bruces Posted August 26, 2007 Report Share Posted August 26, 2007 After sitting for a week or a couple hours upon start the car blows blue smoke should there be an oil separater,car has 200 miles on it. Any ideas? other blogs say no problem dealer says needs to break in 1200 miles. Link to comment Share on other sites More sharing options...
mffarrell Posted August 27, 2007 Report Share Posted August 27, 2007 After sitting for a week or a couple hours upon start the car blows blue smoke should there be an oil separater,car has 200 miles on it. Any ideas? other blogs say no problem dealer says needs to break in 1200 miles. Could be valve guides or seals. Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted August 27, 2007 Report Share Posted August 27, 2007 I have found this to be normal on both our 05 GT's. Mine has 15,000 on it and my sons has about 33,000. He was concerned, took to dealer, stated was normal on start-up after car had sit for awhile. GG Link to comment Share on other sites More sharing options...
SHELBY0264 Posted August 27, 2007 Report Share Posted August 27, 2007 I have found this to be normal on both our 05 GT's. Mine has 15,000 on it and my sons has about 33,000. He was concerned, took to dealer, stated was normal on start-up after car had sit for awhile. GG my shelby did it for the first 600 miles,but it is fine now. Link to comment Share on other sites More sharing options...
lonnyreed Posted August 27, 2007 Report Share Posted August 27, 2007 Mine did the same, went away after about 1500 miles. Link to comment Share on other sites More sharing options...
blueshawk Posted August 27, 2007 Report Share Posted August 27, 2007 Mine did the same, went away after about 1500 miles. Mine did it once but hasn't since and I'm now at 1650 miles. I thought that it was because I started it when it was cold, then immediately turned it off and then started it about an hour later and saw the blue smoke. Link to comment Share on other sites More sharing options...
stump_breaker Posted August 27, 2007 Report Share Posted August 27, 2007 Mine smoked when it was newer. It only does it on ocassion now - if the car has not beet driven in awhile. Probably just a little oil seeping past the valves and burning on start up. It's nothing bad. Link to comment Share on other sites More sharing options...
MattInDetroit Posted August 27, 2007 Report Share Posted August 27, 2007 I have a friend with the same issue on his Porsche. He spoke with a Porsche tech and he explained that it's how the engine is designed, so even a brand new 911 will experience it from time to time due to the way the oil settles in the engine, it gets burned off every once in awhile when you start the car, thus leading him to believe that there is no fix and Porsche is o.k. with occasional embarrasment generally associated with higher mileage vehicles costing less than a house. :D I haven't seen this yet with my car but then it doesn't sit idle very long. Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted August 27, 2007 Report Share Posted August 27, 2007 I test drove a new Black 07 SGT this past Saturday. The dealer had to first drive it out of his showroom. I was standing about 20 feet behind the car when he started it. I noticed the black smoke, too. Usually, I believe black indicates a too rich mixture on start-up. I think white smoke indicates oil burning, but I'm not sure. It stopped after a few seconds. Maybe they are designed to start with that mixture??? :huh: Link to comment Share on other sites More sharing options...
MattInDetroit Posted August 27, 2007 Report Share Posted August 27, 2007 I test drove a new Black 07 SGT this past Saturday. The dealer had to first drive it out of his showroom. I was standing about 20 feet behind the car when he started it. I noticed the black smoke, too. Usually, I believe black indicates a too rich mixture on start-up. I think white smoke indicates oil burning, but I'm not sure. It stopped after a few seconds. Maybe they are designed to start with that mixture??? :huh: Yeah "usually": "A little" Black: too much gas in the mix "A little" Blue: Oil burn off "A little" White: Water vapor Link to comment Share on other sites More sharing options...
SGT1171 Posted August 27, 2007 Report Share Posted August 27, 2007 Mine did too. A Harley dealer told me it was a lifter not broken in or seating properly yet, and it would go away. He was right. Went away after about 1500 miles. Link to comment Share on other sites More sharing options...
