06mustang Posted March 30, 2007 Report Share Posted March 30, 2007 i JUST got the cs6 grille but sadly it didnt come with instructions and i am having a hard time getting the shelby lettering to stay. also i need to know what i need those aluminum pices for. they are marked for drilling but without the instructions im lost. can some one PLEASE PM it or load it here so i kno what needs to happen. thanks peeps. Link to comment Share on other sites More sharing options...
Paleoc Posted March 30, 2007 Report Share Posted March 30, 2007 i JUST got the cs6 grille but sadly it didnt come with instructions and i am having a hard time getting the shelby lettering to stay. also i need to know what i need those aluminum pices for. they are marked for drilling but without the instructions im lost. can some one PLEASE PM it or load it here so i kno what needs to happen. thanks peeps. Letters go through the holes drilled in the long aluminum piece. Link to comment Share on other sites More sharing options...
06mustang Posted March 30, 2007 Author Report Share Posted March 30, 2007 i did that but the letters keep popping off. do i use those tiny black things with teeth or is that for the rivets that also where supplied? i cant see the pix rite now. im at work but ill check at home. Link to comment Share on other sites More sharing options...
GPStang06_merged Posted March 30, 2007 Report Share Posted March 30, 2007 do i use those tiny black things with teeth or is that for the rivets that also where supplied? Those are for the letters Link to comment Share on other sites More sharing options...
06mustang Posted March 30, 2007 Author Report Share Posted March 30, 2007 they dont fit in the holes in the metal strip. do i bore these holes out a little and then press the black teeth into it then the letters? Link to comment Share on other sites More sharing options...
Rogue24 Posted March 31, 2007 Report Share Posted March 31, 2007 I found the best way to mount the metal brackets is to put the narrow lip to the inside. One will be upside down. Here are some pics to give you an idea of what it will look like. I was able to get a fax from shelby when I started my grille here is the scan of that... Link to comment Share on other sites More sharing options...
