OneTrickPony Posted December 8, 2007 Report Share Posted December 8, 2007 I own a 07 White Shelby GT five speed. Has anyone else noticed a vibration in 3rd gear on deceleration only with their hand on the shifter. When I accelerate the vib goes away. The trans has done this since day one. Ford replaced the trans with a new one since it didn't seem normal that none of the other Mustang GT's (factory shifter) had a vibration and it was only in 3rd gear on deceleration. The new transmission does the same thing. I have noticed that when I apply a slight bit of forward pressure on the shifter it does go away and is smooth as silk. Could it be the Hurst Shifter? Is this a normal chracteristic of the car's shifter since the factory shifter has different bushings. I'm not able to test drive another Shelby GT with a five speed for the obvious reasons. Thanks for any help or advice. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted December 8, 2007 Report Share Posted December 8, 2007 I own a 07 White Shelby GT five speed. Has anyone else noticed a vibration in 3rd gear on deceleration only with their hand on the shifter. When I accelerate the vib goes away. The trans has done this since day one. Ford replaced the trans with a new one since it didn't seem normal that none of the other Mustang GT's (factory shifter) had a vibration and it was only in 3rd gear on deceleration. The new transmission does the same thing. I have noticed that when I apply a slight bit of forward pressure on the shifter it does go away and is smooth as silk. Could it be the Hurst Shifter? Is this a normal chracteristic of the car's shifter since the factory shifter has different bushings. I'm not able to test drive another Shelby GT with a five speed for the obvious reasons. Thanks for any help or advice. There are reports of shifter vibration what can be caused by loose bolts that hold the shifter in place as well as a rubber boot of sorts that can come loose. I am TOTALLY non-mechanical so I will direct you to the following for now and wait for those with more talent chime in. In the meantime I will direct you to a topic in the old forum, which is being moved over here, for now: http://forum.shelbyautos.com/index.php?showtopic=3154 Link to comment Share on other sites More sharing options...
OneTrickPony Posted December 9, 2007 Author Report Share Posted December 9, 2007 There are reports of shifter vibration what can be caused by loose bolts that hold the shifter in place as well as a rubber boot of sorts that can come loose. I am TOTALLY non-mechanical so I will direct you to the following for now and wait for those with more talent chime in. In the meantime I will direct you to a topic in the old forum, which is being moved over here, for now: http://forum.shelbyautos.com/index.php?showtopic=3154 Link to comment Share on other sites More sharing options...
OneTrickPony Posted December 9, 2007 Author Report Share Posted December 9, 2007 Thanks for the info, looks like I got a new tranny for nothing. My car sat in their shop for 3 weeks while I waited for them to figure out what to do about the issue. Link to comment Share on other sites More sharing options...
07SGT0086 Posted December 10, 2007 Report Share Posted December 10, 2007 Thanks for the info, looks like I got a new tranny for nothing. My car sat in their shop for 3 weeks while I waited for them to figure out what to do about the issue. In spite of the inconvenience, try to consider the new trans as a process of elimination... same problem with new trans, so the original trans was likely OK. Next item to receive closer scruitiny... probably the Hurst Shifter. I hope your concern is resolved soon... good luck. BTW: no 3rd gear decel shifter chatter/noise to report on CSM No. 07SGT0086. Link to comment Share on other sites More sharing options...
LuckySnake Posted December 11, 2007 Report Share Posted December 11, 2007 Thanks for the info, looks like I got a new tranny for nothing. My car sat in their shop for 3 weeks while I waited for them to figure out what to do about the issue. Your Drive Shaft could cause this problem, not balanced correctly. Ask Ford dealership if they can borrow one, to prove it's not the DS. Link to comment Share on other sites More sharing options...
mikesdream Posted December 12, 2007 Report Share Posted December 12, 2007 Mine is so loud in 4th at normal hwy speeds that I have to turn the shake 500 up to 45. I'v experienced this from the get go (4500mi). When I put a little pressure on the shifter or excellerate it goes away but then my wife starts complaining about how I drive. I say "Baby it's a shelby, it likes the abuse." All kiding aside, I would like my 40k car without this glitch. SGT182 wht 5spd, signed by all the SAI employees. Link to comment Share on other sites More sharing options...
TBone Posted December 12, 2007 Report Share Posted December 12, 2007 I own a 07 White Shelby GT five speed. Has anyone else noticed a vibration in 3rd gear on deceleration only with their hand on the shifter. When I accelerate the vib goes away. The trans has done this since day one. Ford replaced the trans with a new one since it didn't seem normal that none of the other Mustang GT's (factory shifter) had a vibration and it was only in 3rd gear on deceleration. The new transmission does the same thing. I have noticed that when I apply a slight bit of forward pressure on the shifter it does go away and is smooth as silk. Could it be the Hurst Shifter? Is this a normal chracteristic of the car's shifter since the factory shifter has different bushings. I'm not able to test drive another Shelby GT with a five speed for the obvious reasons. Thanks for any help or advice. I have an 07 as well and I have the very same symptom. I read the other posts and will check with my dealer Link to comment Share on other sites More sharing options...
AstroDan Posted December 12, 2007 Report Share Posted December 12, 2007 Mine is so loud in 4th at normal hwy speeds that I have to turn the shake 500 up to 45. I'v experienced this from the get go (4500mi). When I put a little pressure on the shifter or excellerate it goes away but then my wife starts complaining about how I drive. I say "Baby it's a shelby, it likes the abuse." All kiding aside, I would like my 40k car without this glitch. SGT182 wht 5spd, signed by all the SAI employees. At normall freeway speeds (65+mph?) you should be in 5th gear anyway! Probably back-torque since it goes away as soon as you accelerate. Not sure, just my .02c Dan Link to comment Share on other sites More sharing options...
bubbabow Posted December 18, 2007 Report Share Posted December 18, 2007 i am not sure if this is the right place to post this as there are several treads on shifter/transmission rattles etc. I took my 08 in today it rattles real bad in 2 and 3 gears it also rattles behind the airbag on the dash. the service mgr. called ford the said that their reports said to remove the two exhaust hangers at trans cross member and leave them off that they are not needed. The noise completely stopped in both places. I suggested tightening the bolts on the shifter at the transmission but they said that they were fine it was the exhaust hangers. I drive it aggressively in 2nd and third trying to make it happen and it does not. hopes this helps. I also hope leaving the two hangers off are ok , according to Ford they are not necessary. guess we will see. Link to comment Share on other sites More sharing options...
Alloy Dave Posted December 18, 2007 Report Share Posted December 18, 2007 i am not sure if this is the right place to post this as there are several treads on shifter/transmission rattles etc. I took my 08 in today it rattles real bad in 2 and 3 gears it also rattles behind the airbag on the dash. the service mgr. called ford the said that their reports said to remove the two exhaust hangers at trans cross member and leave them off that they are not needed. The noise completely stopped in both places. I suggested tightening the bolts on the shifter at the transmission but they said that they were fine it was the exhaust hangers. I drive it aggressively in 2nd and third trying to make it happen and it does not. hopes this helps. I also hope leaving the two hangers off are ok , according to Ford they are not necessary. guess we will see. Is this on a GT500 or a Shelby GT? thanks for posting. Link to comment Share on other sites More sharing options...
bubbabow Posted December 18, 2007 Report Share Posted December 18, 2007 08 gt manual Link to comment Share on other sites More sharing options...
uno Posted December 28, 2007 Report Share Posted December 28, 2007 it sounds like your just putting a slight bit of pressure on the shifter towards neutral. Link to comment Share on other sites More sharing options...
07alloyGT Posted January 13, 2008 Report Share Posted January 13, 2008 i am not sure if this is the right place to post this as there are several treads on shifter/transmission rattles etc. I took my 08 in today it rattles real bad in 2 and 3 gears it also rattles behind the airbag on the dash. the service mgr. called ford the said that their reports said to remove the two exhaust hangers at trans cross member and leave them off that they are not needed. The noise completely stopped in both places. I suggested tightening the bolts on the shifter at the transmission but they said that they were fine it was the exhaust hangers. I drive it aggressively in 2nd and third trying to make it happen and it does not. hopes this helps. I also hope leaving the two hangers off are ok , according to Ford they are not necessary. guess we will see. Thanks for this info. My 07 GT manual has developed a vibration/rattle just as you described with in the past week. I'm going to get it checked this week. Link to comment Share on other sites More sharing options...
