rheller Posted June 26, 2008 Report Share Posted June 26, 2008 After several hundred miles on the odometer, it began to dawn on me that the supercharger has never kicked in (duh) on my 2008 coupe. And, yes, I have not driven the beast hard. Today, I took 95 north to Portland Maine and twice tached it to 5,000+, resulting in no supercharger and no movement on the PSI boost gauge. With that, I called my dealership service manager and made an appointment to bring it in next week. Of course, they want me to leave the car, which I have initially declined to do. I said I would wait. Is this a result of improper dealer prep after initial delivery? Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted June 26, 2008 Report Share Posted June 26, 2008 did you hear the whine of the supercharger when you got on it hard? if so the gauge is bad. Link to comment Share on other sites More sharing options...
rheller Posted June 26, 2008 Author Report Share Posted June 26, 2008 did you hear the whine of the supercharger when you got on it hard? if so the gauge is bad. Nada. No whine, no supercharger, no boost. Yeah, I got on it pretty good, so something is wrong. Link to comment Share on other sites More sharing options...
mrdci Posted June 26, 2008 Report Share Posted June 26, 2008 Nada. No whine, no supercharger, no boost. Yeah, I got on it pretty good, so something is wrong. So is the belt on the pulley is the pulley spinning? I mean its a pretty simple design so unless the pulley isn't attached to the screws it should whine. Link to comment Share on other sites More sharing options...
turbogt-500 Posted June 26, 2008 Report Share Posted June 26, 2008 So is the belt on the pulley is the pulley spinning? I mean its a pretty simple design so unless the pulley isn't attached to the screws it should whine. Try disconnecting the battery for 5-10 min. and turn on the headlightswitch to fully drain any power in the car. then reconnect and try it. IIRC there is some kind mode that wont make boost. The service manager told me to do it first thing when I bought mine. Hopefully it helps. Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted June 26, 2008 Report Share Posted June 26, 2008 sc engagement is a function of a couple of things; I would go on a highway, and in second gear at about 3k rpm floor it and see the reaction of the car and gauge. You should feel the car start to really take off after a second or two, and some whine (although muffled with the stock air cleaner) and you should see some boost after a few seconds. You do need to leave it floored for more than a couple of seconds though, so do it without other cars around. good luck Link to comment Share on other sites More sharing options...
Mustang5 Posted June 26, 2008 Report Share Posted June 26, 2008 I will second what KCMO-GT500 has said. You mentioned that you took the engine to 5000 RPM, but you didn't mention if you were flooring it or not. Unlike less sophisticated superchargers of the past, ours does not develop boost all the time. There is a waste gate function that dumbs boost until the accelerator is in the last inch or so of throttle movement. By putting it in second gear and flooring it from about 40 mph you'll have about 3 seconds to read the boost gauge before you hit 80 and have to shift to 3rd. gear. Hopefully you'll find that every thing is fine. Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted June 26, 2008 Report Share Posted June 26, 2008 thanks for going into more detail, I forgot to mention how quickly third and fourth gear come up I am guessing that the OP is not a real aggressive driver (which is fine, probably a better trait than like I am ) since he did not worry about the sc kicking in for this long. That was the first thing that I checked :o Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted June 26, 2008 Report Share Posted June 26, 2008 ..and while I'm being a badcat, how would you like to be the ford mechanic who was given the dreadful task of finding out if the sc on a gt500 was really working??? :P gosh, just throw me in the briar patch LOL Link to comment Share on other sites More sharing options...
Hisssss Posted June 26, 2008 Report Share Posted June 26, 2008 After several hundred miles on the odometer, it began to dawn on me that the supercharger has never kicked in (duh) on my 2008 coupe. And, yes, I have not driven the beast hard. Today, I took 95 north to Portland Maine and twice tached it to 5,000+, resulting in no supercharger and no movement on the PSI boost gauge. With that, I called my dealership service manager and made an appointment to bring it in next week. Of course, they want me to leave the car, which I have initially declined to do. I said I would wait. Is this a result of improper dealer prep after initial delivery? OK, let me get this straight....."the supercharger has never kicked in" Well, lets get to the bottom of this conundrum, maybe the Eaton is rusted shut??? no, no.... ... the dealer must have forgotten to remove the throttle stop from the bottom of the accelerator pedal...no, no, highly unlikely, part of the 40 point pre assembly inspection... MAN, what could it BE????? WAIT....I got it.... Your dealer installed Mad Max shift lever mounted supercharger on off switch is stuck in the OFF position I dont really mean to come off like a d!*%Head, but is this post really for real????? But on a serious note, your one and only problem is that you need to kick that mule in the guts!!! Wring that bitch out like a wet dish rag...Put it in first gear and "lay a big ole fat patch down brutha!!!!!" AKA, drive it like Max would NOT like your mother... Link to comment Share on other sites More sharing options...
Blackhawkpilot Posted June 26, 2008 Report Share Posted June 26, 2008 Wring that bitch out like a wet dish rag...AKA, drive it like Max would NOT like your mother... I've found my mantra! Link to comment Share on other sites More sharing options...
Hisssss Posted June 26, 2008 Report Share Posted June 26, 2008 Hey Mike, I couldn't resist....it took me 10 minutes to think up all those cheezy one liners.. Link to comment Share on other sites More sharing options...
Blackhawkpilot Posted June 26, 2008 Report Share Posted June 26, 2008 Hey Mike, I couldn't resist....it took me 10 minutes to think up all those cheezy one liners.. Yeah man, that's good stuff One-liners are always the best way to get a point across.... Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted June 26, 2008 Report Share Posted June 26, 2008 try this per ford for reseting the pcm PCM_Reset_Shelby_2.pdf PCM_Reset_Shelby_2.pdf Link to comment Share on other sites More sharing options...
rheller Posted June 26, 2008 Author Report Share Posted June 26, 2008 try this per ford for reseting the pcm PCM_Reset_Shelby_2.pdf Thank you, Coldwater. I'll bring that as a print out with me to the dealership. Link to comment Share on other sites More sharing options...
Justin00Stang Posted June 26, 2008 Report Share Posted June 26, 2008 Sounds like a hardware issue, possibly a Bypass that is stuck open. I don't expect the PCM to be causing a problem. You may want to check the 2nd vac line that goes to the BPV, behind the blower and try playing with the linkage. Link to comment Share on other sites More sharing options...
rheller Posted July 1, 2008 Author Report Share Posted July 1, 2008 Visited my SVT Ford mechanic today and he checked out the beast. Bottom line is that he said there was no problemo with the car. The problemo is with the driver (that would be me). Yikes! That qualifies me as a wuss. Ok, I'll go pull out my Devo album "Are We Not Men" and flog myself a time or two. Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted July 2, 2008 Report Share Posted July 2, 2008 Operator error! Link to comment Share on other sites More sharing options...
FiaCobra Posted July 2, 2008 Report Share Posted July 2, 2008 Wow, i can't believe what i just read. I almost feel embarrassed for the OP. Don't be scared to drive the car hard, that's what it was built for. You'll probably do more damage driving it like an old lady as opposed to beating on it. Link to comment Share on other sites More sharing options...
drlovegun Posted July 2, 2008 Report Share Posted July 2, 2008 Visited my SVT Ford mechanic today and he checked out the beast. Bottom line is that he said there was no problemo with the car. The problemo is with the driver (that would be me). Yikes! That qualifies me as a wuss. Ok, I'll go pull out my Devo album "Are We Not Men" and flog myself a time or two. Where are you located? I ask cause you said "towards Portland Maine". I'm in the Manchester, NH area, come on out and I'll teach you how to get that blower goin' :happy feet: Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted July 2, 2008 Report Share Posted July 2, 2008 Visited my SVT Ford mechanic today and he checked out the beast. Bottom line is that he said there was no problemo with the car. The problemo is with the driver (that would be me). Yikes! That qualifies me as a wuss. Ok, I'll go pull out my Devo album "Are We Not Men" and flog myself a time or two. thanks for letting us know how it turned out; don't feel bad, not everybody is a natural hot rodder, and the car really does have quite a bit of power even without the sc kicking in. Word of advice, full throttle at too low a speed can easily put you sideways, so be prepared, and try it out under various situations to get a good feel for using it to the full potential. Link to comment Share on other sites More sharing options...
rheller Posted July 2, 2008 Author Report Share Posted July 2, 2008 Where are you located? I ask cause you said "towards Portland Maine". I'm in the Manchester, NH area, come on out and I'll teach you how to get that blower goin' :happy feet: I'm in the Dover/Rochester/Lee area. There is another red coupe in my town of Barrington. His is an 07. His plates read "07COBRA" while mine read "GT500." Ok, so he has more balls than I, but I plan on addressing that ASAP. Link to comment Share on other sites More sharing options...
