trooper530 Posted September 25, 2007 Report Share Posted September 25, 2007 hello all. i was wondering what rim off set and tire size is used on the cs6 razors. looking to place my order tommorow but need the correct fit. want the same look as the vista blue photos. thanks. Link to comment Share on other sites More sharing options...
GPStang06_merged Posted September 26, 2007 Report Share Posted September 26, 2007 hello all. i was wondering what rim off set and tire size is used on the cs6 razors. looking to place my order tommorow but need the correct fit. want the same look as the vista blue photos. thanks. Not sure what tires they used on the blue prototype Trooper but the rim offset on those are the 24mm offset on all 4. I think in some of the older posts from last year may be the answer on the tire size but I don't recall if it was ever identified. Link to comment Share on other sites More sharing options...
Paleoc Posted September 26, 2007 Report Share Posted September 26, 2007 Not sure what tires they used on the blue prototype Trooper but the rim offset on those are the 24mm offset on all 4. I think in some of the older posts from last year may be the answer on the tire size but I don't recall if it was ever identified. The Blue prototype has 255/35ZR20 as does my car. The widest recommended tires are 275 (on a 9inch wide rim). Link to comment Share on other sites More sharing options...
