SAMstng Posted July 2, 2007 Report Share Posted July 2, 2007 Hello All, Does anyone know if the strut bar (Part #5S3Z-ASB on ShelbyPerformanceParts.com) will fit under the hood of the CS6 package with a standard plenum cover? I like the way it looks and need the extra stability. Thanks Steve Link to comment Share on other sites More sharing options...
Paleoc Posted July 2, 2007 Report Share Posted July 2, 2007 Hello All, Does anyone know if the strut bar (Part #5S3Z-ASB on ShelbyPerformanceParts.com) will fit under the hood of the CS6 package with a standard plenum cover? I like the way it looks and need the extra stability. Thanks Steve Is this a V6 or a V8? The V6 has a higher intake plenum and it may not even clear the plenum. In addition, on my V6, I had to cut the hood scoop area out on the lower part of my hood just to keep the plenum cover from rubbing on the hood. On a V8, it may clear??? Link to comment Share on other sites More sharing options...
SAMstng Posted July 2, 2007 Author Report Share Posted July 2, 2007 Is this a V6 or a V8? The V6 has a higher intake plenum and it may not even clear the plenum. In addition, on my V6, I had to cut the hood scoop area out on the lower part of my hood just to keep the plenum cover from rubbing on the hood. On a V8, it may clear??? Sorry, it has a V6 without a plenum cover. I was hoping to add a cover since I really liked the way it looks on yours. Link to comment Share on other sites More sharing options...
Paleoc Posted July 3, 2007 Report Share Posted July 3, 2007 Sorry, it has a V6 without a plenum cover. I was hoping to add a cover since I really liked the way it looks on yours. You can put a plenum cover on but you will have to cut the hood scoop area on the underside of the hood out. I seriously doubt the bar will clear the plenum much less the cover. Link to comment Share on other sites More sharing options...
