Detuned Shelbys Delivered To Dealers
FordGeek
I know I saw it somewhere (either in this forum or in one of the many auto mags I subscribe to) that the Shelbys will be arriving to the dealerships in a detuned state. The motivation behind this move is to discourage "hot rodding" by dealer personnel until such time as the true owner takes ownership of the vehicle. My question is, does anyone have a clue what exactly is involved in getting the car back up to spec, and how would one know that the proper procedure has been carried out so that we don't drive off with a dud?
:shrug:
:shrug:
I heard someone on this forum say that it is what they call a Re-flash.
And it is very simple
Yeah he's right,
The onboard computer that regulates the engines output, timing, etc.
is de-tuned for the reason you mentioned. When the car is recieved by the dealer
they hook it up to their computer and re-flash the onboard programming back to
the original specs, as programmed by SVT. It's quick and easy.
KingCobra.
It can be but the fuel and timing are retared so you don't have to worry about burnouts and such. It may be rev-limited as well. The flash takes about 45 seconds and is done by a machine hooked to ford via satellite so they can track it. You should see it in your oasis report if you ask your service advisor for it.
Roger
Ford did the same thing with some Terminators back in 2003. The story back then was that many cars were showing up with fouled plugs. :shrug:
At some point during the 2003 model year, Ford decided to start shipping Cobras with the supercharger boost disabled. For those unfamiliar with Terminators, there's a boost bypass valve that prevents boost from building up even though the blower is still turning. The valve is controlled by the PCM.
I purchased a new Cobra back in September of '03. During the initial test-drive of my car (it had fewer than 7 miles on the odometer), it made no boost for the first several minutes of the test drive. When I was on my way back to the dealer with the car...BAM...suddenly the boost started working! I thought for sure there was something wrong and almost didn't buy the car. The dealer could provide no explanation...nor could any of the techs on duty.
After looking around on message boards, I found the answer. The boost had been disabled in the tune from the factory. This message was broadcast to all dealers, but most were completely unaware of it...
SPECIAL SERVICE MESSAGES
16459 2003 MUSTANG COBRA SUPERCHARGED
LACK OF POWER AND NO BOOST, LOW MILES
SOME 2003 COBRA VEHICLES EQUIPPED WITH THE 4.6L SUPERCHARGED ENGINE MAY EXHIBIT A LACK OF POWER AND NO BOOST WHEN THE VEHICLE IS INITIALLY DELIVERED TO THE DEALERSHIP. THE VEHICLES AFFECTED WILL HAVE VERY LOW MILES AND THE CONCERN WILL TYPICALLY BE NOTICED DURING THE PRE-DELIVERY INSPECTION. IF THE VEHICLE HAS NO BOOST AND LACK OF POWER, CLEAR THE KEEP ALIVE MEMORY AND RETEST. THE ALTERNATIVE CALIBRATION IS USED DURING THE ASSEMBLY PROCESS TO DISABLE BOOST AND PREVENT PLUG FOULING. BY CLEARING THE KEEP ALIVE MEMORY OR DRIVING THE VEHICLE FOR AT LEAST FIVE CONTINUOUS MILES, THE VEHICLE WILL REVERT BACK TO THE BASE CALIBRATION AND BOOST WILL BE ENABLED.
This situation was fairly rare. It took me awhile to find someone else who had the same issue.
Roger
Ok...what is an Oasis report? :wacko:
The Oasis report is the report ford generates anytime there is anything done to the vehicle at a delership. Its a maintence record and does include things done before purchase.
Roger
No, it is not a maintainence record. An OASIS is a warranty history report that lists warranty claims and repairs. Maintainence (oil changes, tire rotations, etc.) are not included in an OASIS.
For example, here's the OASIS for my Mach 1...
OASIS RESULT:
1FAFP42RX3FXXXXXX
06/20/2006
13:41:11
VEHICLE INFORMATION
VEHICLE DESCRIPTION 2003 MUSTANG
BODY STYLE 2 DOOR COUPE GT
ENGINE 4.6L EFI DOHC
TRANSMISSION T3650 5-SPEED MANUAL
AXLE CODE ME
ENGINE CALIBRATION 3ZE2M10A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE 09/08/2003
BUILD DATE 05/23/2003
SALE MILEAGE 00400
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING SEAT BELT RETRACTOR (-611B08/9, 611B68/9-) SEE TSB 05-16-11
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
09/07/2005
DEALER: XXXXX
WARRANTY CLAIM NUMBER: 205621 ODOMETER: 022067M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
F6ZZ 6323394AA DRIVE ASY-PWR LIFT W 001 23943A11 28 OPEN CIRCUIT
000 23943A
22067 VERIFIED COMPLAINT REMOVED DRIVERS DOOR INTERIOR PANEL FOUND 12.6 VOL TS AT WINDOW MOTOR TESTED MOTOR FOUND OPEN CIRCUIT R&R WINDOW RUNS AND TRACK REPLACED WINDOW MOTOR ADJUSTED WINDOW RUNS AND TRACK RETEST ALL OK REINSTALLED DOOR PANEL
08/10/2005
DEALER: XXXXX
WARRANTY CLAIM NUMBER: 204232 ODOMETER: 021304M
LABOR OP
CONDITION CODE
CONDITION DESC
3R3Z 7124AD SYNCHRONIZER ASY 001 7003A 42 DOES NOT OPERATE PROPERLY
000 7003A2
000 7003AZJ
21309 TEST DROVE FOUND HARD TO SHIFT COLD REMOVED TRANS INSTALL UP GRADE KIT CHECKED ALL CLEARANCES BUILD UP TRANS INSTALLED TEST DROVE FINE
Click Here for Full Warranty History
END OF OASIS REPORT FOR 1FAFP42RX3FXXXXXX
What are the chances we can get the program to detune the car? Could be useful if you're handing the car over to a valet. A 45 second operation would be priceless in that scenario.
There's a great product potential to make a small flash-loader that plugs into the flash port and, in turn passes that interface right thru. A switch mounted under the dash let's you select between VALET and NORMAL. I think vettes had (have) this at one time and I think it was (is) called VALET MODE.
Could probably make them in reasonably low volume for $30-40 and sell them for considerably more. In fact, I'd like 3 or 4 modes: Stock, Valet, Custom-Prog#1, Custom-Prog#2. I'd pay $200 for that!
It was the ZR1 Vettes with the Lotus designed, Mercury Marine built 4 cam engine. Controlled by the ignition key via a switch on the console. Took it from 400 to 250 horses.
Thanks Jetsolver.. that's the one! So glad you are in these forums...
That would be such a nice touch Ford could easily add to their hi-po offerings (not that I'm gonna let anyone drive it without me in the car!) :)
