altopcat Posted July 12, 2008 Report Share Posted July 12, 2008 I love this forum and have seen numerous posts on the infamous muffler rattle. I was sure my 2007 did not have it well not till today. I was at a light and decided to let it out for once and got the infamous muffler rattle as I power shifted through the gears. I cannot find the pictures of the fix of cutting the bracket that was posted. Can anybody get me the link so I can spoon feed it to my Ford dealer. Interesting thing is that it seems when it is hot outside and I push the RPMs it happens not under gentle driving. Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted July 13, 2008 Report Share Posted July 13, 2008 I love this forum and have seen numerous posts on the infamous muffler rattle. I was sure my 2007 did not have it well not till today. I was at a light and decided to let it out for once and got the infamous muffler rattle as I power shifted through the gears. I cannot find the pictures of the fix of cutting the bracket that was posted. Can anybody get me the link so I can spoon feed it to my Ford dealer. Interesting thing is that it seems when it is hot outside and I push the RPMs it happens not under gentle driving. I've never seen photos here; but the issue always seems to be the driver's side rear hanger, when the system is hot, the system "grows" and the hanger expands into the metal behind the bumper, should be an easy fix. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted July 15, 2008 Report Share Posted July 15, 2008 I love this forum and have seen numerous posts on the infamous muffler rattle. I was sure my 2007 did not have it well not till today. I was at a light and decided to let it out for once and got the infamous muffler rattle as I power shifted through the gears. I cannot find the pictures of the fix of cutting the bracket that was posted. Can anybody get me the link so I can spoon feed it to my Ford dealer. Interesting thing is that it seems when it is hot outside and I push the RPMs it happens not under gentle driving. I'm not sure I understand. Are you talking about a shifter rattle? That is an infamous gear related vibration rattle issue but I don't know if I ever heard of a rattle from the muffler being associated with simply shifting gears. There are issues that are heard on small bumps or uneven roads. I had BOTH issues. The shifter was fixed through cutting the exhaust hangers and there us a PDF post of their location if you search for "hangers" maybe.As for the muffler noises there are multiple issues that can cause this. one cause is listed above, in my case it was a broken muffler hanger that banged on the bumper. Try to shake the pipes and see if one has more play than the other or if you hear a banging noise. But in the end, only up on a lift, with a good tech, can you be sure it's one thing and not another. Good luck! Link to comment Share on other sites More sharing options...
06VistaBlueGT Posted July 15, 2008 Report Share Posted July 15, 2008 Hey bud, I know EXACTLY what TSB your looking for. I have the same rattle from my exhaust around the 1,200 RPM range, only when the temp outside is HOT! Click on the link below for the TSB. I got it from Mustang Source. Hope this helps. tsb08_03_04_1_.pdf Link to comment Share on other sites More sharing options...
altopcat Posted July 15, 2008 Author Report Share Posted July 15, 2008 Hey bud, I know EXACTLY what TSB your looking for. I have the same rattle from my exhaust around the 1,200 RPM range, only when the temp outside is HOT! Click on the link below for the TSB. I got it from Mustang Source. Hope this helps. tsb08_03_04_1_.pdf Thanks it is in my Dealers hands as we speak :happy feet: Link to comment Share on other sites More sharing options...
LuLu Posted July 15, 2008 Report Share Posted July 15, 2008 My mufflers don't rattle or make any noise at all. They're sitting very quietly in the corner of my garage. Link to comment Share on other sites More sharing options...
SHELBYBRO Posted July 16, 2008 Report Share Posted July 16, 2008 Thanx. I just downloaded it too and will be giving this to my dealer. This will be the second time I have the exhaust fixed. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted July 16, 2008 Report Share Posted July 16, 2008 Thanx. I just downloaded it too and will be giving this to my dealer. This will be the second time I have the exhaust fixed. Yikes! I am awaiting on a replacement muffler. What was your first problem? Link to comment Share on other sites More sharing options...
06VistaBlueGT Posted July 17, 2008 Report Share Posted July 17, 2008 Thanks it is in my Dealers hands as we speak :happy feet: Thanx. I just downloaded it too and will be giving this to my dealer. This will be the second time I have the exhaust fixed. No problem fellas. Glad to help out. Since that was my 1st post (though I have been a member for well over a year), I'll be sure to post up in the New Members section, with pics of my custom modded '06 GT. I think you guys will like it. Link to comment Share on other sites More sharing options...
BossBronco Posted August 10, 2008 Report Share Posted August 10, 2008 My car had the same noise. I found that the drivers side tail pipe was hitting the body over the rear axle when hot. I went under the car and loosend up the exaust clamp behind the X pipe and pulled the pipe towards the frount 1/2-3/4 in. . No more noise. Hope this helps. I also checked the passenger side . There was no room for movement. Link to comment Share on other sites More sharing options...
