trackeer Posted November 9, 2007 Report Share Posted November 9, 2007 I thought I should comment on the repair of my Hood Scoop, First the repair is almost perfect, the multitude of rivits solved the problem and the scoop sits on the hood like it is almost part of the hood. In total amazement my dealer managed to make the repair after a call to Shelby with concerns and all is as it should be. Thanks to both Londonderry Ford Auto Body and Shelby for a Job well done. I felt a Hardy well done is in order so the Folks at Shelby don't think us Adult Males only like to B&M. Thanks Moe in NH Link to comment Share on other sites More sharing options...
Reino Posted November 9, 2007 Report Share Posted November 9, 2007 I felt a Hardy well done is in order so the Folks at Shelby don't think us Adult Males only like to B&M. They put in more rivits then there were before? Its not fun unless we B&M. Link to comment Share on other sites More sharing options...
VEGASTY Posted November 9, 2007 Report Share Posted November 9, 2007 talked to my dealer today about the 2nd replacement scoop, been waiting 2 months now, he said all the replacement scoops here out from shelby will be 2008 model scoops and they will need to be bolted on,so holes will be drilled in hood. any thoughts/comments on this, will it ruin the integrity of being an true 07's with these holes. problem is one on it now looks like crap with ripples and chip/crack, as well as sits more than 1/4" up from hood. Link to comment Share on other sites More sharing options...
07SHELBY GT Posted November 9, 2007 Report Share Posted November 9, 2007 I guess if you want it to look good.................I figured there had to be something to the 08' scoop,Because the one I saw on a Vista Blue car was perfect! Link to comment Share on other sites More sharing options...
SGT3369 Posted November 9, 2007 Report Share Posted November 9, 2007 talked to my dealer today about the 2nd replacement scoop, been waiting 2 months now, he said all the replacement scoops here out from shelby will be 2008 model scoops and they will need to be bolted on,so holes will be drilled in hood. any thoughts/comments on this, will it ruin the integrity of being an true 07's with these holes. problem is one on it now looks like crap with ripples and chip/crack, as well as sits more than 1/4" up from hood. What is your CSM? Mine is 3369 (obviously) and is bolted through bottom-2 front hex bolts are full length. Original is not bad. talked to my dealer today about the 2nd replacement scoop, been waiting 2 months now, he said all the replacement scoops here out from shelby will be 2008 model scoops and they will need to be bolted on,so holes will be drilled in hood. any thoughts/comments on this, will it ruin the integrity of being an true 07's with these holes. problem is one on it now looks like crap with ripples and chip/crack, as well as sits more than 1/4" up from hood. See you are 373-SAI changed to the bolts on later '07s-no integrity concern there. Link to comment Share on other sites More sharing options...
stormeaston Posted November 9, 2007 Report Share Posted November 9, 2007 What is your CSM? Mine is 3369 (obviously) and is bolted through bottom-2 front hex bolts are full length. Original is not bad. See you are 373-SAI changed to the bolts on later '07s-no integrity concern there. Mine is #3133 and also is held on with four hex bolts, no issues here. Link to comment Share on other sites More sharing options...
mywickedshelby Posted November 9, 2007 Report Share Posted November 9, 2007 I guess if you want it to look good.................I figured there had to be something to the 08' scoop,Because the one I saw on a Vista Blue car was perfect! they all look perfect when they are new. only time will tell if this actually works. Link to comment Share on other sites More sharing options...
VEGASTY Posted November 9, 2007 Report Share Posted November 9, 2007 Mine is #3133 and also is held on with four hex bolts, no issues here. cool, thanks i did not know they had switched to bolts on later csm numbers, Link to comment Share on other sites More sharing options...
Webba Posted November 9, 2007 Report Share Posted November 9, 2007 One of the other fixes involved adding bolts. The originals were bolted on in like 4 places. So when they added they had maybe 6 or 8 bolts. The rivot is the latest and best done fix to date. Link to comment Share on other sites More sharing options...
mywickedshelby Posted November 9, 2007 Report Share Posted November 9, 2007 I think the extra bolts were an interim fix before the rivits, but there were problems with that as well. Besides drilling the hood being undesirable. Link to comment Share on other sites More sharing options...
trackeer Posted November 9, 2007 Author Report Share Posted November 9, 2007 Hey Guys and Gals, The new Scoop is all Rivits and it appears the bolts are also re-used, I did not study the repair in detail other than to confirm the Scoop now sits flat on the Hood "I will look closer and report along with some pics". I know my original Scoop was flawed and had Gaps on both sides and the rear, the second Scoop was worse as all the sides now had Major Gaps. So, unless the Heat of summer has some effect, as the car is to be garaged all winter then I hope I'm done fixing the hood. My CSN 2674, I am hoping to send the Car down to Taska and have the Super Charger, Brake Kit, and New Wheels installed at some point before it starts snowing here in New Hampshire. Yes, I agree B&M'ing does bring some satisfaction, but when someone does a good job we also need to let them know they did, else they'll quit listening to our B&M'ing. Moe in NH..... Link to comment Share on other sites More sharing options...
66DNA Posted November 18, 2007 Report Share Posted November 18, 2007 SAI promises Hood Scoop resolution. Watch for something by December 3rd, 2007!!!!! SAI promises Hood Scoop resolution. Watch for something by December 3rd, 2007!!!!! SAI promises Hood Scoop resolution. Watch for something by December 3rd, 2007!!!!! Link to comment Share on other sites More sharing options...
fatboy_merged Posted November 18, 2007 Report Share Posted November 18, 2007 my 07 Shelby #1381 looks like its held with 4 bolts looks ok here's pics yes i know...it needed a bath <_< Link to comment Share on other sites More sharing options...
MattInDetroit Posted November 18, 2007 Report Share Posted November 18, 2007 Scoops History 101 Early scoops 0001-2XXX (approx) had four bolts, two on either side. They may also have the back middle screw, not sure though. Mid-Year scoops 21XX-51XX (approx) in addition to the four bolts had actual screws fitted in the front faux screw position on either side and the middle back in response to issues of lifting at the front corners and in the back. End of year scoops 51XX-59XX (approx) used the same four bolts but replaced all the (round head) faux screws with flat head rivets. This is also the technique used on the 08 and for scoops needing repair. Hope this helps and everyone please feel free to make corrections. Link to comment Share on other sites More sharing options...
sdear Posted November 18, 2007 Report Share Posted November 18, 2007 #545 has a back middle screw......and a front screw on both sides of the scoop...bought that way. Link to comment Share on other sites More sharing options...
MattInDetroit Posted November 19, 2007 Report Share Posted November 19, 2007 #545 has a back middle screw......and a front screw on both sides of the scoop...bought that way. Thanks Sue! Good info! Guess I misread a post so many moons ago! I had #33 next to me at a car show and it didn't have the two screws in the front. But I thought I remembered this was a change in, maybe Jan/Feb but guess I was wrong! Congrats again on the win! Link to comment Share on other sites More sharing options...
ilmor Posted November 19, 2007 Report Share Posted November 19, 2007 #1917 also appears to have 2 screws front, 1 screw rear-center and 4 bolts. Link to comment Share on other sites More sharing options...
bigcarl1 Posted November 19, 2007 Report Share Posted November 19, 2007 #1917 also appears to have 2 screws front, 1 screw rear-center and 4 bolts. #0220 four bolts only Link to comment Share on other sites More sharing options...
