computermike Posted March 24, 2008 Report Share Posted March 24, 2008 I have a 2007 shelby GT500. About a month ago I hit a curb driving on ice. Mechanic tells me right rear axle shaft is bent. They say part is unavailable through ford and I have to buy entire assebly. I have seen axle shaft on Ford racing for $140, but not sure if it is for GT500. An assembly is $1600-1800 I want to avoid buying entire new assembly if possible, but as long as I am replacing parts I would like to upgrade. Any ideas or thoughts on what I should do? Thanks, Mike Link to comment Share on other sites More sharing options...
David Hawkins Posted March 24, 2008 Report Share Posted March 24, 2008 Are the Axles different then the Mustang GT? David. Link to comment Share on other sites More sharing options...
Son of GT Posted March 24, 2008 Report Share Posted March 24, 2008 Not 100% certain of the exact spline numbers, but there is a difference. If I recall correctly the MGT has 26 spline axle shafts and the GT500 has 32 spline shafts. GT500 shafts are much beefer/heaver. I believe that the FRPP axle shafts that you mentioned are the same shafts that are installed in the GT500's Link to comment Share on other sites More sharing options...
shel-b001 Posted March 24, 2008 Report Share Posted March 24, 2008 What about all the axles that came out of the G.T Hertz & Shelby G.T they were sold off to some company , should be a few out there. Maybe SAI could help you. Link to comment Share on other sites More sharing options...
mrfarmdog Posted March 24, 2008 Report Share Posted March 24, 2008 Curry 9 inch Link to comment Share on other sites More sharing options...
David Hawkins Posted March 25, 2008 Report Share Posted March 25, 2008 What about all the axles that came out of the G.T Hertz & Shelby G.T they were sold off to some company , should be a few out there. Maybe SAI could help you. Those are Mustang GT Axles and as stated in an above post, will not work. David. Link to comment Share on other sites More sharing options...
SVTpower Posted March 25, 2008 Report Share Posted March 25, 2008 all mustang v8 2005+ axles are 31 spline.......Ford got smarter this time and upped from the old 28 spline. What I would do?? Pull both and now's a good time to order H/D 31 spline axles from companies like Strange Eng. or Marks and Williams and others. My guess $200-$300 each but well worth it. Link to comment Share on other sites More sharing options...
John Strauss Posted March 25, 2008 Report Share Posted March 25, 2008 You can try this site. http://www.newtakeoff.com/index.asp?PageAc...mp;Category=424 Hope it helps. Link to comment Share on other sites More sharing options...
David Hawkins Posted March 25, 2008 Report Share Posted March 25, 2008 Pull both and now's a good time to order H/D 31 spline axles from companies like Strange Eng. or Marks and Williams and others. My guess $200-$300 each but well worth it. Ford should have done this from the Get Go since the cars have 500HP. Will the KR's have the same Axles or will it get beefed up? David. Link to comment Share on other sites More sharing options...
SLGT750 Posted March 25, 2008 Report Share Posted March 25, 2008 all mustang v8 2005+ axles are 31 spline.......Ford got smarter this time and upped from the old 28 spline. What I would do?? Pull both and now's a good time to order H/D 31 spline axles from companies like Strange Eng. or Marks and Williams and others. My guess $200-$300 each but well worth it. +1, also the gt500 axles are hardened 31 spline so there different than Mustang GT 31 spline Link to comment Share on other sites More sharing options...
BADBOY500 Posted March 25, 2008 Report Share Posted March 25, 2008 Curry 9 inch +1......But they will poch me at the car shows....!!!!! F--k-em....My car will live or I will die to make it so..................BB500. Link to comment Share on other sites More sharing options...
SVTpower Posted March 25, 2008 Report Share Posted March 25, 2008 As he wrote, don't think he wants to spend $1600-$1800, let alone more on a 9 inch. Do the axles. Moser is another good company for axles Link to comment Share on other sites More sharing options...
07SHELBY GT Posted March 25, 2008 Report Share Posted March 25, 2008 I think that the Bullitt has the same rear assembly as the 500,Except for the 3:73 gears.There are larger bearings involved somewhere.Go aftermarket,WAYYYYYYYYYY cheaper than Ford parts most likely. Link to comment Share on other sites More sharing options...
red07shelby Posted April 13, 2008 Report Share Posted April 13, 2008 Mike, How did you make out finding an axle? I also have a bent axle and need a new one. Link to comment Share on other sites More sharing options...
ChrisSD Posted December 1, 2009 Report Share Posted December 1, 2009 Bumping an old thread to clear any misinformation. My 2010 GT500 has a bent axle and my dealer has ordered part number 5R3Z4234A for the right rear. This is the *same part* as the GT's get. This is for a 2010, I didn't cross check the older cars. For 2010 at least, there is NO DIFFERENCE in the axle shafts from GT to GT500. I just called SVT ( 1-800-FORD-SVT ) to triple check and they verified it is the same axle shaft as well. Actual differences: Setup specifications High torque Pinion bearing on GT500 Carbon fiber clutchpacks on GT500 Everything else is the same. Link to comment Share on other sites More sharing options...
