skiph Posted May 31, 2008 Report Share Posted May 31, 2008 I'm a better safe then sorry kind of guy, so I'm bending over and paid $8/qt for a 16 qts of the 5-50 "B" spec oil from the dealer, and did not see a specific product number anywhere for the oil filter. Enough for a couple of oil changes and a qt in the trunk for if I ever run low. The dealer "seemed" to know exactly what I needed when I came in for the oil filter, so I trusted them, but only to the point of bying one oil filter. It's a Ford Racing, Performance Parts Filter. Part number - CM-6731-FL820 Sound like the right/best filter to everybody? And I don't suppose it's available anywhere else but a Dealer. But thoughts on that would be cool as well. Link to comment Share on other sites More sharing options...
Grabber Posted May 31, 2008 Report Share Posted May 31, 2008 Use the specified Motorcraft filter for the best flow. I have read that it is the best for our cars. I also have a "friend" at the plant that has advised me of this. I did my 2nd oil change Jan 16th, 2008 after Ford installed my new clutch and tranny. 3600 miles on my car for the 2nd oil change. I did the first oil change at 919. This one should take me untill the end of the Summer of 2008. This was the first time I have used these ramps on the front of the car. I had to use a 2X10 under them so the front splitter would not rub. Other then that, they worked great. Link to comment Share on other sites More sharing options...
phr3121 Posted May 31, 2008 Report Share Posted May 31, 2008 The dealer "seemed" to know exactly what I needed when I came in for the oil filter, so I trusted them, but only to the point of bying one oil filter. It's a Ford Racing, Performance Parts Filter. Part number - CM-6731-FL820 And I don't suppose it's available anywhere else but a Dealer. But thoughts on that would be cool as well. May want to check out this thread: http://www.teamshelby.com/forums/index.php...ic=25102&hl Link to comment Share on other sites More sharing options...
skiph Posted May 31, 2008 Author Report Share Posted May 31, 2008 Great shots of your car, ramps and such Grabber. Yea, looks like I'll use the Motocraft filter in the future, but based on a TON of surfing I did here, the Ford Racing one I got is equal to, or perhaps a little better flow rate (depending on who you believe, and what specs mean to you) so should not HURT anything to use. But, probably paying for the "Ford Racing" stamp on the filter more then anything else. Link to comment Share on other sites More sharing options...
07SHELBY GT Posted May 31, 2008 Report Share Posted May 31, 2008 FL820S here.I also got my oil at $8.00 a quart and bought the specified filter at the dealer.I hope someone buys the B cert soon so we can save a little money. Link to comment Share on other sites More sharing options...
ingram4868 Posted May 31, 2008 Report Share Posted May 31, 2008 $8.00 per QT is a good price. Some dealers charge $14.00. There is nothing wrong with the Ford Racing filter but I believe it is overkill. The Motorcraft is also a good filter and what I use. Link to comment Share on other sites More sharing options...
FiaCobra Posted May 31, 2008 Report Share Posted May 31, 2008 The motorcraft filter is fine. I did install the "racing filter" for my 1st oil change. The only noticeable difference was the heft/weight of it. It's definitely heavier than the motorcraft filter. My dealer stocks both. Link to comment Share on other sites More sharing options...
LuisA Posted May 31, 2008 Report Share Posted May 31, 2008 I sue Mobil 1 oil filter due to the fact that it has a much better filtering efficiency. Link to comment Share on other sites More sharing options...
Boss Doctor Posted June 2, 2008 Report Share Posted June 2, 2008 I sue Mobil 1 oil filter due to the fact that it has a much better filtering efficiency. I hope that's a typo. Link to comment Share on other sites More sharing options...
89Saleen215 Posted June 3, 2008 Report Share Posted June 3, 2008 Anyone tried a Trasko piece? http://www.trasko-usa.com/ Link to comment Share on other sites More sharing options...
