69dejavue Posted October 14, 2007 Report Share Posted October 14, 2007 Does anyone know if the 2007 SGT has an engine oil cooler radiator and if so the location and location of the lines. Link to comment Share on other sites More sharing options...
07SHELBY GT Posted October 15, 2007 Report Share Posted October 15, 2007 Does anyone know if the 2007 SGT has an engine oil cooler radiator and if so the location and location of the lines. It does not. Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted October 15, 2007 Report Share Posted October 15, 2007 has some type of water to oil system; don't know where the heat exchanger is located though Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted October 15, 2007 Report Share Posted October 15, 2007 here is a graphic of the cooling system; oil cooler is at the rear side Link to comment Share on other sites More sharing options...
SCGT500 Posted October 15, 2007 Report Share Posted October 15, 2007 Here is the cooler on a GT500. It is the block w/ the numbers. It is located on the drivers side, I belive it is the same on the 4.6 motor. There are no hoses or tubes, it is directly connected at the block I believe. Link to comment Share on other sites More sharing options...
07SHELBY GT Posted October 16, 2007 Report Share Posted October 16, 2007 It does not. Let me rephrase this,if you look at the oil filter adapter on a Shelby GT,It appears to have some sort of coolant circulation at the base of the filter,nothing like the GT500,But some sort of temp control,quicker warm ups for the oil? Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted October 16, 2007 Report Share Posted October 16, 2007 sorry, thought you were asking about the gt500; maybe I should slow down and read next time Link to comment Share on other sites More sharing options...
Alloy Dave Posted October 16, 2007 Report Share Posted October 16, 2007 It does not. The GT500 DOES have an oil cooler, but not sure about the SGT. Link to comment Share on other sites More sharing options...
Alloy Dave Posted October 16, 2007 Report Share Posted October 16, 2007 Here is the cooler on a GT500. It is the block w/ the numbers. It is located on the drivers side, I belive it is the same on the 4.6 motor. There are no hoses or tubes, it is directly connected at the block I believe. Bill, I know a bit about this since I helped stentgraft with his leak here. It bolts to some type of adapter, and there are o-rings between the cooler head and the adapter. Looks pretty easy to get the cooler itself off, but the adapter is another story. It appears to be air cooled only. Link to comment Share on other sites More sharing options...
