RogerS Posted June 30, 2008 Report Share Posted June 30, 2008 Here is the link for a strut tower brace for Whipple Supercharged 4.6 05-08 Mustangs. Thanks for the link Paul Roger http://www.steeda.com/products/steeda_bill...tower_brace.php EDIT: it will NOT fit under the stock or CS6 hoods. Link to comment Share on other sites More sharing options...
Dig-It Posted June 30, 2008 Report Share Posted June 30, 2008 Very cool Roger. Are you going to give it a shot? Link to comment Share on other sites More sharing options...
RogerS Posted June 30, 2008 Author Report Share Posted June 30, 2008 Very cool Roger. Are you going to give it a shot? just ordered. Link to comment Share on other sites More sharing options...
RogerS Posted June 30, 2008 Author Report Share Posted June 30, 2008 Cancel that Kevin..............they just called back and told me it requires an aftermarket hood and will not fit under the stock or CS6 hoods. Back to the drawing board! Link to comment Share on other sites More sharing options...
Dig-It Posted June 30, 2008 Report Share Posted June 30, 2008 Bummer! Link to comment Share on other sites More sharing options...
AFBLUE Posted June 30, 2008 Report Share Posted June 30, 2008 Hmmm. I wonder if it would work with my Trufiber Roadster hood. Link to comment Share on other sites More sharing options...
RogerS Posted June 30, 2008 Author Report Share Posted June 30, 2008 It becomes all about the contour of the underside of the hood. The CS6 is the same as a factory hood. They cut a hole for the Whipple SC. From what I Dig-it tells me the height variation is in the intake manifolds of the different SC's. The Whipple is taller than all others. So if you Trufiber follows the contour of the factory hood I would say no. But some ot the Trufibers are raised to follow the exterior contour. I think Kevin mentioned the difference is 3/8" taller than a Kenne Bell. I may have the number wrong though. But the Whipple is higher presenting clearance issues. Roger Link to comment Share on other sites More sharing options...
AFBLUE Posted June 30, 2008 Report Share Posted June 30, 2008 Well it does have a funtional hood scoop in the center so maybe it does have a higher clearance there. Will have to look at it when I get home. Link to comment Share on other sites More sharing options...
Dig-It Posted June 30, 2008 Report Share Posted June 30, 2008 Well it does have a funtional hood scoop in the center so maybe it does have a higher clearance there. Will have to look at it when I get home. When's that? EDIT: Nevermind, I just saw your answer in another thread. Link to comment Share on other sites More sharing options...
GT500-07 Posted June 30, 2008 Report Share Posted June 30, 2008 Cancel that Kevin..............they just called back and told me it requires an aftermarket hood and will not fit under the stock or CS6 hoods. Back to the drawing board! Sorry about that Roger. When I was talking to the Steeda Tech we were discussing a heat extraction hood. My bad Link to comment Share on other sites More sharing options...
RogerS Posted June 30, 2008 Author Report Share Posted June 30, 2008 Sorry about that Roger. When I was talking to the Steeda Tech we were discussing a heat extraction hood. My bad Nothing to be sorry about Paul. I was getting excited. I will still have to tackle this myself. If a "deep draw" comes to market there could be several options. Thanks again for the link. It does give Whipple owner's the option of changing out hoods and having an "off the shelf" strut tower brace option. Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted June 30, 2008 Report Share Posted June 30, 2008 Nice avatar there Spider-bite man! SEF AKA: Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted June 30, 2008 Report Share Posted June 30, 2008 Nothing to be sorry about Paul. I was getting excited. I will still have to tackle this myself. If a "deep draw" comes to market there could be several options. Thanks again for the link. It does give Whipple owner's the option of changing out hoods and having an "off the shelf" strut tower brace option. I have been told that the Agent 47 double barrel max clearance strut tower brace will fit over the Whipple and under a stock hood, I have it on order and will post pictures once it comes in and IF it fits. Stillen's link to Agent 47 Strut Tower Brace This is an image of it from Agent 47's website Agent 47 link Paige at Stillen may be able to verify this. Andrew Link to comment Share on other sites More sharing options...
RogerS Posted June 30, 2008 Author Report Share Posted June 30, 2008 Thanks for the info. I had spoke to Agent 47 directly some time ago and they could not tell me 100% if it would fit uner the hood. But looking at that shot I believe you will have issues with the driver side due to the location of the throttle body and air inlet tube on the Whipple. It is more offset to the shock tower and the bends are too low. I don't think there is not enough clearance. Let us know how you make out. Roger Link to comment Share on other sites More sharing options...
RogerS Posted June 30, 2008 Author Report Share Posted June 30, 2008 Nice avatar there Spider-bite man! SEF AKA: I just had to use it SEF. You don't know how many Spider Man jokes I hear every day. But no one wanted to take my place in the hospital! Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted June 30, 2008 Report Share Posted June 30, 2008 Thanks for the info. I had spoke to Agent 47 directly some time ago and they could not tell me 100% if it would fit uner the hood. But looking at that shot I believe you will have issues with the driver side due to the location of the throttle body and air inlet tube on the Whipple. It is more offset to the shock tower and the bends are too low. I don't think there is not enough clearance. Let us know how you make out. Roger Roger, No doubt until I see it on it, it is still only in the hoping stage; if it doesn't fit it is going back. Once it is here I will let everyone know one way or another. Andrew Link to comment Share on other sites More sharing options...
SGT2666 Posted July 1, 2008 Report Share Posted July 1, 2008 Thanks for the info. I had spoke to Agent 47 directly some time ago and they could not tell me 100% if it would fit uner the hood. But looking at that shot I believe you will have issues with the driver side due to the location of the throttle body and air inlet tube on the Whipple. It is more offset to the shock tower and the bends are too low. I don't think there is not enough clearance. Let us know how you make out. Roger +1 I spoke to them as well, they thought it might fit but would not guarantee it. The throttle body is much more of an issue then height, you would have to come of the strut on the drivers side at a much steeper angle. Link to comment Share on other sites More sharing options...
SGT2666 Posted July 1, 2008 Report Share Posted July 1, 2008 I just had to use it SEF. You don't know how many Spider Man jokes I hear every day. But no one wanted to take my place in the hospital! Thats funny I was wondering what the Spiderman tie in was Link to comment Share on other sites More sharing options...
pottydr Posted July 1, 2008 Report Share Posted July 1, 2008 I do not think that agent47 brace will clear the throttle body, If somebody has a whipple that is going to the socal meeting in July, I will try my brace on there car, yes I have tools, Rick Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 30, 2008 Report Share Posted July 30, 2008 I do not think that agent47 brace will clear the throttle body, If somebody has a whipple that is going to the socal meeting in July, I will try my brace on there car, yes I have tools, Rick Roger and Rick were correct The Agent 47 Double Barrel Strut Brace does NOT fit over the Whipple due to the throttle body ! I was wrong, but they did take it back for a full refund. I talked to BMR Fabrications today and they said they had nothing currently that would fit the Whipple with a stock GT hood, but they were looking into it/thinking about it and that it would take time and something should eventually come out (no time table) Thanks Andrew Link to comment Share on other sites More sharing options...
RogerS Posted July 31, 2008 Author Report Share Posted July 31, 2008 I know the feeling Andrew, I have been all around this subject for about 1 year now. I have one more hope. We will see. Link to comment Share on other sites More sharing options...
