ShelbyKindaGuy Posted July 4, 2008 Report Share Posted July 4, 2008 Since the SGT has been lowered from SAI what are the largest tires that can properly fit (no rubbing the wells during cornering) for both front and back even if staggered? Link to comment Share on other sites More sharing options...
Jer Posted July 4, 2008 Report Share Posted July 4, 2008 Since the SGT has been lowered from SAI what are the largest tires that can properly fit (no rubbing the wells during cornering) for both front and back even if staggered? I was wondering too... Jer Link to comment Share on other sites More sharing options...
RogerS Posted July 5, 2008 Report Share Posted July 5, 2008 I'm running 20" wheels and 255/35/20 Front and 275/35/20 Rear's BF Goodrich KDW in traditional thread pattern with no rubbing at all. The rim sizes are 9x20 front and 10x20 rear. Roger Link to comment Share on other sites More sharing options...
ShelbyPilot Posted July 5, 2008 Report Share Posted July 5, 2008 I had 285/30's on a 10.5 wheel. If I remember correctly a 40mm offset. I am awaiting a new set of 10" wide wheels but will be reusing the same 285/30 tires. One importnat thing with the wider tires is you will probably want to invest in an adjustabel pan hard rod or better yet a watt's link. When the Shelby GTs are lowered they use the stock pan hard rod. That results in the axle being offset. Before I installed a wattslink. My left was outside of the fender while the right was the same amount inside the fender. I think that was the way it was. It isn't noticeable with the stock tires but is very noticeable with wider rubber. Link to comment Share on other sites More sharing options...
ShelbyKindaGuy Posted July 5, 2008 Author Report Share Posted July 5, 2008 Folks I am keeping the stock rims on the car so for my question, staggered = tire size is staggered but rims are all original stock size. So what does that do for any of the answeres already provided? Link to comment Share on other sites More sharing options...
AstroDan Posted July 6, 2008 Report Share Posted July 6, 2008 Folks I am keeping the stock rims on the car so for my question, staggered = tire size is staggered but rims are all original stock size. So what does that do for any of the answeres already provided? It looks like 255/45/ZR18 is the largest you can go with 8.5" rims... Here's some info from BFG... http://www.bfgoodrichtires.com/specs/g-force-t-a-kdw/22.html Link to comment Share on other sites More sharing options...
07SGT4578 Posted July 6, 2008 Report Share Posted July 6, 2008 my question, 18X9.5 shelby CS69 (black). what size staggered tires? Link to comment Share on other sites More sharing options...
