JRKANOT Posted June 26, 2008 Report Share Posted June 26, 2008 I bought a GT500 steering wheel to replace my stocker on my Shelby GT. Mine didn't come w/ the leather wrapped wheel and the composite is a little rough on the hands on long drives. Is this a job that a guy w/ average mechanical skills can handle or should I just have the dealer do so it's done right the first time? Link to comment Share on other sites More sharing options...
RogerS Posted June 26, 2008 Report Share Posted June 26, 2008 You can do it yourself. I did mine. Hope this helps. airbag.pdf steeringwheel.pdf airbag.pdf steeringwheel.pdf Link to comment Share on other sites More sharing options...
JRKANOT Posted June 26, 2008 Author Report Share Posted June 26, 2008 You can do it yourself. I did mine. Hope this helps. Thanks. That's exactly what I needed. :beerchug: I just need a torque wrench. Where did you get your steering wheel? I got mine from Blue Oval Industries and it came w/ an extra boot. Link to comment Share on other sites More sharing options...
RogerS Posted June 26, 2008 Report Share Posted June 26, 2008 Same place. I only went with the GT500 with the red stitching. Then shipped it out to W. Rau Restorations in Cali. for the carbon fiber conversion. Blue Oval had the best price at the time. Didn't get the boot. I had it custom made with red stitching to match the wheel. Roger Link to comment Share on other sites More sharing options...
blueshawk Posted June 26, 2008 Report Share Posted June 26, 2008 Thanks.That's exactly what I needed. :beerchug: I just need a torque wrench. Where did you get your steering wheel? I got mine from Blue Oval Industries and it came w/ an extra boot. I got mine from Blue Oval also with he black stitching. The boot is real leather and not the stuff that comes with the car. Don't forget to do the depowering and repowering sequence before and after you do the air bag. Link to comment Share on other sites More sharing options...
msouhlas Posted June 26, 2008 Report Share Posted June 26, 2008 I got mine from Blue Oval also with he black stitching. The boot is real leather and not the stuff that comes with the car. Don't forget to do the depowering and repowering sequence before and after you do the air bag. What is the depowering / repowering procedure? Do you have that section of the manual? (Thanks for your advice) Link to comment Share on other sites More sharing options...
RogerS Posted June 26, 2008 Report Share Posted June 26, 2008 I had a Ford Master Tech assist me and all he did was disconnect the battery. Link to comment Share on other sites More sharing options...
blueshawk Posted June 27, 2008 Report Share Posted June 27, 2008 I had a Ford Master Tech assist me and all he did was disconnect the battery. The Ford instructions also say to remove the RCM fuse from the SJB. I didn't do that but I did remove the negative battery terminal, and then turned on the lights and stepped on the brake, etc. to deplete all the charges in the airbag sensors. Then you need to turn all the stuff off. The idea is to not have any charges in the systems that may power one of the airbag sensors. Link to comment Share on other sites More sharing options...
stormeaston Posted June 27, 2008 Report Share Posted June 27, 2008 You can do it yourself. I did mine. Hope this helps. SCHWEEEEEEEEEEEEET! Link to comment Share on other sites More sharing options...
