dukenrock Posted February 18, 2009 Report Share Posted February 18, 2009 I need a good 4 post lift (stacker) that will work in a 10'4 ceiling height. Can anybody give me a good brand and supplier? Thanks. Link to comment Share on other sites More sharing options...
shel-b001 Posted February 18, 2009 Report Share Posted February 18, 2009 Super Lift Store make good lifts but are in Canada. Just make sure your get a good hydrualic pump system as alot come from China. Mine was made in the U.S & has a 3" piston & is 220 volts but 110 volt work okay. Get aluminum ramps as the steel ones are way too heavy. Most come with a jack tray, 4 dollys & mine came with an oil drain tray. Shop around & compare before you buy. Most only need a 10' ceiling Good Luck Link to comment Share on other sites More sharing options...
Stalwart Posted February 18, 2009 Report Share Posted February 18, 2009 I have two of these along with a 4 post 15,000 lb lift: http://www.eagleequip.com/page/EE/PROD/LI-SS/MS-7000XLT I like them but I'd fasten them down with anything heavier than 4-5000 lb. Link to comment Share on other sites More sharing options...
dukenrock Posted February 18, 2009 Author Report Share Posted February 18, 2009 I agree with the non China brands. Would the casters be needed if it's bolted down? Also, what should I expect to pay? I was thing a couple grand.Thanks.... Super Lift Store make good lifts but are in Canada. Just make sure your get a good hydrualic pump system as alot come from China. Mine was made in the U.S & has a 3" piston & is 220 volts but 110 volt work okay. Get aluminum ramps as the steel ones are way too heavy. Most come with a jack tray, 4 dollys & mine came with an oil drain tray. Shop around & compare before you buy. Most only need a 10' ceiling Good Luck Link to comment Share on other sites More sharing options...
svtride Posted February 18, 2009 Report Share Posted February 18, 2009 I need a good 4 post lift (stacker) that will work in a 10'4 ceiling height. Can anybody give me a good brand and supplier? Thanks. Revolution lifts or Rotary lifts. Made in USA. Link to comment Share on other sites More sharing options...
dukenrock Posted February 18, 2009 Author Report Share Posted February 18, 2009 SVT, The Revolution looks great and will work (I think) I'll check that one out! TY Revolution lifts or Rotary lifts. Made in USA. Link to comment Share on other sites More sharing options...
tispco Posted February 18, 2009 Report Share Posted February 18, 2009 Revolution lifts or Rotary lifts. Made in USA. +1 I bought one. Great lift. Link to comment Share on other sites More sharing options...
shel-b001 Posted February 18, 2009 Report Share Posted February 18, 2009 I agree with the non China brands. Would the casters be needed if it's bolted down? Also, what should I expect to pay? I was thing a couple grand.Thanks.... No the casters are not needed if it is bolted down but most come with them . Your looking at just around 2 grand + for a decent unit Link to comment Share on other sites More sharing options...
rnoggle Posted February 18, 2009 Report Share Posted February 18, 2009 Something to keep in mind is your garage door hieght in the open position. I have 12 foot ceilings but, when my door is open, it is only about 8 feet high. I wanted to install a lift, but the door would hit any vehicle on the lift if it were opened. Link to comment Share on other sites More sharing options...
Stalwart Posted February 18, 2009 Report Share Posted February 18, 2009 The Eagle Lifts are also US made. Link to comment Share on other sites More sharing options...
SVTpower Posted February 18, 2009 Report Share Posted February 18, 2009 Something to keep in mind is your garage door hieght in the open position. I have 12 foot ceilings but, when my door is open, it is only about 8 feet high. I wanted to install a lift, but the door would hit any vehicle on the lift if it were opened. fyi, you have to redo the garage door side tracks so they direct up and not 90 degrees which is typical Link to comment Share on other sites More sharing options...
rnoggle Posted February 18, 2009 Report Share Posted February 18, 2009 fyi, you have to redo the garage door side tracks so they direct up and not 90 degrees which is typical I'm planning that this summer. I didn't look into the price yet, but I don't think it should be too much Link to comment Share on other sites More sharing options...
svtride Posted February 18, 2009 Report Share Posted February 18, 2009 SVT, The Revolution looks great and will work (I think) I'll check that one out! TY Ty The ceiling in the picture with the black hoist is 10 feet. That hoist had a ~63" rise. I had the garage door raised so the tracks were tight against the ceiling and could get my Ford Focus under the Camaro. The top car always had to be backed in to clear the door opener. I sold the this smaller lift when I had a new garage built with a 12 foot ceiling. But I did get another Revolution 4 poster with ~73 in rise. Rotary, builder of the Revolution lifts, makes great safe products. Tip: In the new garage the power opener is connected directly to the door's torsion tube. Allowing the door to be mounted even closer to the ceiling. http://www.liftmaster.com/consumerweb/page...spx?modelId=834 Link to comment Share on other sites More sharing options...
dukenrock Posted February 18, 2009 Author Report Share Posted February 18, 2009 Nice setup. (Nice cars too!) TyThe ceiling in the picture with the black hoist is 10 feet. That hoist had a ~63" rise. I had the garage door raised so the tracks were tight against the ceiling and could get my Ford Focus under the Camaro. The top car always had to be backed in to clear the door opener. I sold the this smaller lift when I had a new garage built with a 12 foot ceiling. But I did get another Revolution 4 poster with ~73 in rise. Rotary, builder of the Revolution lifts, makes great safe products. Tip: In the new garage the power opener is connected directly to the door's torsion tube. Allowing the door to be mounted even closer to the ceiling. http://www.liftmaster.com/consumerweb/page...spx?modelId=834 Link to comment Share on other sites More sharing options...
BlackVert Posted February 18, 2009 Report Share Posted February 18, 2009 I can't really tell from the pictures- are these units good for working on the cars from the underside, or are they really meant for just storage (i.e. is there good access from below)? Link to comment Share on other sites More sharing options...
kryptonite Posted February 18, 2009 Report Share Posted February 18, 2009 I have the Eagle Equipment 4 post storage lift. (see link) I have had mine for about 3 years. http://www.eagleequip.com/page/EE/PROD/LI-SS/MS-7000 It is both a storage lift as well as a service lift. IF you do not bolt it down, you can actually move your car on the lift via casters. It is recommended that where-ever you install a lift, that there is extra concrete in the pad where it will sit. Mine is not bolted down. My ceiling is 14ft with the 90 degree roll up doors. With the lift at full height, I can work on a car underneath with little to no hindrance as well as doing work on the car that is on the lift. I have been very satisfied with their product. Link to comment Share on other sites More sharing options...
mywickedshelby Posted February 18, 2009 Report Share Posted February 18, 2009 TyThe ceiling in the picture with the black hoist is 10 feet. That hoist had a ~63" rise. I had the garage door raised so the tracks were tight against the ceiling and could get my Ford Focus under the Camaro. The top car always had to be backed in to clear the door opener. I sold the this smaller lift when I had a new garage built with a 12 foot ceiling. But I did get another Revolution 4 poster with ~73 in rise. Rotary, builder of the Revolution lifts, makes great safe products. Tip: In the new garage the power opener is connected directly to the door's torsion tube. Allowing the door to be mounted even closer to the ceiling. http://www.liftmaster.com/consumerweb/page...spx?modelId=834 beautiful garage and collection.....wow! Link to comment Share on other sites More sharing options...
