old guy Posted April 30, 2008 Report Share Posted April 30, 2008 Does anyone know if there are any additional tunes for the Super Snake hood with the Ford Racing CAI and JBA mufflers? I got the tune from SAI when I got the hood, but a check engine code indicated that the car is running lean on both banks. It usually happens after I get on it pretty good then shut down and restart the engine. SAI has sent me a baffle plate to fit over the ram air hole in the hood and instructed me to drill some holes in it, but there is no indication where to drill, what size holes or how many to drill. We have blocked the hood intake with foam and the light takes a little longer to come on, but it still comes on eventually. The baffle might fix the problem, but I don't want to paint it and attach it then drill random holes if it's not going to fix the problem or if there is a new program coming out. It seems to me that the baffle defeats the whole purpose of having the ram air. I spoke with SVT and they told me that tuning the computer with anything but an approved program will void my warranty. Does anyone have any additional information? Is SAI or SVT working on this or is the baffle their final answer? Link to comment Share on other sites More sharing options...
old guy Posted April 30, 2008 Author Report Share Posted April 30, 2008 Forgot... on an '07 GT500 Coupe Link to comment Share on other sites More sharing options...
svt boost Posted April 30, 2008 Report Share Posted April 30, 2008 Forgot... on an '07 GT500 Coupe known issue, install the baffle. the ram air effect causes too much AIR and not enough Fuel thus the lean codes. at least I think that is what was stated...a member had this problem a few weeks ago and the baffle solved the problem. Link to comment Share on other sites More sharing options...
old guy Posted April 30, 2008 Author Report Share Posted April 30, 2008 known issue, install the baffle. the ram air effect causes too much AIR and not enough Fuel thus the lean codes. at least I think that is what was stated...a member had this problem a few weeks ago and the baffle solved the problem. Yes, it seems that is the problem, but I still don't understand why they would want the hole plugged. It seems that the car would be able to be tuned for the ram air and breathe a whole lot better. As for installing the baffle... Were there any suggestions for drilling holes in the baffle? How many? What size? Location? Thanks. Link to comment Share on other sites More sharing options...
Son of GT Posted April 30, 2008 Report Share Posted April 30, 2008 Here ya go young man... If you need specific dementions and the like, let me know and I'll take some measurements for you, but off of the top of my head, I would say the holes are 2.5 inches in diameter. Link to comment Share on other sites More sharing options...
Master Yoda Posted May 1, 2008 Report Share Posted May 1, 2008 click on this link for more info about your problem http://www.teamshelby.com/forums/index.php?showtopic=25881 Link to comment Share on other sites More sharing options...
old guy Posted May 1, 2008 Author Report Share Posted May 1, 2008 Here ya go young man... If you need specific dementions and the like, let me know and I'll take some measurements for you, but off of the top of my head, I would say the holes are 2.5 inches in diameter. Thanks for the reply. PM sent. Link to comment Share on other sites More sharing options...
old guy Posted May 1, 2008 Author Report Share Posted May 1, 2008 click on this link for more info about your problem http://www.teamshelby.com/forums/index.php?showtopic=25881 Thanks for the link. I had seen that but the car isn't stalling so I wasn't sure that it was the same problem... although it more than likely is with a different symptom at 5,000 ft (Denver) Link to comment Share on other sites More sharing options...
mywickedshelby Posted May 1, 2008 Report Share Posted May 1, 2008 so could the tune be upgraded to handle the extra air and take advantage of it or is the only course of action limiting the air to not upset things as is? Link to comment Share on other sites More sharing options...
old guy Posted May 1, 2008 Author Report Share Posted May 1, 2008 I'd have no problem getting a tune on the car... the problem is that Ford says they won't honor the warranty. if I do Link to comment Share on other sites More sharing options...
Michael Morris Posted May 1, 2008 Report Share Posted May 1, 2008 so could the tune be upgraded to handle the extra air and take advantage of it or is the only course of action limiting the air to not upset things as is? I think the problem with not having the baffle was the air was PUSHING the throttle open and causing the computer to freak out. michael morris Link to comment Share on other sites More sharing options...
old guy Posted May 1, 2008 Author Report Share Posted May 1, 2008 I've continued this discussion in the link that Master Yoda provided above. http://www.teamshelby.com/forums/index.php?showtopic=25881 Link to comment Share on other sites More sharing options...
