s-code Posted June 10, 2008 Report Share Posted June 10, 2008 i am installing a paxton sn-60 (older but very nice polished unit) on my small block 289 engine (mild cam and mild headwork) and was just curious about carb specs for running a paxton. i got my brackets and fuel pump from craig over at paradise. i just was wondering what the best carb and distributor setup would be for this. thanks for any help Link to comment Share on other sites More sharing options...
zray Posted June 10, 2008 Report Share Posted June 10, 2008 i am installing a paxton sn-60 (older but very nice polished unit) on my small block 289 engine (mild cam and mild headwork) and was just curious about carb specs for running a paxton. i got my brackets and fuel pump from craig over at paradise. i just was wondering what the best carb and distributor setup would be for this.thanks for any help you should do whatever craig connely recommends. He knows the most. I used to have a Paxton set up on '66 GT-350 but I don't recall the carb jets I used. As for the distributor, I didn't have to retard the timing at all from stock specs. The older Paxtons didn't really put out that much boost in comparison to the modern units. I did have a problem with the carb flooding on occasion. Z. Ray Link to comment Share on other sites More sharing options...
MAMBA-SS Posted July 31, 2008 Report Share Posted July 31, 2008 i am installing a paxton sn-60 (older but very nice polished unit) on my small block 289 engine (mild cam and mild headwork) and was just curious about carb specs for running a paxton. i got my brackets and fuel pump from craig over at paradise. i just was wondering what the best carb and distributor setup would be for this.thanks for any help I have an original NOS Paxton Supercharger still in the box and wrapped in 1967 LA Times newspaper. It has the installation book with it. If you'd like I will Fax or mail a copy of the manual to you. My home E-Mail is. oz.lamonds@verizon.net Link to comment Share on other sites More sharing options...
kahmann Posted April 29, 2009 Report Share Posted April 29, 2009 i am installing a paxton sn-60 (older but very nice polished unit) on my small block 289 engine (mild cam and mild headwork) and was just curious about carb specs for running a paxton. i got my brackets and fuel pump from craig over at paradise. i just was wondering what the best carb and distributor setup would be for this.thanks for any help I've been considering the same route. I raced with a 67 GT-350 a week and a half ago at Thunderhill. He had the Paxton installed and it sounded and seemed to run great. It's definitely a unique setup and one that I'd like more info on. Anyone on TS with any insight? Ken Link to comment Share on other sites More sharing options...
