Dead Pedal Installation
I am looking for some advise in taking the plastic trim off to install my dead pedal.
I am posting this as a precaution before i go tugging at the sill panel and end up breaking it.
Can anyone tell me if i need to pop the bottom ? or do i need to start at the top and slide the panel toward me to disengauge it?
I know this is probably as simple as it comes, however i do want it to be right and tight as it is now .
Any advice appreciated!!!!
The sill plate pops straight up, the kick panel has a round push-in button clip on the side you need to pull out first, then the panel pulls out toward the rear of the car.
Should i just try to get my fingers under the sill plate and then pull straight up? Or do you recommend using like a flat head screwdriver?
If need be use a putty knife, a screwdriver puts too much pressure at one point and can mess it up.
The first time pulling it off it may be a little tight, but it will come off.
Hold it at 2 points about 6 inches apart and tug up, instead of just tugging on an end. Try to keep the panel flat, not bent.
It should be reasonably easy.
Thanks Snoopy , You Rock man!!
I got it off!! ,apparently all clips are toward the carpet.
there was a piece of two sided tape on each side of panel that touches the paint.
No problem, thanks for your help!! :happy feet: :hysterical:
