Grabber Posted December 3, 2008 Report Share Posted December 3, 2008 Well....It went out today. I suppose it was only a matter of time. Here's the worn out parts for documentation. Warranty did not cover the repair. I had to have a senior Master Tech Come out to the house because she was stranded too. That cost a little extra. He did the job in about one our.....including the test Spin. The unit went back together with no problems. Tana Cleaned her up and did a test Spin....and she's very HAPPY !!! :happy feet: She's as good as new again. The bill was $222.15 and it came with a 3 month Warranty. :huh: :rolleyes: Link to comment Share on other sites More sharing options...
kevhead20 Posted December 3, 2008 Report Share Posted December 3, 2008 :whew: you know where I thought this was headed.. Link to comment Share on other sites More sharing options...
Richard Saute Posted December 3, 2008 Report Share Posted December 3, 2008 Well if you stopped overloading it with cleaning cloths..... Link to comment Share on other sites More sharing options...
RUFDRAFT Posted December 3, 2008 Report Share Posted December 3, 2008 Link to comment Share on other sites More sharing options...
tekheavy Posted December 3, 2008 Report Share Posted December 3, 2008 Washing Machine!!!! Link to comment Share on other sites More sharing options...
SpeedRacer Posted December 3, 2008 Report Share Posted December 3, 2008 You need to go to PA (Photographers Anonymous)! Link to comment Share on other sites More sharing options...
shel-b001 Posted December 3, 2008 Report Share Posted December 3, 2008 Looks like Tana has been over loading the clutch with dirty under garments ,definately voids the warranty. Link to comment Share on other sites More sharing options...
Sudguy4 Posted December 3, 2008 Report Share Posted December 3, 2008 I was hoping for an areal shot of the work being performed...... Link to comment Share on other sites More sharing options...
Grabber Posted December 3, 2008 Author Report Share Posted December 3, 2008 I had a feeling it was the clutch because the spinning was not getting all the water out. One of the engineers at the dealership told me how to do a Clutch Test on our rig. The Test confirmed that the clutch was bad. Here's the Grabber "Clutch Test" 1. Open the door. 2. Press a screw driver against the door latch safety switch to over ride it. 3. Turn on the Spin cycle. 4. Grab the side of the drum with your hand. 5. If you are able to keep the drum from spinning......the clutch is shot. Link to comment Share on other sites More sharing options...
LuckySnake Posted December 3, 2008 Report Share Posted December 3, 2008 You are funny. I hope you don't have the dreaded chatter in the near future. Hope I didn't make a mistake letting the warranty expire on mine recently. Link to comment Share on other sites More sharing options...
Torch40 Posted December 3, 2008 Report Share Posted December 3, 2008 I had a feeling it was the clutch because the spinning was not getting all the water out. One of the engineers at the dealership told me how to do a Clutch Test on our rig. The Test confirmed that the clutch was bad. Here's the Grabber "Clutch Test" 1. Open the door. 2. Press a screw driver against the door latch safety switch to over ride it. 3. Turn on the Spin cycle. 4. Grab the side of the drum with your hand. 5. If you are able to keep the drum from spinning......the clutch is shot. Where's the TSB? Link to comment Share on other sites More sharing options...
DDT Posted December 3, 2008 Report Share Posted December 3, 2008 I had a feeling it was the clutch because the spinning was not getting all the water out. One of the engineers at the dealership told me how to do a Clutch Test on our rig. The Test confirmed that the clutch was bad. Here's the Grabber "Clutch Test" 1. Open the door. 2. Press a screw driver against the door latch safety switch to over ride it. 3. Turn on the Spin cycle. 4. Grab the side of the drum with your hand. 5. If you are able to keep the drum from spinning......the clutch is shot. Did you make sure they replaced it with a "RACING CLUTCH"????????????? Or at least a "HIGH PERFORMANCE CLUTCH"??????????? Link to comment Share on other sites More sharing options...
SpeedRacer Posted December 3, 2008 Report Share Posted December 3, 2008 Did you make sure they replaced it with a "RACING CLUTCH"????????????? Or at least a "HIGH PERFORMANCE CLUTCH"??????????? Is it ceramic or organic? Link to comment Share on other sites More sharing options...
David Hawkins Posted December 3, 2008 Report Share Posted December 3, 2008 Did you at least WIN the Race? Were you Racing for Pinks? Link to comment Share on other sites More sharing options...
svtkeith Posted December 3, 2008 Report Share Posted December 3, 2008 Good one got me. Link to comment Share on other sites More sharing options...
68fastback Posted December 3, 2008 Report Share Posted December 3, 2008 I had a feeling it was the clutch because the spinning was not getting all the water out. One of the engineers at the dealership told me how to do a Clutch Test on our rig. The Test confirmed that the clutch was bad. Here's the Grabber "Clutch Test" 1. Open the door. 2. Press a screw driver against the door latch safety switch to over ride it. 3. Turn on the Spin cycle. 4. Grab the side of the drum with your hand. 5. If you are able to keep the drum from spinning......the clutch is shot. 6. If your hand rips off......the clutch is good (call 911 right away) Isn't that clutch from a '68 Fiat 850? Strange to see a clutch like that in a modern washer ...most washers now use variable-speed u-processor controlled variable-speed electric motors instead of a clutch. Rob, when that washer is ready for replacement, consider a front-loader ...much more energy efficient (less electricity and *much* less hot water), cleans better (the falling action of the clothes into the water loosens dirt better than a reciprocating agitator) and no twisted arms/legs on shirts and jeans, etc. Look for one with 1,000/1,100 rpm (or more) spin cycle (removes substantially more H20 than a 850-900 rpm spin which greatly reduces drying energy and time, witht he side-benefit that the dryer won't lag the washer's cycle-time on multiple loads. Also the very lateral nature of the front-loader gets a pulsed assist (from gravity) to spin more water out at the same rpm ...many also use load-sensing to adjust/reballance for a more-effective spin. If you have metered city water, you'll also pay less in both water and sewer taxes with a front loader and they're gentler on septics too. Front-loaders typically pay-back the small cost difference in 1-3 years depending on model and usage and have excellent life expectancies. (from week-4 of my Build/buy a Better Home and Save Money Too course). Ok, I'll leave now ...as you were ...move along, Johnny ...nothing to see here... Link to comment Share on other sites More sharing options...
Grabber Posted December 3, 2008 Author Report Share Posted December 3, 2008 Dan, That Washer was a house gift from my dad when we moved into our home in Sept 2002. So that Sears Kenmoore is 6 years old. Tana does want a new side loader and that will be our next one. Maybe in a couple years we will give this one to our kid's if they are in need and we will pick up a new one....but now I need to get some miles on this new rebuilt one. I found out that this washer is made by Whirlpool for Sears Kenmoore. It's not a bad unit the guy told us. Link to comment Share on other sites More sharing options...
sprint200 Posted December 3, 2008 Report Share Posted December 3, 2008 This can't be coincidence! We had ours replaced last month. It's a 7 year old Kenmore..................... I smell a RECALL!!!!!!!!!!!!! Or at least a Class Action Lawsuit!!!!!!!!!!!!!!!1 Link to comment Share on other sites More sharing options...
Grabber Posted December 3, 2008 Author Report Share Posted December 3, 2008 This can't be coincidence! We had ours replaced last month. It's a 7 year old Kenmore..................... I smell a RECALL!!!!!!!!!!!!! Or at least a Class Action Lawsuit!!!!!!!!!!!!!!!1 Link to comment Share on other sites More sharing options...
68fastback Posted December 3, 2008 Report Share Posted December 3, 2008 This can't be coincidence! We had ours replaced last month. It's a 7 year old Kenmore..................... I smell a RECALL!!!!!!!!!!!!! Or at least a Class Action Lawsuit!!!!!!!!!!!!!!!1 Yeah, I think it's called planned lifecycle. Sears seems to spec/label serviceable products that get high functional ratings in Consumer Reports but then they often do have latent defects such that they mysteriously require replacement parts at some predictable/regular interval such that you wish they would just fall apart so you can justify getting rid of them. It's gotten to the point where I just won't buy from Sears for that reason unless I know who makes the product and its model -specific cross-ref so I can find out if it's really good or not (often you find most every part is the same except for a few Sears-unique parts). Even then I hesitate since a Whirlpool or Frigidaire will just send you a replacement part and/or pay to have a local/approved company install it too, whereas often you have to bring your Sears product to an authorized Sears repair facility in another city (not the store) to get it done for free under warranty ...or they won't pay the labor portion or some such loophole. I've just been burned too many times with Sears and Craftsman products to ever buy from them again. Maybe they'll go bankrupt ...again! Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted December 3, 2008 Report Share Posted December 3, 2008 Good thing I new he was in your driveway before I read this thread or I would have ya Link to comment Share on other sites More sharing options...
68fastback Posted December 3, 2008 Report Share Posted December 3, 2008 Dan, That Washer was a house gift from my dad when we moved into our home in Sept 2002. So that Sears Kenmoore is 6 years old. Tana does want a new side loader and that will be our next one. Maybe in a couple years we will give this one to our kid's if they are in need and we will pick up a new one....but now I need to get some miles on this new rebuilt one. I found out that this washer is made by Whirlpool for Sears Kenmoore. It's not a bad unit the guy told us. Hope it holds up for you, Rob ...often the replacement part is what should have been put in to begin with or it will go again in similar time. At least there's no flywheel warpage! Link to comment Share on other sites More sharing options...
RUFDRAFT Posted December 3, 2008 Report Share Posted December 3, 2008 :goodnight: Link to comment Share on other sites More sharing options...
Grabber Posted December 3, 2008 Author Report Share Posted December 3, 2008 Rodney, I'm going to do a recall letter and I need your support ! So shut up. Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted December 3, 2008 Report Share Posted December 3, 2008 Rodney, I'm going to do a recall letter and I need your support ! So shut up. Link to comment Share on other sites More sharing options...
DutchGT500 Posted December 3, 2008 Report Share Posted December 3, 2008 We just bought a new washing machine too. Our 13 yr old Bosch gave way. We bought a new Bosch WAE 32360. Man, that thing is quiet. Even at 1600 RPM max and that saves you drying time in the dryer we noticed. Every time about 20 minutes. We look forward to a cheaper electric bill. Next mod are rookie stripes. Link to comment Share on other sites More sharing options...
Grabber Posted December 3, 2008 Author Report Share Posted December 3, 2008 I have bad news to report. Tana was getting caught up on the wash last night....and The washer has failed. The clutch seems to not engage the spin cycle again and the cloths just stay soggy wet. You can hear something spinning inside.....but the drum is not turning. $222.15 not well spent. I should of taken it to the dump and bought a new one. Grabber trying to save a buck-----------> Link to comment Share on other sites More sharing options...
DutchGT500 Posted December 3, 2008 Report Share Posted December 3, 2008 Chatter or warped flywheel? Link to comment Share on other sites More sharing options...
sprint200 Posted December 3, 2008 Report Share Posted December 3, 2008 Link to comment Share on other sites More sharing options...
Grabber Posted December 3, 2008 Author Report Share Posted December 3, 2008 Chatter or warped flywheel? I actually think the input shaft is not engaging or the CSC bearing is not doing it's job. I need to call the dealer and tell them that the repair was shotty. Link to comment Share on other sites More sharing options...
