Shelby.GT500 Posted October 16, 2010 Report Share Posted October 16, 2010 What RPMs are you guys setting the Performance Shift Indicator to? Just curious to what everyone would recommend them to. Thanks! Link to comment Share on other sites More sharing options...
Torched10 Posted October 16, 2010 Report Share Posted October 16, 2010 What RPMs are you guys setting the Performance Shift Indicator to? Just curious to what everyone would recommend them to. Thanks! i use 5800--and i never hear the chime--i look for the SVT logo to light up--really cool after dark too Link to comment Share on other sites More sharing options...
Shelby.GT500 Posted October 16, 2010 Author Report Share Posted October 16, 2010 Torch, thanks for your input! :happy feet: Link to comment Share on other sites More sharing options...
11ShelbyGT500 Posted October 18, 2010 Report Share Posted October 18, 2010 What RPMs are you guys setting the Performance Shift Indicator to? Just curious to what everyone would recommend them to. Thanks! +1 Link to comment Share on other sites More sharing options...
08 ORANGE SS-725HP Posted October 18, 2010 Report Share Posted October 18, 2010 6000 rpm's. Just program the light with NO tone. Won't hear it @ WOT anyway Link to comment Share on other sites More sharing options...
rkalish Posted October 19, 2010 Report Share Posted October 19, 2010 Bit of a different topic, but I cannot get the shift rpm to change from the default. I set the shift light on, but the value will not move no matter which of the two buttons I hit. Does anyone else have that problem. Thanks Link to comment Share on other sites More sharing options...
Torched10 Posted October 19, 2010 Report Share Posted October 19, 2010 Bit of a different topic, but I cannot get the shift rpm to change from the default. I set the shift light on, but the value will not move no matter which of the two buttons I hit. Does anyone else have that problem. Thanks i remember having the same issue---had to follow the manual directions exactly--bob Link to comment Share on other sites More sharing options...
2011 P8J Posted October 19, 2010 Report Share Posted October 19, 2010 I think the shift light is usless as tits on a boared hog. I wish the tone was louder because that would have been perfect. I had an 87 RX7 and when it hit redline a very loud beep would let you know. My Aeroforce guage has a shift light that works so much better than the stock light. Link to comment Share on other sites More sharing options...
bigsnake Posted October 19, 2010 Report Share Posted October 19, 2010 Bit of a different topic, but I cannot get the shift rpm to change from the default. I set the shift light on, but the value will not move no matter which of the two buttons I hit. Does anyone else have that problem. Thanks Maybe this will help. Performance shift indicator Your vehicle is equipped with a programmable performance shift indicator. When activated, this feature provides a visual (SHIFTLAMP) and/or audible (SHIFTTONE) cue to shift to the next highest gear at an engine rpm specified by the driver. The SHIFTLAMP feature uses the SVT logo on the tachometer to notify you when the desired shiftpoint is reached. The SVT symbol is backlit in red under normal driving conditions (SHIFTLAMP OFF). When the SHIFTLAMP is set to ON, the red backlighting is turned off and the SVT logo will turn bright orange when the desired shift point is reached. The SHIFTTONE feature uses an audible tone to notify you when the desired shiftpoint is reached. SHIFTLAMP and SHIFTTONE can be used separately, together, or turned off completely. To use the performance shift indicator feature, first bring the vehicle to a complete stop then use the message center controls as follows: Note: The vehicle's headlamps or park lamps must be on to perform/check light functions. 1. Press SETUP repeatedly until PRESS RESET TO SET SHIFTPOINT appears in the display. 2. Press RESET to choose between SHIFTLAMP ON/OFF. Press SETUP when finished. 3. Press RESET to choose between SHIFTTONE ON/OFF. Press SETUP when finished. 4. Press and hold INFO to lower the desired SHIFTPOINT in increments of 100 rpm. 5. Press and hold RESET to raise the desired SHIFTPOINT in increments of 100 rpm. Note: The SHIFTPOINT can be adjusted from 1,500-6,500 rpm. The performance shift indicator feature functions independently of the fuel economy upshift indicator . The upshift indicator will still illuminate when it is best to shift to the next highest gear to maximize fuel economy regardless of the performance shift indicator settings. Link to comment Share on other sites More sharing options...
mmolzahn Posted October 21, 2010 Report Share Posted October 21, 2010 Bit of a different topic, but I cannot get the shift rpm to change from the default. I set the shift light on, but the value will not move no matter which of the two buttons I hit. Does anyone else have that problem. Thanks I don't think you can change it while you are driving. You have to be stopped. Link to comment Share on other sites More sharing options...
