chritaka Posted December 11, 2006 Report Share Posted December 11, 2006 I think I read that the CS6 hood is raised 1" over stock to compensate for the dip and the dip in the hood would be the same height as the factory hood, is this correct? I will be going with a Kenne Bell or Whipple S/C on my '06 GT and want to see if there would be any clearance issues with the hood. There are not any clearance issues with the factory hood and if the CS6 has an additional 1", it should be fine? Just looking for confirmation. Thanks! Link to comment Share on other sites More sharing options...
GPStang06_merged Posted December 11, 2006 Report Share Posted December 11, 2006 I can say from what I was told it should clear, at least a Roushcharger since that is what I have on mine. Link to comment Share on other sites More sharing options...
chritaka Posted December 11, 2006 Author Report Share Posted December 11, 2006 I can say from what I was told it should clear, at least a Roushcharger since that is what I have on mine. Thanks, I appreciate the info! If it clears the Roush, then it should clear the others. Link to comment Share on other sites More sharing options...
GPStang06_merged Posted December 11, 2006 Report Share Posted December 11, 2006 Thanks, I appreciate the info! If it clears the Roush, then it should clear the others. Hopefully I can tell you for sure soon. The hood is still sitting in my garage. Waiting for the fascia before i get anything painted. I want to get everything painted at the same time as it doesn't matter how good a shop is, if they have to mix paint twice, chances are something will be different. Link to comment Share on other sites More sharing options...
Shelby_CS8 Posted December 12, 2006 Report Share Posted December 12, 2006 It doesnt clear the Paxton Supercharger. I had to cut a box shaped hole on the under neath to clear the massive inlet pipe. But I never complained......massive power....small sacrafise! Link to comment Share on other sites More sharing options...
pyrat Posted December 22, 2006 Report Share Posted December 22, 2006 It doesnt clear the Paxton Supercharger. I had to cut a box shaped hole on the under neath to clear the massive inlet pipe. But I never complained......massive power....small sacrafise! Jason, is this specific to the V8 installation? Link to comment Share on other sites More sharing options...
GPStang06_merged Posted December 22, 2006 Report Share Posted December 22, 2006 Well the question is then, Is the CS6 Hood clearance on the inside the same as the stock hood? I was told yes way back when I purchased my hood. If it is not and poses a problem for my Rouscharger I would not have went this route. Link to comment Share on other sites More sharing options...
amyb Posted December 25, 2006 Report Share Posted December 25, 2006 Well the question is then, Is the CS6 Hood clearance on the inside the same as the stock hood? I was told yes way back when I purchased my hood. If it is not and poses a problem for my Rouscharger I would not have went this route. Guys, I am not sure what the issue is here, and I think there is confusion. We all have SC on our cars with the Gt-H/CS6 hood. they all fit and we have used paxton . So if its not fitting, then there is another issue. we have both the CS6 and CS8. The hood was made with paxton /vortex in mind as that is part of our kit. If you diviate from our kit, you should call before you buy. Jason, you have a lot of stuff on your car, please check to make sure what it is before posting that the hood doesn't fit our SC. Amy Link to comment Share on other sites More sharing options...
GPStang06_merged Posted December 25, 2006 Report Share Posted December 25, 2006 Guys, I am not sure what the issue is here, and I think there is confusion. We all have SC on our cars with the Gt-H/CS6 hood. they all fit and we have used paxton . So if its not fitting, then there is another issue. we have both the CS6 and CS8. The hood was made with paxton /vortex in mind as that is part of our kit. If you diviate from our kit, you should call before you buy. Jason, you have a lot of stuff on your car, please check to make sure what it is before posting that the hood doesn't fit our SC. Amy Understood Amy, that is what I did since I have a Roots style blower sitting ontop of the engine that fit's under the stock hood with no issue. When I purchased the hood from Hillbank I was told there was no issue that the clearance is the same as the stock hood. Link to comment Share on other sites More sharing options...
amyb Posted December 26, 2006 Report Share Posted December 26, 2006 Understood Amy, that is what I did since I have a Roots style blower sitting ontop of the engine that fit's under the stock hood with no issue. When I purchased the hood from Hillbank I was told there was no issue that the clearance is the same as the stock hood. thanks GP, merry christmas!!! Not sure where the confusion is, the paxton fits, the roush fits and I suppose as long as it's a roots sytem there will bo no issues. I am waiting for Jason to tell me whay he did differently that made him cut a hole. Amy Link to comment Share on other sites More sharing options...
GPStang06_merged Posted January 5, 2007 Report Share Posted January 5, 2007 thanks GP, merry christmas!!! Not sure where the confusion is, the paxton fits, the roush fits and I suppose as long as it's a roots sytem there will bo no issues. I am waiting for Jason to tell me whay he did differently that made him cut a hole. Amy Amy, FYI. My Bodyshop called today to inform me the hood does not fit on my car with the Roush blower (I assume will be the same with other roots/twinscrew blowers as well). They will need to cut the inner support basically in the area that looks like it is meant to be cut out for a drag racing style blower. They are going to put some dye on top of the blower and mark where it hits and send me pictures. I will be sending those to Ted once I get them as I am not thrilled about the idea of changing the structural support. I will post here as well. So the answer appears to be no, the underside of the CS6 Hood is not the same clearance as the stock hoods. Link to comment Share on other sites More sharing options...
Flyingbadgers2001 Posted January 6, 2007 Report Share Posted January 6, 2007 Amy, FYI. My Bodyshop called today to inform me the hood does not fit on my car with the Roush blower (I assume will be the same with other roots/twinscrew blowers as well). They will need to cut the inner support basically in the area that looks like it is meant to be cut out for a drag racing style blower. They are going to put some dye on top of the blower and mark where it hits and send me pictures. I will be sending those to Ted once I get them as I am not thrilled about the idea of changing the structural support. I will post here as well. So the answer appears to be no, the underside of the CS6 Hood is not the same clearance as the stock hoods. Sorry to hear about the clearance issue. I hope it works out. -FB Link to comment Share on other sites More sharing options...
GPStang06_merged Posted January 6, 2007 Report Share Posted January 6, 2007 Thanks bro Link to comment Share on other sites More sharing options...
