dtaylor Posted February 26, 2008 Report Share Posted February 26, 2008 I have 08 with evo stage 2 kit. I have just noticed at under a load I am getting clatter from motor under a load. The rpms are from 1800 to 2000 in 3rd thru 6th. Any ideas anyone? Link to comment Share on other sites More sharing options...
srk1959 Posted February 26, 2008 Report Share Posted February 26, 2008 I have 08 with evo stage 2 kit. I have just noticed at ubder a load I am getting clatter from motor under a load. The rpms are from 1800 to 2000 in 3rd thru 6th. Any ideas anyone? 93 or 91 octane? Also some states like Wi where I am at have winter blend fuel which pings/knocks very easily even though octane is still rated at 93. Link to comment Share on other sites More sharing options...
dtaylor Posted February 27, 2008 Author Report Share Posted February 27, 2008 93 or 91 octane? Also some states like Wi where I am at have winter blend fuel which pings/knocks very easily even though octane is still rated at 93. Im running 93 octane. I am in Tx and weather does't get that cold here. Link to comment Share on other sites More sharing options...
mrfarmdog Posted February 27, 2008 Report Share Posted February 27, 2008 Im running 93 octane. I am in Tx and weather does't get that cold here. You could possibly have a lean condition. One thing I would consider is get a bottle of Torco and add it to your tank to boost up you octane and see if it goes away. Link to comment Share on other sites More sharing options...
dtaylor Posted February 27, 2008 Author Report Share Posted February 27, 2008 You could possibly have a lean condition. One thing I would consider is get a bottle of Torco and add it to your tank to boost up you octane and see if it goes away. I added lucas in fuel but still had problem. Fred at Evo perf told me to send back tuner. I know someone else that has same car and stage 2 kit and his is not having problem . Link to comment Share on other sites More sharing options...
mrfarmdog Posted February 27, 2008 Report Share Posted February 27, 2008 I added lucas in fuel but still had problem. Fred at Evo perf told me to send back tuner. I know someone else that has same car and stage 2 kit and his is not having problem . Then send it back to Fred. They will take care of you. Link to comment Share on other sites More sharing options...
jcthorne Posted February 27, 2008 Report Share Posted February 27, 2008 Fred will fix you up. The Stage 2 tune he sends out works GREAT in most cars. But some are slightly different and require a slighly different timing curve. He will get it right for you. Link to comment Share on other sites More sharing options...
Tucker Posted February 27, 2008 Report Share Posted February 27, 2008 Could be bad fuel as it should not happen. I've not seen it happen yet, but Fred will fix it for you. Jay Link to comment Share on other sites More sharing options...
dtaylor Posted February 29, 2008 Author Report Share Posted February 29, 2008 Could be bad fuel as it should not happen. I've not seen it happen yet, but Fred will fix it for you. Jay I'm sending tuner back to Fred at Evo. I know that he will fix me up. I checked few things on car one of guys at Evo told me to look for and all looks good.. Hell if all else fails put 3in pulley back on put car back to stock and see what happens. Link to comment Share on other sites More sharing options...
2008 Shelby Posted February 29, 2008 Report Share Posted February 29, 2008 You could possibly have a lean condition. One thing I would consider is get a bottle of Torco and add it to your tank to boost up you octane and see if it goes away. TORCO Link to comment Share on other sites More sharing options...
dtaylor Posted March 1, 2008 Author Report Share Posted March 1, 2008 TORCO I checked the plugs and they dont look like they would if the car was running lean. If running lean you would think plugs would be white. As far as bad gas goes I've filled up at 3 difrent stations still pinging. I work with guy that has same car and setup and he is running great. I'm sure tweeking tune will take car of it. Link to comment Share on other sites More sharing options...
