cknight Posted August 13, 2007 Report Share Posted August 13, 2007 I pulled up to a drive through yesterday, put the car in neutral and let the clutch out. I than noticed for the first time and noise. It sounded like a rough throwout bearing. Current mileage, 1,300 Does anyone else have this issue? Is it normal? Link to comment Share on other sites More sharing options...
sprint200 Posted August 13, 2007 Report Share Posted August 13, 2007 I pulled up to a drive through yesterday, put the car in neutral and let the clutch out. I than noticed for the first time and noise. It sounded like a rough throwout bearing. Current mileage, 1,300 Does anyone else have this issue? Is it normal? What you describe sounds like normal gear roll-over noise. It's described in the owners manual. I've even got it on my Mini Cooper. When I first got the Mini I thought I had a bad throwout bearing too. Link to comment Share on other sites More sharing options...
Dropping__Chronic Posted August 13, 2007 Report Share Posted August 13, 2007 I pulled up to a drive through yesterday, put the car in neutral and let the clutch out. I than noticed for the first time and noise. It sounded like a rough throwout bearing. Current mileage, 1,300 Does anyone else have this issue? Is it normal? Definitely a dud, I think you should just give up on the old girl and drop her off at my house. I'll pm you the address. My condolences on your loss. Link to comment Share on other sites More sharing options...
SSGT500 Posted August 13, 2007 Report Share Posted August 13, 2007 I pulled up to a drive through yesterday, put the car in neutral and let the clutch out. I than noticed for the first time and noise. It sounded like a rough throwout bearing. Current mileage, 1,300 Does anyone else have this issue? Is it normal? My trans does this also. Sometimes louder than other times. Link to comment Share on other sites More sharing options...
Super Snake Posted August 13, 2007 Report Share Posted August 13, 2007 Normal 07 GT500 BadAss high performance clutch noise Link to comment Share on other sites More sharing options...
1badsho Posted August 13, 2007 Report Share Posted August 13, 2007 this is a race tranny ... its not quite .... this is normal .. all ok ! Link to comment Share on other sites More sharing options...
Three Cobras Posted August 13, 2007 Report Share Posted August 13, 2007 CK - Normal. You'll hear that gear roll-over noise a bit more when you turn on the A/C - that 150 RPM drop when the A/C is on is enough to make the noise noticeably louder. Wouldn't surprise me, then, if they selected the idle speed for just that reason so it would be quieter during most times you are idling with your windows down. Link to comment Share on other sites More sharing options...
cknight Posted August 13, 2007 Author Report Share Posted August 13, 2007 Thanks for all the information. Link to comment Share on other sites More sharing options...
