1FAFP90 Posted February 2, 2008 Report Share Posted February 2, 2008 I'm trying to save all the original stickers that were on the car -- how do you remove (without damaging) the paper ones like the "loose items" and the big barcode sticker ? Thanks. Link to comment Share on other sites More sharing options...
DutchGT500 Posted February 2, 2008 Report Share Posted February 2, 2008 Mine came of fairly easy. Just pull gently. After that stick them on decal paper so save them. Next step, scan them for digitalization. That way you can print them out or have others made as spare. Link to comment Share on other sites More sharing options...
1FAFP90 Posted February 2, 2008 Author Report Share Posted February 2, 2008 Mine came of fairly easy. Just pull gently. After that stick them on decal paper so save them. Next step, scan them for digitalization. That way you can print them out or have others made as spare. The window sticker (price) and Country of origin stickers came off real easy. I've got them protected on decal paper. It's the other stickers (loose items / barcode ) that appear to be a bear to remove, at least on my car Link to comment Share on other sites More sharing options...
shel-b001 Posted February 2, 2008 Report Share Posted February 2, 2008 I'm trying to save all the original stickers that were on the car -- how do you remove (without damaging) the paper ones like the "loose items" and the big barcode sticker ?Thanks. The main sticker can be printed out by your dealer & comes with the paper backing on it Link to comment Share on other sites More sharing options...
nilkilla Posted February 2, 2008 Report Share Posted February 2, 2008 here at the dealer, we use razor blades. if you are gentle enough you can get them off cleanly. More than one order unit came in with requests to preserve EVERYTHING. so I have delivered GT500s with all the plastic/bubble wrap and every sticker imaginable, intact, in their trunk. Link to comment Share on other sites More sharing options...
greensalesco Posted February 3, 2008 Report Share Posted February 3, 2008 Would a hair dryer make things easier. That's what I use to remove decals. Bruce Link to comment Share on other sites More sharing options...
COILED1 GT500 Posted February 3, 2008 Report Share Posted February 3, 2008 ------ Link to comment Share on other sites More sharing options...
1badsho Posted February 3, 2008 Report Share Posted February 3, 2008 ------ 11111 Link to comment Share on other sites More sharing options...
1FAFP90 Posted February 3, 2008 Author Report Share Posted February 3, 2008 Thanks for all of your good ideas and help it is mission accomplished I got them all off, however two needed to be started with the razor blade and then pulled by hand. Strangely enough, the loose item label ink powderized while it was being removed. So, it is only about half as dark as it was prior to removal. Link to comment Share on other sites More sharing options...
