shelbydream1 Posted May 31, 2007 Report Share Posted May 31, 2007 Anyone heard if bigger injectors would bump HP by a noticeable amount? Link to comment Share on other sites More sharing options...
stump_breaker Posted May 31, 2007 Report Share Posted May 31, 2007 Anyone heard if bigger injectors would bump HP by a noticeable amount? I wondered this myself. Although I have no definitive answer, I'm pretty sure as long as the motor is stock it will prove worthless. Start upgrading and it helps. It's kind of the same with the throttle body. No need to upgrade unless you really start trying to turn some real big HP numbers.. Link to comment Share on other sites More sharing options...
DreamRide Posted June 1, 2007 Report Share Posted June 1, 2007 Anyone heard if bigger injectors would bump HP by a noticeable amount? You start getting into bigger injectors and larger capacity fuel systems when you start running Blowers and Turbo's. Link to comment Share on other sites More sharing options...
