1965coupe Posted December 14, 2007 Report Share Posted December 14, 2007 Well, the pictures are over at stangnet.. sorry.. I can't make the same post three times- too much work on a laptop.. CLICK HERE!!! Enjoy! Any questions, email me: Mustangparts65@msn.com. Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted December 15, 2007 Report Share Posted December 15, 2007 I have the same unit. I love the ipod interface. Much better than stock!!! Link to comment Share on other sites More sharing options...
pottydr_merged Posted December 15, 2007 Report Share Posted December 15, 2007 I also have the same unit, I took out the shaker 1000, they make a plug so you can use the amp in the trunk, works very well. Link to comment Share on other sites More sharing options...
1965coupe Posted December 15, 2007 Author Report Share Posted December 15, 2007 I also have the same unit, I took out the shaker 1000, they make a plug so you can use the amp in the trunk, works very well. That's what I did- connected the AVIC to the in-dash harness that connects to the Shaker system. However, you must install a voltage regulator in line of the amp turn-on wire. Otherwise, you'll get a pop every time the system turns on. Link to comment Share on other sites More sharing options...
stump_breaker Posted December 15, 2007 Report Share Posted December 15, 2007 That's what I did- connected the AVIC to the in-dash harness that connects to the Shaker system. However, you must install a voltage regulator in line of the amp turn-on wire. Otherwise, you'll get a pop every time the system turns on. Excellent job. One thing though, can the Ipod interface hole be cleaned up with a grommet or something? Link to comment Share on other sites More sharing options...
pottydr_merged Posted December 15, 2007 Report Share Posted December 15, 2007 That's what I did- connected the AVIC to the in-dash harness that connects to the Shaker system. However, you must install a voltage regulator in line of the amp turn-on wire. Otherwise, you'll get a pop every time the system turns on. Did you get the adapter, just put it in the consol and control thur the radio? Link to comment Share on other sites More sharing options...
amyb Posted December 15, 2007 Report Share Posted December 15, 2007 Nice, really nice!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
1965coupe Posted December 15, 2007 Author Report Share Posted December 15, 2007 Excellent job. One thing though, can the Ipod interface hole be cleaned up with a grommet or something? That's what I am hoping.. I misjudged the size of the cable and made the hole too large.. I'm going to look into some kind of grommet.. The local ACE has all kinds of oddball hardware like that.. Did you get the adapter, just put it in the consol and control thur the radio? With the AVIC-D3, there is no adapter required. All it takes is a Pioneer iPod cable for aout $30, depending on where you shop. Basically, you connect the cable to the iPod and control everything through the headunit. Did you get the adapter, just put it in the consol and control thur the radio? Thank you! Link to comment Share on other sites More sharing options...
goakley1 Posted December 16, 2007 Report Share Posted December 16, 2007 Great job!!! Gary Link to comment Share on other sites More sharing options...
