svtkeith Posted June 10, 2006 Report Share Posted June 10, 2006 Responding to some of the bad performance #'s that some magazines are publishing on the GT500. I am sure their heads must be stuck up their A--holes. Check out these #'s from TV's Motoring 2006 on an 06 Bentley weighing in at 5500 lbs; with 552 hp; 479 ft-tq; 0-60 in 4.2 sec at top speed of 312 kms, no 1/4 times available and it has the aerodynamics of a boxcar. Compare this to our GT500, even at 3900 lbs; 500hp; 480 ft-tq; traction is definitely the problem and probably bad drivers. Believe me guys this car is going to fly. svtkeith Link to comment Share on other sites More sharing options...
KingCobra Posted June 11, 2006 Report Share Posted June 11, 2006 Traction is without a dought the main thing holding the GT500 back. Is it possible to improve the traction??? In my humble opinion guys, all of the talk around power modification is a waist of time and money when the car already has trouble getting the power it has to the ground without just spinning in place. This is the first place to mod if you're going to, otherwise it's pointless. Any thoughts??? KingCobra. Link to comment Share on other sites More sharing options...
07 Shelby Cobra Posted June 11, 2006 Report Share Posted June 11, 2006 Traction is without a dought the main thing holding the GT500 back. Is it possible to improve the traction??? In my humble opinion guys, all of the talk around power modification is a waist of time and money when the car already has trouble getting the power it has to the ground without just spinning in place. This is the first place to mod if you're going to, otherwise it's pointless. Any thoughts??? KingCobra. Damn right James! We really have to see this thing run with slicks on her. :burnout: Link to comment Share on other sites More sharing options...
BlueOval Posted June 11, 2006 Report Share Posted June 11, 2006 It's all just "bench racin'" until these things hit the streets. As soon as people start posting time slips we'll all know for sure what they'll do. I personally wouldn't consider power mods a waste of time. You'll just have to match suspension mods with engine mods. Link to comment Share on other sites More sharing options...
faststang Posted June 11, 2006 Report Share Posted June 11, 2006 Traction is without a dought the main thing holding the GT500 back. Is it possible to improve the traction??? In my humble opinion guys, all of the talk around power modification is a waist of time and money when the car already has trouble getting the power it has to the ground without just spinning in place. This is the first place to mod if you're going to, otherwise it's pointless. Any thoughts??? KingCobra. I AGREE 100% THAT'S WHY I MADE A POST [WHAT TIRE] MIGHT BE THE FIRST THING I DO THEN ADD ON POWER.ALSO WHEN I PUT THE VORTCH S-TRIM IN THE 93 LX5.0 AT THE TIME I HAD EAGLE GSC WICH WERE NOT GOOD AT ALL AFTER THE S/C WAS INSTALLED.AFTER I PUT NITTO DRAG'S THEY HELPED ALOT![ A CAR HAS TO BE ALL AROUND IN ORDER TO PERFORM CORRECT]BEST OF LUCK TO ALL!! Link to comment Share on other sites More sharing options...
kaylan1521 Posted June 11, 2006 Report Share Posted June 11, 2006 Traction is without a dought the main thing holding the GT500 back. Is it possible to improve the traction??? In my humble opinion guys, all of the talk around power modification is a waist of time and money when the car already has trouble getting the power it has to the ground without just spinning in place. This is the first place to mod if you're going to, otherwise it's pointless. Any thoughts??? KingCobra. These would work preety good me thinks. Link to comment Share on other sites More sharing options...
