how much did it shift . Shouldn't the adjustable panard rod which Shelby is now installing prevent this from happening. Link to comment Share on other sites More sharing options...
Grabber Posted July 30, 2008 Report Share Posted July 30, 2008 Looks nice Michael. Link to comment Share on other sites More sharing options...
Budman340 Posted July 30, 2008 Report Share Posted July 30, 2008 Michael-did the rear suspension actually shift to one side ? If so, how much did it shift . Shouldn't the adjustable panard rod which Shelby is now installing prevent this from happening. No, the suspension didn't "shift" it settled. Meaning, after driving the vehicle around for a while, the suspension will settle down a bit. This can lower the vehicle a little more and the rear housing could shift over a bit. What you have to do is either raise the suspension (only if you have the adjustable Eibach Suspension kit) a little bit or readjust the panhard bar to compensate for the settling. Bud Link to comment Share on other sites More sharing options...
QuietShelby Posted July 30, 2008 Report Share Posted July 30, 2008 Lookin good MM. On another note did you have the little one yet? Blake Link to comment Share on other sites More sharing options...
Michael Morris Posted July 31, 2008 Author Report Share Posted July 31, 2008 Snoop I do know everything, but I dont always give away the info Blake, the baby is about a month away. Thanks for asking :happy feet: Thanks Bud. It was VERY easy to adjust it back to where it needed to be. It just settle less than a HALF inch, but when you stood behind the car you could tell it wasnt correct.michael morris Link to comment Share on other sites More sharing options...
Michael Morris Posted July 31, 2008 Author Report Share Posted July 31, 2008 If that is the 725 MM would be so kind to post a sound clip of the exhaust? It would help tie ease my hunger for my SS as I am still waiting for it to get completed at SAI. Thanks a million Ace here are the clips of before and after. michael morris http://www.teamshelby.com/forums/index.php?showtopic=26922 Link to comment Share on other sites More sharing options...
carrera Posted July 31, 2008 Report Share Posted July 31, 2008 No, the suspension didn't "shift" it settled. Meaning, after driving the vehicle around for a while, the suspension will settle down a bit. This can lower the vehicle a little more and the rear housing could shift over a bit. What you have to do is either raise the suspension (only if you have the adjustable Eibach Suspension kit) a little bit or readjust the panhard bar to compensate for the settling. Bud Thanks for the clarification. Will the same "settling" occur with the Ford Racing suspension and if so is the fix the same Link to comment Share on other sites More sharing options...
Budman340 Posted July 31, 2008 Report Share Posted July 31, 2008 Bud Thanks for the clarification. Will the same "settling" occur with the Ford Racing suspension and if so is the fix the same It will also settle, but I do not think it will be that much. If it does, you can still adjust the pan hard bar. The suspension is not adjustable. But to do it, it only take a few minutes or so. Bud Link to comment Share on other sites More sharing options...
carrera Posted August 1, 2008 Report Share Posted August 1, 2008 It will also settle, but I do not think it will be that much. If it does, you can still adjust the pan hard bar. The suspension is not adjustable. But to do it, it only take a few minutes or so. Bud Good information! Thanks Bud Link to comment Share on other sites More sharing options...
