69dejavue Posted February 3, 2008 Report Share Posted February 3, 2008 Has anyone installed the Shelby GT Plus Brake System on the front and will it fit the stock 18" wheels? The catalog states certain spoke designs may not allow enough clearance for the oversize calipers. Link to comment Share on other sites More sharing options...
ShelbyPilot Posted February 3, 2008 Report Share Posted February 3, 2008 Call Shelby Performance Parts and ask for Keith. They test fitted several different wheel combinations with the different brake packages. He will tell you what will fit. Link to comment Share on other sites More sharing options...
clark17357 Posted February 3, 2008 Report Share Posted February 3, 2008 Has anyone installed the Shelby GT Plus Brake System on the front and will it fit the stock 18" wheels? The catalog states certain spoke designs may not allow enough clearance for the oversize calipers. That system will not fit our stock wheels. If you search, you will find a fair number of threads that discuss this issue. Presently, the only alternative you have with the stock SGT wheels is to upgrade your rotors to slotted and cross drilled, upgrade your brake pads to Hawk and upgrade your brake lines to stainless steel. Jim Link to comment Share on other sites More sharing options...
chigl Posted February 3, 2008 Report Share Posted February 3, 2008 Call Shelby Performance Parts and ask for Keith. They test fitted several different wheel combinations with the different brake packages. He will tell you what will fit. Hi, I had the same question so I called Keith at Shelby Performance Parts. As stated in the previous post, the GT+ Baer kit will not fit the stock wheels. If you add the GT+ kit, only 2 wheels will fit from the Mod Shop - The Razors and the GT500 wheel. Two additional wheels will fit if you order from Shelby Performance Parts - the Type S1 and the Alcoa Aluminum forged wheel. These last two wheels CANNOT be added at the mod shop. Best of luck in your decision. Link to comment Share on other sites More sharing options...
ShelbyPilot Posted February 3, 2008 Report Share Posted February 3, 2008 Hi, I had the same question so I called Keith at Shelby Performance Parts. As stated in the previous post, the GT+ Baer kit will not fit the stock wheels. If you add the GT+ kit, only 2 wheels will fit from the Mod Shop - The Razors and the GT500 wheel. Two additional wheels will fit if you order from Shelby Performance Parts - the Type S1 and the Alcoa Aluminum forged wheel. These last two wheels CANNOT be added at the mod shop. Best of luck in your decision. Please clarify for those interested. Are those all 18" diameters of the Razor, S1 and Alcoa? Link to comment Share on other sites More sharing options...
chigl Posted February 4, 2008 Report Share Posted February 4, 2008 Please clarify for those interested. Are those all 18" diameters of the Razor, S1 and Alcoa? For the GT+ upgrade, all 4 wheel options (razor, gt500, S1, Alcoa) are 20". The GT+ will not fit on the stock 18" wheel. Link to comment Share on other sites More sharing options...
69dejavue Posted February 4, 2008 Author Report Share Posted February 4, 2008 The SPP catalog mentioned the GT Plus brakes would fit some 18" wheels but to call for templates. That is why I was hoping it would fit our stock wheels. Would make sense to design the kit to fit the stock wheel. A lot of people would probably like to upgrade the brakes without having to buy new wheels and tires also. Link to comment Share on other sites More sharing options...
twobjshelbys Posted February 4, 2008 Report Share Posted February 4, 2008 I just went through this exercise last week and Bud says the only 18" wheels that work with these brakes are the GT500 wheels. No GT wheels. Link to comment Share on other sites More sharing options...
SGT2666 Posted February 4, 2008 Report Share Posted February 4, 2008 Baer has templates on their site template. Link to comment Share on other sites More sharing options...
et10sec Posted February 4, 2008 Report Share Posted February 4, 2008 Baer has templates on their site template. Do the hertz 2006 cars have the same brakes as the gt mustang? looking to buy rotors and pad at the local parts store? Link to comment Share on other sites More sharing options...
SGT2666 Posted February 4, 2008 Report Share Posted February 4, 2008 Do the hertz 2006 cars have the same brakes as the gt mustang? looking to buy rotors and pad at the local parts store? Yes they are stock mustang GT brakes. Link to comment Share on other sites More sharing options...
69dejavue Posted February 5, 2008 Author Report Share Posted February 5, 2008 Jim, where did you buy your cross drilled rotors and pads? Link to comment Share on other sites More sharing options...
07SGT1638 Posted February 5, 2008 Report Share Posted February 5, 2008 Per Kenny at SPP, I just confirmed about what everybody else is saying.... If you want the Baer GT plus brake system, in 18" the GT500 wheels will fit, and the new SPP S1 wheel. Anything other than those 2 wheels or something matching their specs, you are into 20". From where I sit, this is good. I'd planned on GT500 wheels anyway and was just about decided to go with the GT500 brakes for my SGT. Knowing the above, it will be the GT plus system F&R instead. No if I can only quit reading this forum (those Steeda/ Ford OEM Xenon lights just jumped out at me too)... Todd 07SGT1638 Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted February 29, 2008 Report Share Posted February 29, 2008 To swap out front and rear rotors, what tools are needed? How difficult is it to do the rear with the E-brake adjustmnet? I will be changing pads also. Plan is to install OEM I rotors that are drilled and slotted. Thanks for any input. Link to comment Share on other sites More sharing options...
ShelbyPilot Posted February 29, 2008 Report Share Posted February 29, 2008 To swap out front and rear rotors, what tools are needed? How difficult is it to do the rear with the E-brake adjustmnet? I will be changing pads also. Plan is to install OEM I rotors that are drilled and slotted. Thanks for any input. My neighbor and I swapped out the stock brakes for the Baer GT Plus package. It took us about 3 hours. We could have done it faster but we were having fun doing one wheel at a time. Bleeding the brakes was the hardest part. The only special tool we used was his air wrench for convience. However, the brake package upgrade doesn't require changing the pads. You resuse the rear caliper and the front calipers come with the pads installed from the factory. Link to comment Share on other sites More sharing options...
RogerS Posted March 1, 2008 Report Share Posted March 1, 2008 To swap out front and rear rotors, what tools are needed? How difficult is it to do the rear with the E-brake adjustmnet? I will be changing pads also. Plan is to install OEM I rotors that are drilled and slotted. Thanks for any input. For a simple rotor and pad install, no special tools required. No issue with the e-brake either. Should be straight forward. Link to comment Share on other sites More sharing options...
RStangsOC Posted March 1, 2008 Report Share Posted March 1, 2008 To swap out front and rear rotors, what tools are needed? How difficult is it to do the rear with the E-brake adjustmnet? I will be changing pads also. Plan is to install OEM I rotors that are drilled and slotted. Thanks for any input. Hey there, Just an FYI - Lethal Performance, Evolution Performance and JLT all sell excellent cross-drilled, cross-drilled/slotted or just slotted rotors also (Stillen of course) Page Link to comment Share on other sites More sharing options...
willyumm930 Posted March 2, 2008 Report Share Posted March 2, 2008 Hey there, Just an FYI - Lethal Performance, Evolution Performance and JLT all sell excellent cross-drilled, cross-drilled/slotted or just slotted rotors also (Stillen of course) Page Shameless plug. Link to comment Share on other sites More sharing options...
SGT2666 Posted March 2, 2008 Report Share Posted March 2, 2008 Shameless plug. LOL every chance he gets Link to comment Share on other sites More sharing options...
robsdad3423 Posted March 13, 2008 Report Share Posted March 13, 2008 Here the response that I recieved from Shelby on this very topic. Rich, With larger brakes it is very difficult to find a wheel that will fit in the 18" size. I have attached a little chart to show you which wheels fit with which brakes. In addition to the wheels in that chart, the Shelby Type S1 wheel by American racing will also accept the larger brake packages. I have attached pictures of those wheels for you to see. If you have any further questions please let me know Thanks!! Wheel GT + 14" (Baer), Extreme + 14" (Baer), Extreme Plus 15.0 (Baer) G040P N045P N045U CS40 20x9.0 Fits Fits Fits CS56 18x9.5 Fits Fits No CS66 18x8.5 No No No CS66 20x9.0 Fits Fits Fits CS67 17x8.5 No No No 18x8.5 No No No 20x9.0 No No No Kenny Gorham Customer Service/Sales Shelby Performance Parts Phone (702) 853-2068 Fax (702) 853-2069 -------------------------------------------------------------------------------- From: Randi Denton Sent: Monday, March 10, 2008 7:39 AM To: Kenny Gorham Subject: FW: Wheel and Brake combination Kind Regards, Randi Denton Shelby Performance Parts -------------------------------------------------------------------------------- From: Rich Sent: Friday, March 07, 2008 11:29 PM To: Info - Shelby Subject: Wheel and Brake combination Will the Baer Extreme Plus system fit with the 18 inch CS67 rims Part # CS67-885442-C ? Living in Chicago means you are always just a pot hole away from throwing away a beautiful wheel if you go larger than 18 inches. Thanks for your time. Rich Hi, I had the same question so I called Keith at Shelby Performance Parts. As stated in the previous post, the GT+ Baer kit will not fit the stock wheels. If you add the GT+ kit, only 2 wheels will fit from the Mod Shop - The Razors and the GT500 wheel. Two additional wheels will fit if you order from Shelby Performance Parts - the Type S1 and the Alcoa Aluminum forged wheel. These last two wheels CANNOT be added at the mod shop. Best of luck in your decision. Link to comment Share on other sites More sharing options...
