STLShelby Posted November 1, 2007 Report Share Posted November 1, 2007 After the wheels were changed it threw the TPMS fault display after about 20 miles of driving. Dealer went thru the procedure, cleared and reprogrammed. Drove it 22 miles today and it's back. There's a lot of 07 Mustangs out there that have had wheel changes, so whats my dealer missing? Link to comment Share on other sites More sharing options...
Paleoc Posted November 1, 2007 Report Share Posted November 1, 2007 After the wheels were changed it threw the TPMS fault display after about 20 miles of driving. Dealer went thru the procedure, cleared and reprogrammed. Drove it 22 miles today and it's back. There's a lot of 07 Mustangs out there that have had wheel changes, so whats my dealer missing? I took my car to a dealer and asked them about the TPMS and turning it off. They told me that it was required by federal law and they can't touch it. I took it to a couple of tuners (had it dyno tuned) and they couldn't find any computer settings for it. Unless you cheat it (and there a few complicated methods to do so), you are stuck with pressing the reset button on the dash board. Even if you have the same size wheels (I don't as I now have 20" razors) the tires may not have the same pressure as stock. My new tires require 40 lbs of pressure so even if I had wheels that the sensors would fit, the TPMS would be telling me that the inflation was wrong. TPMS is perfect for a Prius but it can't handle aftermarket tires and aftermarket wheels. Link to comment Share on other sites More sharing options...
RogerS Posted November 1, 2007 Report Share Posted November 1, 2007 After the wheels were changed it threw the TPMS fault display after about 20 miles of driving. Dealer went thru the procedure, cleared and reprogrammed. Drove it 22 miles today and it's back. There's a lot of 07 Mustangs out there that have had wheel changes, so whats my dealer missing? You say the wheels were changed. Did they place new sensors and bands on the new wheels? Link to comment Share on other sites More sharing options...
MattInDetroit Posted November 2, 2007 Report Share Posted November 2, 2007 The sensors MUST be the right ones for the size wheel. They also as Per the FORD Instructions ,the Cradle is not supposed to be Reused which comes with the strap kit. So if you Were Changing from one style to another with 18"s you would need a Strap kit. The OE Straps Which Come on the Car are Not Reusable. However the Service Replacement Straps are a Worm Gear and Can Be Reused. TPMS Overview http://home.ptd.net/~safari/mustang/fsm/TPMS.pdf Sensor Training http://home.ptd.net/~safari/mustang/fsm/Training.pdf Sensor Details http://home.ptd.net/~safari/mustang/fsm/Sensor.pdf Strap and Cradle Details http://home.ptd.net/~safari/mustang/fsm/Strap.pdf Link to comment Share on other sites More sharing options...
SWEDESHELBY1 Posted November 2, 2007 Report Share Posted November 2, 2007 I purchased th 20" Razors and tires, had them installed @ Americas Tire Center and they took care of the sensors perfectly. I have never had an issue. Link to comment Share on other sites More sharing options...
AFBLUE Posted November 2, 2007 Report Share Posted November 2, 2007 Where did you purchase your razors swede? Link to comment Share on other sites More sharing options...
MattInDetroit Posted November 2, 2007 Report Share Posted November 2, 2007 I purchased th 20" Razors and tires, had them installed @ Americas Tire Center and they took care of the sensors perfectly. I have never had an issue. Sounds like they know what they are doing. If you throw 20" wheels on and reuse, or order new sensors, using the PN from the old ones (for 18") they will fail. Link to comment Share on other sites More sharing options...
STLShelby Posted November 2, 2007 Author Report Share Posted November 2, 2007 My wheels and tires were swapped out for factory polished ones on an 08 they had on the lot, as part of the deal per my request. Tires and sensors were left intact on the wheels they came on. Nothing was broke down and changed. They just swapped wheel/tire combo, so i ended up with different sensors. The dealer and myself thought the reprogram would take care of it. Apparently something is being overlooked. The orange warning light flashes until you move the car then it quits. The "tire pressure monitor fault" displays instead of the odometer all the time. Link to comment Share on other sites More sharing options...
STLShelby Posted November 2, 2007 Author Report Share Posted November 2, 2007 The sensors MUST be the right ones for the size wheel. They also as Per the FORD Instructions ,the Cradle is not supposed to be Reused which comes with the strap kit. So if you Were Changing from one style to another with 18"s you would need a Strap kit. The OE Straps Which Come on the Car are Not Reusable. However the Service Replacement Straps are a Worm Gear and Can Be Reused. TPMS Overview http://home.ptd.net/~safari/mustang/fsm/TPMS.pdf Sensor Training http://home.ptd.net/~safari/mustang/fsm/Training.pdf Sensor Details http://home.ptd.net/~safari/mustang/fsm/Sensor.pdf Strap and Cradle Details http://home.ptd.net/~safari/mustang/fsm/Strap.pdf Thanks for the info Matt. I didn't have time to go thru it before my last post. The wife was hollering for me to get to the dinner table. :D Link to comment Share on other sites More sharing options...
MattInDetroit Posted November 2, 2007 Report Share Posted November 2, 2007 Thanks for the info Matt. I didn't have time to go thru it before my last post. The wife was hollering for me to get to the dinner table. :D Hey, hope it helps! Based upon posts all over about the TPS it = Voodoo! :unsure: Link to comment Share on other sites More sharing options...
ShelbyPilot Posted November 2, 2007 Report Share Posted November 2, 2007 I have 20" wheels with the stock sensors cut off from the 18" wheels and rebanded. The only time my light has gone off was when I picked up a nail and was getting a flat. Link to comment Share on other sites More sharing options...
MattInDetroit Posted November 2, 2007 Report Share Posted November 2, 2007 I have 20" wheels with the stock sensors cut off from the 18" wheels and rebanded. The only time my light has gone off was when I picked up a nail and was getting a flat. See! Voodoo! :unsure: Link to comment Share on other sites More sharing options...
