SGT2666 Posted February 25, 2008 Report Share Posted February 25, 2008 I'm thinking I'm going to do my trunk with dynamat, I'm just wondering if anyone has done it already and if so what you thought of the result. Link to comment Share on other sites More sharing options...
ingram4868 Posted February 25, 2008 Report Share Posted February 25, 2008 I've been thinking of doing the same thing but was going to include the rear seating area. Link to comment Share on other sites More sharing options...
SGT2666 Posted February 25, 2008 Author Report Share Posted February 25, 2008 I've been thinking of doing the same thing but was going to include the rear seating area. Great minds think alike I was thinking I would do the back seat also. The specs on this stuff look really good but I'd like to hear from someone who has done it. Link to comment Share on other sites More sharing options...
greaser Posted March 1, 2008 Report Share Posted March 1, 2008 whats youre reason for doing it? it will add a lot of weight to the car so it will be a hinderance on track day but other than that it is a great product. i have used it in many cars and trucks its easy to use and stops vibrations/quiets down the interior a lot. Link to comment Share on other sites More sharing options...
ingram4868 Posted March 1, 2008 Report Share Posted March 1, 2008 I don't care about the weight factor. I drove down the road the other day and the sand from the snowplow vehicles was bouncing up under the car and the sound was almost painful. The sheet metal is so thin you can hear every grain bounce off the underside of the car. Link to comment Share on other sites More sharing options...
SGT2666 Posted March 1, 2008 Author Report Share Posted March 1, 2008 They claim their new extreme is half as heavy and twice as effective, but I don't really know what kind of weight we're talking about. Link to comment Share on other sites More sharing options...
greaser Posted March 1, 2008 Report Share Posted March 1, 2008 I don't care about the weight factor. I drove down the road the other day and the sand from the snowplow vehicles was bouncing up under the car and the sound was almost painful. The sheet metal is so thin you can hear every grain bounce off the underside of the car. i should be painfull thats gods way of telling you to put the car away and buy a winter beater but in all reality it will cut out most if not all noise from where you apply it. Link to comment Share on other sites More sharing options...
greaser Posted March 1, 2008 Report Share Posted March 1, 2008 They claim their new extreme is half as heavy and twice as effective, but I don't really know what kind of weight we're talking about. its still 1/2 a pound per square foot. this stuff is much lighter and they say works better worth a look anyways. http://www.b-quiet.com/compare.html Link to comment Share on other sites More sharing options...
SGT2666 Posted March 1, 2008 Author Report Share Posted March 1, 2008 its still 1/2 a pound per square foot. this stuff is much lighter and they say works better worth a look anyways.http://www.b-quiet.com/compare.html Good info thanks ! Link to comment Share on other sites More sharing options...
willyumm930 Posted March 2, 2008 Report Share Posted March 2, 2008 whats youre reason for doing it? it will add a lot of weight to the car so it will be a hinderance on track day but other than that it is a great product. i have used it in many cars and trucks its easy to use and stops vibrations/quiets down the interior a lot. You are correct about the weight. If you are only going to add a little to your trunk, you should be ok. I was heavy into car audio competitions some years back and it was necessary to use this stuff everywhere. And like it was said earlier, it added more weight than I wanted. This may sound really stupid, but if you use a lot of it, you have to approach it in a manner so you won't throw off the balance of the car. If you use 6lbs on one side, make sure you use 6lbs on the other. I've seen people just cut squares of this stuff and not be aware of how much they used. Link to comment Share on other sites More sharing options...
ingram4868 Posted March 2, 2008 Report Share Posted March 2, 2008 You are correct about the weight. If you are only going to add a little to your trunk, you should be ok. I was heavy into car audio competitions some years back and it was necessary to use this stuff everywhere. And like it was said earlier, it added more weight than I wanted. This may sound really stupid, but if you use a lot of it, you have to approach it in a manner so you won't throw off the balance of the car. If you use 6lbs on one side, make sure you use 6lbs on the other. I've seen people just cut squares of this stuff and not be aware of how much they used. That sounds like a good idea. I'll keep track of how much weight I actually add to cover the surfaces. Link to comment Share on other sites More sharing options...
SGT2666 Posted March 2, 2008 Author Report Share Posted March 2, 2008 You are correct about the weight. If you are only going to add a little to your trunk, you should be ok. I was heavy into car audio competitions some years back and it was necessary to use this stuff everywhere. And like it was said earlier, it added more weight than I wanted. This may sound really stupid, but if you use a lot of it, you have to approach it in a manner so you won't throw off the balance of the car. If you use 6lbs on one side, make sure you use 6lbs on the other. I've seen people just cut squares of this stuff and not be aware of how much they used. So is the effect of this stuff pretty extreme on the cars sound levels? Would doing the trunk area yeild results that are worth the effort I guess is what I'm asking, the package I've been looking at is 36 square feet so somewhere less then 15 pounds of weight. Link to comment Share on other sites More sharing options...
greaser Posted March 2, 2008 Report Share Posted March 2, 2008 just to quiet down the outside noise one layer will be plenty. do the trunk and if it still seems to loud pull the rear seats and do them. Link to comment Share on other sites More sharing options...
ilmor Posted March 2, 2008 Report Share Posted March 2, 2008 I hope you don't mask off the wonderful exhaust music!!! Link to comment Share on other sites More sharing options...
willyumm930 Posted March 3, 2008 Report Share Posted March 3, 2008 So is the effect of this stuff pretty extreme on the cars sound levels? Would doing the trunk area yeild results that are worth the effort I guess is what I'm asking, the package I've been looking at is 36 square feet so somewhere less then 15 pounds of weight. It's going to work well in your trunk. You don't have to use much to get the results you want. You may not need 15 pounds, but I really can't say for sure. My SGT isn't noisy to me and I think I'm pretty sensitive. With the power that we have, 15 pounds won't make a big difference. Please let me know when you complete the install. Link to comment Share on other sites More sharing options...
