STLShelby Posted November 8, 2007 Report Share Posted November 8, 2007 My wife's 06 GT is sporadic and only does it once in a while. It hasn't been enough of a problem yet to worry about. My Shelby is real bad. I have problems every time i try to put gas in it. I moved to 3 different pumps today and couldn't get it to take, kept clicking off. I talked my Ford dealer, and they said Ford tech told them to try lowering the bracket with a spacer that holds the fill tube which helps, and to tell people to fill on the slowest setting. I can't even get to the slowest fill setting without it clicking off. They said there's no official fix from Ford since the 06 & 07's are supposed have the revised gas tank, although it's still a problem. Guess i'll have them try the back yard fix and see if that helps.They said some are worse than others, guess i got one of the bad ones. Link to comment Share on other sites More sharing options...
stump_breaker Posted November 8, 2007 Report Share Posted November 8, 2007 My wife's 06 GT is sporadic and only does it once in a while. It hasn't been enough of a problem yet to worry about. My Shelby is real bad. I have problems every time i try to put gas in it. I moved to 3 different pumps today and couldn't get it to take, kept clicking off. I talked my Ford dealer, and they said Ford tech told them to try lowering the bracket with a spacer that holds the fill tube which helps, and to tell people to fill on the slowest setting. I can't even get to the slowest fill setting without it clicking off. They said there's no official fix from Ford since the 06 & 07's are supposed have the revised gas tank, although it's still a problem. Guess i'll have them try the back yard fix and see if that helps.They said some are worse than others, guess i got one of the bad ones. I have had this problem on other vehicles and I've always found the solution is to not stick the nozzle in but about about 1/4 way instead of all the way. Link to comment Share on other sites More sharing options...
fatboy_merged Posted November 8, 2007 Report Share Posted November 8, 2007 i ran across this site....... http://ratstangrestoration.com/05_mustang_tank.htm Link to comment Share on other sites More sharing options...
Webba Posted November 8, 2007 Report Share Posted November 8, 2007 There was a TSB on this issue on these when they came out in 05....mustang GT's I mean...and I recall seeing some here and there on 06's. Once in a while I have issues with mine. If it were me Id tell the service guy to look up the TSB and have him fix it. Why would someone tell a customer to fix his own warrantied car that has a known issue?? meatheads I tell ya! Link to comment Share on other sites More sharing options...
DreamRide Posted November 8, 2007 Report Share Posted November 8, 2007 I have had the problem twice since last feb. when i purchased my Shelby. I noticed that the last time it happened and the pump clicked off, i could hear from the tank inlet a sound like the fuel was slowly draing down. So if i waited a few seconds when the sound stopped and then proceded it was ok. I think it has something to do with the tank set up having a cross over and maybe air pocket occuring? But, like i said , it has happened 2 times since last Feb. Other then that , no problem.......... Link to comment Share on other sites More sharing options...
STLShelby Posted November 8, 2007 Author Report Share Posted November 8, 2007 I have had this problem on other vehicles and I've always found the solution is to not stick the nozzle in but about about 1/4 way instead of all the way. I tried that to stump, thanks. There was a TSB on this issue on these when they came out in 05....mustang GT's I mean...and I recall seeing some here and there on 06's. Once in a while I have issues with mine. If it were me Id tell the service guy to look up the TSB and have him fix it. Why would someone tell a customer to fix his own warrantied car that has a known issue?? meatheads I tell ya! You misunderstood Webba. Ford Tech told the dealer to lower the fill tube with a spacer not the customer, and then tell the customer to use the slowest setting. They said they have done that on a lot of 06 &07's and it helps somewhat. On the 05 + the tech at the dealer said this has been their biggest continual problem. I have had the problem twice since last feb. when i purchased my Shelby. I noticed that the last time it happened and the pump clicked off, i could hear from the tank inlet a sound like the fuel was slowly draing down. So if i waited a few seconds when the sound stopped and then proceded it was ok. I think it has something to do with the tank set up having a cross over and maybe air pocket occuring? But, like i said , it has happened 2 times since last Feb. Other then that , no problem.......... Yep Ed, he told me due to the style and different location on the 05+ fuel gets trapped in the filler tube and and shuts the pump off. I also tried waiting a few seconds and it still wouldn't take fuel. I couldn't get it to take fuel from the start. I think when it gets down to 3/4 of a tank, i will fill it up so i don't have to fight it for a whole tank. i ran across this site....... http://ratstangrestoration.com/05_mustang_tank.htm Thanks fatboy, maybe i will email that to my dealer. :D Link to comment Share on other sites More sharing options...
STLShelby Posted November 8, 2007 Author Report Share Posted November 8, 2007 This is the latest tsb on it. http://www.stangnet.com/images/stories/doc...SBs/06-3-13.pdf Link to comment Share on other sites More sharing options...
07SHELBY GT Posted November 9, 2007 Report Share Posted November 9, 2007 i ran across this site....... http://ratstangrestoration.com/05_mustang_tank.htm I saw that same fix somewhere and was going to mention it but you beat me too it! Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted November 10, 2007 Report Share Posted November 10, 2007 My wife's 06 GT is sporadic and only does it once in a while. It hasn't been enough of a problem yet to worry about. My Shelby is real bad. I have problems every time i try to put gas in it. I moved to 3 different pumps today and couldn't get it to take, kept clicking off. I talked my Ford dealer, and they said Ford tech told them to try lowering the bracket with a spacer that holds the fill tube which helps, and to tell people to fill on the slowest setting. I can't even get to the slowest fill setting without it clicking off. They said there's no official fix from Ford since the 06 & 07's are supposed have the revised gas tank, although it's still a problem. Guess i'll have them try the back yard fix and see if that helps.They said some are worse than others, guess i got one of the bad ones. I didn't have the problem until I read your post. <_< Now, I have to fiddle with it to get it to work. Thanks Alot!!! Link to comment Share on other sites More sharing options...
LuLu Posted November 10, 2007 Report Share Posted November 10, 2007 Haven't had this problem myself...Yet, anyway. But, thanks for the heads up. Link to comment Share on other sites More sharing options...
STLShelby Posted November 10, 2007 Author Report Share Posted November 10, 2007 I didn't have the problem until I read your post. <_< Now, I have to fiddle with it to get it to work. Thanks Alot!!! :D Glad i could be of some help! Link to comment Share on other sites More sharing options...
fatboy_merged Posted November 10, 2007 Report Share Posted November 10, 2007 maybe they should have made the gas cap emblem on the back functional :rolleyes: sorry just had to put that in hehhehe :P luckily i have no problems with my tank...i just slam it in and it chugs it down ~knocks on wood~ Link to comment Share on other sites More sharing options...
mccoystudio_merged Posted November 11, 2007 Report Share Posted November 11, 2007 No problems at all. Except price of gas :D . I have another vehicle where this is a problem, so I put the filler in upside down and no problem, don't ask me why but this works on a scout. Link to comment Share on other sites More sharing options...
