Super Snake Posted September 6, 2007 Report Share Posted September 6, 2007 I posted this in the Ford Employee form and got no response can anyone help?????!!!! My coworker has a 2001 Mustang Vert that had a driver’s side power window motor failure He purchased a motor and in the process of replacing it some of the window track gears and parts fell apart He now isn't clear on how all the parts go back together Does anyone have a parts breakdown and pix from the IPB or Maint Manual they can post to help him reassemble the parts Thanks Lonnie Link to comment Share on other sites More sharing options...
regalt87 Posted September 6, 2007 Report Share Posted September 6, 2007 I did learn something a while back. its a expensive motor for the rear vert windows. Discount AP does not stock the vert motor so I bought the regular motor with the longer shaft and just cut it off and it worked fine. this was a 1989 vert. If you post pics of the parts I will open later tonight and look at it. Link to comment Share on other sites More sharing options...
Super Snake Posted September 7, 2007 Author Report Share Posted September 7, 2007 I did learn something a while back. its a expensive motor for the rear vert windows. Discount AP does not stock the vert motor so I bought the regular motor with the longer shaft and just cut it off and it worked fine. this was a 1989 vert. If you post pics of the parts I will open later tonight and look at it. He has the motor He's looking for a diagram to put the parts back together Link to comment Share on other sites More sharing options...
regalt87 Posted September 8, 2007 Report Share Posted September 8, 2007 Carefully remove the components from the other side and see if that helps. Link to comment Share on other sites More sharing options...
Super Snake Posted September 11, 2007 Author Report Share Posted September 11, 2007 Carefully remove the components from the other side and see if that helps. good point thanks Link to comment Share on other sites More sharing options...
