'69fstbk/'07gt500 Posted June 12, 2008 Report Share Posted June 12, 2008 I tried to find the answer to this but couldn't so I started my 1st New Thread.... The boys with their SS's back MM, Son, ect.... Do you guys have a hood lift kit and if so what one and how's it holding up? Any pics would be great and your help is greatly appreciated. Thanks!! -- Keith Link to comment Share on other sites More sharing options...
REDC500 Posted June 12, 2008 Report Share Posted June 12, 2008 I tried to find the answer to this but couldn't so I started my 1st New Thread....The boys with their SS's back MM, Son, ect.... Do you guys have a hood lift kit and if so what one and how's it holding up? Any pics would be great and your help is greatly appreciated. Thanks!! -- Keith Try these they don't put pressure on hood when closing or closed. (Fancy prop) http://www.uprproducts.com/shopping/shopexd.asp?id=1090 Link to comment Share on other sites More sharing options...
jsdogs1 Posted June 13, 2008 Report Share Posted June 13, 2008 I personally am trying to keep mine all original so it's the old original prop for me. Link to comment Share on other sites More sharing options...
RogerS Posted June 13, 2008 Report Share Posted June 13, 2008 I know that some on the market will not hold up the CS6 hood. Link to comment Share on other sites More sharing options...
GT500-07 Posted July 26, 2008 Report Share Posted July 26, 2008 just found these today, http://mrt-direct.com/v3/Styling%202005+/E...ing%202005+.php http://www.modernspeedmachines.com/catalog...products_id/524 Link to comment Share on other sites More sharing options...
Michael Morris Posted July 26, 2008 Report Share Posted July 26, 2008 I tried to find the answer to this but couldn't so I started my 1st New Thread....The boys with their SS's back MM, Son, ect.... Do you guys have a hood lift kit and if so what one and how's it holding up? Any pics would be great and your help is greatly appreciated. Thanks!! -- Keith I had talked to SAI about adding the kit, but was told the hood was to heavy and would work. Since I have decided to keep it mostly original, but would look at some black ones if anyone finds a set. michael morris Link to comment Share on other sites More sharing options...
GT500-07 Posted July 26, 2008 Report Share Posted July 26, 2008 here's another, fiberglass hoods are heavier then the stock hoods, http://www.greatlakesclassics.com/2005-200...od%20Struts.htm Link to comment Share on other sites More sharing options...
GT500-07 Posted July 26, 2008 Report Share Posted July 26, 2008 I had talked to SAI about adding the kit, but was told the hood was to heavy and would work. Since I have decided to keep it mostly original, but would look at some black ones if anyone finds a set. michael morris you will need these struts, they work perfect on the fiberglass hoods, plenty of lift and stay. Enidine Corp. (716) 662- 1900 GSML35150 8 x 18 91mm stroke 670N F Master Lift Carbon Steel Gas Spg. Link to comment Share on other sites More sharing options...
Shelby101 Posted July 26, 2008 Report Share Posted July 26, 2008 I have the MRt ones on my original GT500 hood. It is at SAI now, I hope they will try to use them while it is there. We'll see Worked GREAT on the original hood Link to comment Share on other sites More sharing options...
GT500-07 Posted July 26, 2008 Report Share Posted July 26, 2008 here's one from Stillen, Page could tell you about http://www.stillen.com/newproducts.asp?id=109 Link to comment Share on other sites More sharing options...
Son of GT Posted July 28, 2008 Report Share Posted July 28, 2008 I have the MRt ones on my original GT500 hood.It is at SAI now, I hope they will try to use them while it is there. We'll see Worked GREAT on the original hood They will. They did with my MRT lift struts. They needed to shim them, but that's good because they (SAI) are now finding out that either the hinges or the hinge fastners might dimple the hood in that area if they don't shim the hinge mounting plates (stock or otherwise) off of the underside of the hood. Two TS members had issues with dimpling in their SS hoods, and I know that one of them was resolved after SAI added shims. Link to comment Share on other sites More sharing options...
pottydr Posted July 28, 2008 Report Share Posted July 28, 2008 The ones that SAI sells will not hold up my stock SGT hood, they have sent replacements and still no go, when it gets over 70 F the hood will fall down. Rick Link to comment Share on other sites More sharing options...
Son of GT Posted July 28, 2008 Report Share Posted July 28, 2008 The ones that SAI sells will not hold up my stock SGT hood, they have sent replacements and still no go, when it gets over 70 F the hood will fall down. Rick Agreed, and that's true with the MRT's too. I have spent quite a bit of time trying to find a proper OEM gas strut that will hold the hood up no matter what (weight and/or ambient tempature), but every one that I have tried does not seem to work either. I have tried struts from an Explorer, but they are too short. I have tried struts from other cars that use them, but they are either too long or too weak for the appliciation. The MRT struts seem to work with the SS hood (below 70 degrees) right now, but did not work on the stock GT500 hood or the CS6/GTH hood too. The GTH hood on my SGTS/C falls whenever the slightest breeze is put upon it so I still have to use a prop rod as a safety. I contacted MRT on numerious occiasions, but all I ever got from them were excuses, so I'm still on the hunt for an OEM strut that will fit on the MRT assembly. Link to comment Share on other sites More sharing options...
GT500-07 Posted July 28, 2008 Report Share Posted July 28, 2008 Agreed, and that's true with the MRT's too. I have spent quite a bit of time trying to find a proper OEM gas strut that will hold the hood up no matter what (weight and/or ambient tempature), but every one that I have tried does not seem to work either. I have tried struts from an Explorer, but they are too short. I have tried struts from other cars that use them, but they are either too long or too weak for the appliciation. The MRT struts seem to work with the SS hood (below 70 degrees) right now, but did not work on the stock GT500 hood or the CS6/GTH hood too. The GTH hood on my SGTS/C falls whenever the slightest breeze is put upon it so I still have to use a prop rod as a safety. I contacted MRT on numerious occiasions, but all I ever got from them were excuses, so I'm still on the hunt for an OEM strut that will fit on the MRT assembly. E, these will hold the SS hood, they fit the Steeda kit, not sure about the MRT Enidine Corp. (716) 662- 1900 GSML35150 8 x 18 91mm stroke 670N F Master Lift Carbon Steel Gas Spg. Link to comment Share on other sites More sharing options...
'69fstbk/'07gt500 Posted July 28, 2008 Author Report Share Posted July 28, 2008 E, these will hold the SS hood, they fit the Steeda kit, not sure about the MRT Enidine Corp. (716) 662- 1900 GSML35150 8 x 18 91mm stroke 670N F Master Lift Carbon Steel Gas Spg. Paul are you sure that they will fit under the hood clearance to close? Link to comment Share on other sites More sharing options...
Son of GT Posted July 28, 2008 Report Share Posted July 28, 2008 E, these will hold the SS hood, they fit the Steeda kit, not sure about the MRT Enidine Corp. (716) 662- 1900 GSML35150 8 x 18 91mm stroke 670N F Master Lift Carbon Steel Gas Spg. Paul are you sure that they will fit under the hood clearance to close? Thank you Paul. If these struts mount onto the Steeda's with a ball and socket, then they should also fit the MRT brand hood lift assembly too. I'll be contacting Enidine about these. As 69/07 asks, any clearance issues that you are aware of with the Enidine struts? Thanks again! Link to comment Share on other sites More sharing options...
'69fstbk/'07gt500 Posted July 28, 2008 Author Report Share Posted July 28, 2008 Thank you Paul. If these struts mount onto the Steeda's with a ball and socket, then they should also fit the MRT brand hood lift assembly too. I'll be contacting Enidine about these. As 69/07 asks, any clearance issues that you are aware of with the Enidine struts? Thanks again! Hey guys I tried these with no luck! http://www.redlinetuning.com/QL-FORD-MUS-05-RD.html They work and look great but can't close the hood. Anyone with answers to correct this or ones that will clear would be great! Thanks guys! Link to comment Share on other sites More sharing options...
Son of GT Posted July 28, 2008 Report Share Posted July 28, 2008 Hey guys I tried these with no luck! http://www.redlinetuning.com/QL-FORD-MUS-05-RD.html They work and look great but can't close the hood. Anyone with answers to correct this or ones that will clear would be great! Thanks guys! Okay, now I'm confused. Is the posted link and your experience referring to the Enidine struts or the ones being advertised at Redline Tuning? Link to comment Share on other sites More sharing options...
'69fstbk/'07gt500 Posted July 28, 2008 Author Report Share Posted July 28, 2008 Okay, now I'm confused. Is the posted link and your experience referring to the Enidine struts or the ones being advertised at Redline Tuning? Sorry!!! No I'm saying the Redline didn't work out... Sorry if I was confusing E. Link to comment Share on other sites More sharing options...
Son of GT Posted July 28, 2008 Report Share Posted July 28, 2008 Sorry!!! No I'm saying the Redline didn't work out... Sorry if I was confusing E. Okay, got it! Thanks again! Link to comment Share on other sites More sharing options...
GT500-07 Posted July 28, 2008 Report Share Posted July 28, 2008 Paul are you sure that they will fit under the hood clearance to close? I have them with the Steeda kit and a few others with Prglass hoods have the same set up. Link to comment Share on other sites More sharing options...
GT500-07 Posted July 28, 2008 Report Share Posted July 28, 2008 Thank you Paul. If these struts mount onto the Steeda's with a ball and socket, then they should also fit the MRT brand hood lift assembly too. I'll be contacting Enidine about these. As 69/07 asks, any clearance issues that you are aware of with the Enidine struts? Thanks again! VNMOUS1 give me the information back in April. He has the 68KR retro hood from Proglass, very nice hoods, but heavy. Link to comment Share on other sites More sharing options...
mciarochi Posted October 9, 2008 Report Share Posted October 9, 2008 I returned the gas props and bought a stainless steel prop from SPP for about $30 if I recall. Cheap, looks good, works, and no worries. The original rod is with all my other original take-off parts if anybody ever wants them. Link to comment Share on other sites More sharing options...
Alexandros Posted October 13, 2008 Report Share Posted October 13, 2008 Thank you Paul. If these struts mount onto the Steeda's with a ball and socket, then they should also fit the MRT brand hood lift assembly too. I'll be contacting Enidine about these. As 69/07 asks, any clearance issues that you are aware of with the Enidine struts? Thanks again! I love the pic of you with Mr.Shelby...... Link to comment Share on other sites More sharing options...
