Willie Posted December 10, 2007 Report Share Posted December 10, 2007 Just changed the engine oil for the first time. I put in 6-1/2 quarts per owner's manual and the dipstick reads right in the middle of the cross-hatched area. Is the cross-hatched area the "normal" range for oil level and leave it be or should I top it off with another half quart so the dipstick reads at the top (full?) of the hatched area?? Willie Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted December 10, 2007 Report Share Posted December 10, 2007 6.5qts is correct. IMO leave it in the middle Link to comment Share on other sites More sharing options...
SLB8SNK Posted December 10, 2007 Report Share Posted December 10, 2007 Easier to add than reduce! 6.5, test, re-test, then add. Link to comment Share on other sites More sharing options...
mustang crazy Posted December 11, 2007 Report Share Posted December 11, 2007 Easier to add than reduce! 6.5, test, re-test, then add.Manual show 6.5 qt you should leave it in middle crossmarks Link to comment Share on other sites More sharing options...
DDT Posted December 11, 2007 Report Share Posted December 11, 2007 Manual show 6.5 qt you should leave it in middle crossmarks I think better to be over a little than under a little........ Link to comment Share on other sites More sharing options...
Joe G Posted December 11, 2007 Report Share Posted December 11, 2007 I think better to be over a little than under a little........ Not if the crankshaft whips air into the oil. Overfill and you in big trouble mister. Link to comment Share on other sites More sharing options...
Grabber Posted December 11, 2007 Report Share Posted December 11, 2007 6.5 and your good. mister Link to comment Share on other sites More sharing options...
DubbsFaris Posted December 11, 2007 Report Share Posted December 11, 2007 umm jiffy lube anyone? okay, that's mister jiffylube to you then!!! Link to comment Share on other sites More sharing options...
DDT Posted December 11, 2007 Report Share Posted December 11, 2007 Not if the crankshaft whips air into the oil. Overfill and you in big trouble mister. I SAID JUST A LITTLE OVER!!!!!!!!!!!!!!!!!!!!!! oops, didnt mean to yell Link to comment Share on other sites More sharing options...
mustarrosa Posted December 12, 2007 Report Share Posted December 12, 2007 Just changed the engine oil for the first time. I put in 6-1/2 quarts per owner's manual and the dipstick reads right in the middle of the cross-hatched area. Is the cross-hatched area the "normal" range for oil level and leave it be or should I top it off with another half quart so the dipstick reads at the top (full?) of the hatched area?? Willie How many miles for this first time change? Link to comment Share on other sites More sharing options...
