switch Posted June 20, 2007 Report Share Posted June 20, 2007 I'm thinking of purchasing 4 Black 20x9" Razor wheels but not sure about the 5.5, 6, and 6.5" backspacing. What backspacing would work the best? Does it have to do with offset? Not really sure which ones to get. Appreciate opinions. Thanks. Also, can I put different centercaps on the wheels to eliminate the snake?? Link to comment Share on other sites More sharing options...
ShelbyCobra826 Posted June 20, 2007 Report Share Posted June 20, 2007 I'm thinking of purchasing 4 Black 20x9" Razor wheels but not sure about the 5.5, 6, and 6.5" backspacing. What backspacing would work the best? Does it have to do with offset? Not really sure which ones to get. Appreciate opinions. Thanks. Also, can I put different centercaps on the wheels to eliminate the snake?? Ditto, but 18". Link to comment Share on other sites More sharing options...
switch Posted June 21, 2007 Author Report Share Posted June 21, 2007 Anyone???? Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted June 21, 2007 Report Share Posted June 21, 2007 Anyone???? I am not 100% sure, but I think Socal or CM198 posted some spacing numbers about 5 weeks ago. Did you try a search for "spacing" or something similar? Link to comment Share on other sites More sharing options...
ShelbyPilot Posted June 21, 2007 Report Share Posted June 21, 2007 .....I was being quiet because my wheels are a different design, size and the offset was in millimeters. However, if you want it my fronts ar 9" wide and have a 39mm offset and my rears are 10.5" wide and have a 40mm offset. The tire salesman where I had my wheels mounted is a mustang guy and he had 38mm offset on his 10.5" wheels. I suggest you call or email John or Bud. Otherwise, go to a wheel place and ask them four an estimate and ask them about the different backspacings. Link to comment Share on other sites More sharing options...
ShelbyCobra826 Posted June 21, 2007 Report Share Posted June 21, 2007 .....I was being quiet because my wheels are a different design, size and the offset was in millimeters. However, if you want it my fronts ar 9" wide and have a 39mm offset and my rears are 10.5" wide and have a 40mm offset. The tire salesman where I had my wheels mounted is a mustang guy and he had 38mm offset on his 10.5" wheels. I suggest you call or email John or Bud. Otherwise, go to a wheel place and ask them four an estimate and ask them about the different backspacings. I emailed Bud about this twice, and while he answered my other questions, he did not address this one. As I won't have my car for another month, I figured that I'd just wait and ask then as I can't do anything about it now anyway. Link to comment Share on other sites More sharing options...
stump_breaker Posted June 21, 2007 Report Share Posted June 21, 2007 .....I was being quiet because my wheels are a different design, size and the offset was in millimeters. However, if you want it my fronts ar 9" wide and have a 39mm offset and my rears are 10.5" wide and have a 40mm offset. The tire salesman where I had my wheels mounted is a mustang guy and he had 38mm offset on his 10.5" wheels. I suggest you call or email John or Bud. Otherwise, go to a wheel place and ask them four an estimate and ask them about the different backspacings. Conversion factor = 39mm=1.53" 40mm=1.57" 5.5"=139.7mm 6.0"=152.4mm 6.5"=165.1mm if that helps any.. Link to comment Share on other sites More sharing options...
savage1969 Posted June 21, 2007 Report Share Posted June 21, 2007 Just to correct and clarify, backspacing and offset are two different animals. Use the following: Overall width/2 = Centerline (overall width is measured lip to lip) Centerline – Back Spacing = Offset in Inches Inches x 25.4 = Offset in mm That should get you where you want to be. Note that you can't use SoCals widths because those are tire mounting widths, not overall width. You must use lip to lip for widths in these formulas. Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted June 21, 2007 Report Share Posted June 21, 2007 5.5"=139.7mm With a name like stump, you sure were pretty quick to come up with those conversions. I see you're pretty comfortable with the larger numbers. :P Just kidding pal. :D Link to comment Share on other sites More sharing options...
stump_breaker Posted June 21, 2007 Report Share Posted June 21, 2007 With a name like stump, you sure were pretty quick to come up with those conversions. I see you're pretty comfortable with the larger numbers. :P Just kidding pal. :D Ha Ha... <_< :P I'm still waiting for someone to figure what my screen name actually means.... ....BTW, if by chance someone does know, it's just a name not a hobby! Link to comment Share on other sites More sharing options...
07shelbygt109 Posted June 21, 2007 Report Share Posted June 21, 2007 Ha Ha... <_< :P I'm still waiting for someone to figure what my screen name actually means.... ....BTW, if by chance someone does know, it's just a name not a hobby! I was going to say something about it but I figured I better not. You look to be a bit bigger than me. :D Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted June 22, 2007 Report Share Posted June 22, 2007 Ha Ha... <_< :P I'm still waiting for someone to figure what my screen name actually means.... ....BTW, if by chance someone does know, it's just a name not a hobby! I was going to ask in the last post but I was trying to keep it funny, nit serious. Okay, some guesses: 1) Mad scientist 2) Tree removal 3) Bouncer 4) UFC champ 5) Exotic dancer 6) Beat up little people 7) Bird watcher * 8) Astronaut 9) Headache medicine :D Link to comment Share on other sites More sharing options...
stump_breaker Posted June 22, 2007 Report Share Posted June 22, 2007 I was going to ask in the last post but I was trying to keep it funny, nit serious. Okay, some guesses: 1) Mad scientist 2) Tree removal 3) Bouncer 4) UFC champ 5) Exotic dancer 6) Beat up little people 7) Bird watcher * 8) Astronaut 9) Headache medicine :D Oh brother. You are no where close and I will never tell... Link to comment Share on other sites More sharing options...
07shelbygt109 Posted June 22, 2007 Report Share Posted June 22, 2007 Oh brother. You are no where close and I will never tell... Stump, If anyone else figures it out I would be willing to bet they were from the South or the West. What do you think? Link to comment Share on other sites More sharing options...
stump_breaker Posted June 22, 2007 Report Share Posted June 22, 2007 Stump, If anyone else figures it out I would be willing to bet they were from the South or the West. What do you think? I know it's a southern thing but west? Link to comment Share on other sites More sharing options...
ColoradoShelbyGT Posted June 22, 2007 Report Share Posted June 22, 2007 You're a piliated woodpecker? "Another homespun name in extensive use is Cock-of-the-woods; yet another is Wood-cock. This last is suitable enough, but it leads obviously to confusion. Accordingly, within the range of the true woodcock (Philohela minor), the woodpecker is commonly distinguished as the "black woodcock." Other appellatives that have been picked up here and there and gathered in the books are "black woodpecker," "English woodpecker," "black log," "king-of-the-woods," "stump breaker"; and because of its cackling cry, "wood-hen," "Indian-hen," "laughing woodpecker," "johnny-cock," "wood-chuck," and "cluck-cock." (This last, given by Scoville, 1920, as current in Juniata County, Pa., is perhaps, an assimilation from the Pennsylvania Dutch.) *** Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted June 22, 2007 Report Share Posted June 22, 2007 You're a piliated woodpecker? "Another homespun name in extensive use is Cock-of-the-woods; yet another is Wood-cock. This last is suitable enough, but it leads obviously to confusion. Accordingly, within the range of the true woodcock (Philohela minor), the woodpecker is commonly distinguished as the "black woodcock." Other appellatives that have been picked up here and there and gathered in the books are "black woodpecker," "English woodpecker," "black log," "king-of-the-woods," "stump breaker"; and because of its cackling cry, "wood-hen," "Indian-hen," "laughing woodpecker," "johnny-cock," "wood-chuck," and "cluck-cock." (This last, given by Scoville, 1920, as current in Juniata County, Pa., is perhaps, an assimilation from the Pennsylvania Dutch.) *** I did the same Google search. That's where I came up with some of my answers. I was sure it was the bird watcher. There was another one about headaches. The rest I made up to be funny. Come on Stump, you have to give it up now. :P I got it, it's your band's name. Link to comment Share on other sites More sharing options...
07shelbygt109 Posted June 22, 2007 Report Share Posted June 22, 2007 I know it's a southern thing but west? Texas, Kansas, and Oklahoma were considered part of the "South." Plus people out West get made fun of about as much as we do. Link to comment Share on other sites More sharing options...
switch Posted June 23, 2007 Author Report Share Posted June 23, 2007 Original post?? Link to comment Share on other sites More sharing options...
ShelbyGT/SC Posted June 23, 2007 Report Share Posted June 23, 2007 Original post?? Sorry about that switch. I'll go stand in the corner for a few minutes. :rolleyes: Link to comment Share on other sites More sharing options...
07shelbygt109 Posted June 23, 2007 Report Share Posted June 23, 2007 Original post?? Easy now, we do tend to ramble some. :blink: Link to comment Share on other sites More sharing options...
rjr Posted June 23, 2007 Report Share Posted June 23, 2007 I'm thinking of purchasing 4 Black 20x9" Razor wheels but not sure about the 5.5, 6, and 6.5" backspacing. What backspacing would work the best? Does it have to do with offset? Not really sure which ones to get. Appreciate opinions. Thanks. Also, can I put different centercaps on the wheels to eliminate the snake?? My recollection is that the cars used in the museum (GT 500 Anniversary, CS6/8) used a 24mm offset. According to the "Special Notes" in the part description, that equates to the 6" wheel. Special Notes -------------------------------------------------------------------------------- "BLACK POWDER COATED CENTER, MACHINED LIP. SHELBY EMBOSSED IN ONE SPOKE. SHELBY CENTER CAP INCLUDED. +24MM OFFSET. 1600 LBS MAX CAPACITY PER WHEEL." http://www.shelbyperformanceparts.com/ShowItem/100092.aspx Disclaimer: I am not providing professional advice as I am not an attprney, CPA, auto mechanic or hold a drivers license and any comments herein should be brought to those professionals for their expert opinions, hoever........I did sleep at a Holiday Inn last night. Link to comment Share on other sites More sharing options...
