shelbydream1 Posted September 15, 2007 Report Share Posted September 15, 2007 Those of you with upgraded wheels-what brand tires are you running and what do you think of them?? Are all of the stock SGT wheels running the BFG tires? Link to comment Share on other sites More sharing options...
Dread Posted September 15, 2007 Report Share Posted September 15, 2007 Are all of the stock SGT wheels running the BFG tires? I'm gonna wait till Spring ta upgrade ta chrome razor 198S..........but right now...stock..I have the BFG G/Force Link to comment Share on other sites More sharing options...
RogerS Posted September 15, 2007 Report Share Posted September 15, 2007 Dream, I have 20" Carroll Shelby CS69 wheels 9" front and 10's in the rear and went with BFG CompTA/KDW's. Ran them on my 95R and loved them. My car is not here yet but I do expect it by next month's end. I will give you my impression when I get a little seat time. But if past results hold true I will have a good ride quality with little road noise and very good dry grip. Due to the 20" size little sidewall roll is expected due to the reinforcement to the side walls. So it should be a very good all around tire even in the wet. Link to comment Share on other sites More sharing options...
robsdad3423 Posted September 25, 2007 Report Share Posted September 25, 2007 Dream, I have 20" Carroll Shelby CS69 wheels 9" front and 10's in the rear and went with BFG CompTA/KDW's. Ran them on my 95R and loved them. My car is not here yet but I do expect it by next month's end. I will give you my impression when I get a little seat time. But if past results hold true I will have a good ride quality with little road noise and very good dry grip. Due to the 20" size little sidewall roll is expected due to the reinforcement to the side walls. So it should be a very good all around tire even in the wet. I have been considering CS67 shelby18 x 9.5 inch rims. anyone know how wide I can go with the tires? Any help would be apprciated. Thanks, Wood. Link to comment Share on other sites More sharing options...
RogerS Posted September 25, 2007 Report Share Posted September 25, 2007 I have been considering CS67 shelby18 x 9.5 inch rims. anyone know how wide I can go with the tires? Any help would be apprciated. Thanks, Wood. When I put my CS69's on I went with the recommended tire size. Shelby Wheels recommends 285-40ZR-18 for the 9.5" width. Hope that helps. Link to comment Share on other sites More sharing options...
robsdad3423 Posted September 26, 2007 Report Share Posted September 26, 2007 When I put my CS69's on I went with the recommended tire size. Shelby Wheels recommends 285-40ZR-18 for the 9.5" width. Hope that helps. Thanks Big help.... next question do the rub When I put my CS69's on I went with the recommended tire size. Shelby Wheels recommends 285-40ZR-18 for the 9.5" width. Hope that helps. Thanks Big help.... next question do they rub Link to comment Share on other sites More sharing options...
RogerS Posted September 26, 2007 Report Share Posted September 26, 2007 Thanks Big help.... next question do the rub Thanks Big help.... next question do they rub No they are fine. I'm sure the people at Shelby Wheels did quite a bit of R&D before making their recommendation. But they do have a disclaimer * The recommended tire sizes on this page are recommendations only as tire sizes vary by manufacturer. Consult your local tire expert. 2007 Requires Tire Pressure Monitor System (TPMS) Check with your local Ford dealer regarding proper use and installation of TPMS Carroll Shelby Wheels are designed to use OE Ford TPMS and OE Ford Mustang lug nuts. I know for a fact that tire mfgs. profiles in width vary. Certain similar tire sizes run wider than others. BFG's run wider than Nitto's. I would call the company and check to be sure. 888-375-3716 or e-mail info@carrollshelbywheels.com Link to comment Share on other sites More sharing options...
