IASHELBYGT Posted November 26, 2007 Report Share Posted November 26, 2007 In my efforts to keep my SGT engine bay show room clean I have noticed after driving on two different occasions what looks to be oil residue on the top of the driver's side fuel rail. Upon further examination and smell, it smells like gas but has an oily texture. Anyone out there have this happen and any idea where it is coming from? I'd like to give an informed opinion to my Ford mechanic. Thanks, Dave Link to comment Share on other sites More sharing options...
stump_breaker Posted November 26, 2007 Report Share Posted November 26, 2007 In my efforts to keep my SGT engine bay show room clean I have noticed after driving on two different occasions what looks to be oil residue on the top of the driver's side fuel rail. Upon further examination and smell, it smells like gas but has an oily texture. Anyone out there have this happen and any idea where it is coming from? I'd like to give an informed opinion to my Ford mechanic. Thanks, Dave You mentioned keeping your SGT showroom clean. Do you use an engine cleaner which is oily for the shine? This could be why the gas feels oily. I would check the "o" rings. Barring a broke line which would be obvious, this is the most reasonable route. An AC leak might leave an oily residue but would not smell like gas. Link to comment Share on other sites More sharing options...
autoplay Posted November 26, 2007 Report Share Posted November 26, 2007 No clue other than in your sig,you mention having installed gauge package from SAI. Possibly there's a leak coming from 1 of the fittings/lines? Could be a number of things. If you suspect it being Fuel related,drive little as possible! Have your dealer troubleshoot it,after all,part of the price you paid is the warranty Link to comment Share on other sites More sharing options...
IASHELBYGT Posted November 26, 2007 Author Report Share Posted November 26, 2007 No clue other than in your sig,you mention having installed gauge package from SAI. Possibly there's a leak coming from 1 of the fittings/lines? Could be a number of things. If you suspect it being Fuel related,drive little as possible! Have your dealer troubleshoot it,after all,part of the price you paid is the warranty Thanks for the thoughts. I thought O Ring or a fitting from the fuel pressure gauge but am not sure where it connects. Anybody know? John or Bud can you chime in? Dave Link to comment Share on other sites More sharing options...
Budman340 Posted November 26, 2007 Report Share Posted November 26, 2007 Thanks for the thoughts. I thought O Ring or a fitting from the fuel pressure gauge but am not sure where it connects. Anybody know? John or Bud can you chime in? Dave Hi Dave, On the left side (drivers side) of the engine---on top, you will see the fuel pressure sensor. There should be a line that comes off it and then it "T's" off. Check the sensor on top to make sure that it is not leaking. See picture and look for the red arrow. Make sure it is not leaking in that area. If it is, the o-ring may need to be replaced. Bud Link to comment Share on other sites More sharing options...
IASHELBYGT Posted November 26, 2007 Author Report Share Posted November 26, 2007 Hi Dave, On the left side (drivers side) of the engine---on top, you will see the fuel pressure sensor. There should be a line that comes off it and then it "T's" off. Check the sensor on top to make sure that it is not leaking. See picture and look for the red arrow. Make sure it is not leaking in that area. If it is, the o-ring may need to be replaced. Bud Thanks Bud, It's hard to tell but it seems that's where the fluid may be coming from. Thanks for the help to include the nice picture. I'll share with my mechanic. Dave Link to comment Share on other sites More sharing options...
Strawman Posted November 27, 2007 Report Share Posted November 27, 2007 Way to stay on top of things, Bud, nice job. Man, that Paxton sure is pretty. Link to comment Share on other sites More sharing options...
