ShelbyCobra826 Posted September 8, 2007 Report Share Posted September 8, 2007 Now that I have your attention... I was up under #4990 this afternoon trying to figure out how to get my 3.5 ton jack under the car (yes, this is another topic entirely...), and I noticed that the passenger's side pipe is at least 1" lower than the driver's side pipe. It starts dropping down just behind the X crossover and is at its lowest point just before it jumps over the rear axle. Is everyone's SGT like this, or just mine? This thing has ground clearance issues enough without taking away a precious inch down there. Anyway, there's no banging or clanking or rattling, but I'd like to get it fixed if it isn't supposed to be like this. Thanks. Link to comment Share on other sites More sharing options...
stump_breaker Posted September 8, 2007 Report Share Posted September 8, 2007 Now that I have your attention... I was up under #4990 this afternoon trying to figure out how to get my 3.5 ton jack under the car (yes, this is another topic entirely...), and I noticed that the passenger's side pipe is at least 1" lower than the driver's side pipe. It starts dropping down just behind the X crossover and is at its lowest point just before it jumps over the rear axle. Is everyone's SGT like this, or just mine? This thing has ground clearance issues enough without taking away a precious inch down there. Anyway, there's no banging or clanking or rattling, but I'd like to get it fixed if it isn't supposed to be like this. Thanks. Try loosening the clamp and turning the muffler. This might help. Link to comment Share on other sites More sharing options...
ilmor Posted September 8, 2007 Report Share Posted September 8, 2007 As for getting the jack underneath, I just drive up onto 1.5" thick boards to get the clearance needed.... Link to comment Share on other sites More sharing options...
SGT2666 Posted September 9, 2007 Report Share Posted September 9, 2007 As for getting the jack underneath, I just drive up onto 1.5" thick boards to get the clearance needed.... Ditto... Link to comment Share on other sites More sharing options...
dmagner1 Posted September 9, 2007 Report Share Posted September 9, 2007 Ditto... i think thats kind of personal Link to comment Share on other sites More sharing options...
ShelbyCobra826 Posted September 10, 2007 Author Report Share Posted September 10, 2007 As for getting the jack underneath, I just drive up onto 1.5" thick boards to get the clearance needed.... Did you put the jack under the edge of the frame where it is notched to accept the factory (okay, usually factory) jack, or did you put it under the front diagonal subframe between this point and the K-member? So I guess that I am the only one with one pipe this much lower than the other one? Link to comment Share on other sites More sharing options...
stump_breaker Posted September 10, 2007 Report Share Posted September 10, 2007 Did you put the jack under the edge of the frame where it is notched to accept the factory (okay, usually factory) jack, or did you put it under the front diagonal subframe between this point and the K-member? So I guess that I am the only one with one pipe this much lower than the other one? I place it on the jack point of the car BUT I place a 2x4 between the jack and car first to equalize the pressure. Link to comment Share on other sites More sharing options...
WIFFLEGT Posted September 11, 2007 Report Share Posted September 11, 2007 Now that I have your attention... I was up under #4990 this afternoon trying to figure out how to get my 3.5 ton jack under the car (yes, this is another topic entirely...), and I noticed that the passenger's side pipe is at least 1" lower than the driver's side pipe. It starts dropping down just behind the X crossover and is at its lowest point just before it jumps over the rear axle. Is everyone's SGT like this, or just mine? This thing has ground clearance issues enough without taking away a precious inch down there. Anyway, there's no banging or clanking or rattling, but I'd like to get it fixed if it isn't supposed to be like this. Thanks. Yep, me too. Mine is on the Drivers side and probably about 1/2 more than the passenger side. Will need to take care of that as well. Link to comment Share on other sites More sharing options...
crzykc Posted September 11, 2007 Report Share Posted September 11, 2007 I noticed it too...not sure if it's how the pipes are bent or if something does need rotated. Haven't drug it yet..LOL! :rolleyes: Link to comment Share on other sites More sharing options...
frankieboo69 Posted September 11, 2007 Report Share Posted September 11, 2007 All of them ,like everything, one hangs lower than the other!!!!!!!!!!!!!!!!!!!!!!!! B) Link to comment Share on other sites More sharing options...
crzykc Posted September 11, 2007 Report Share Posted September 11, 2007 LOL! Maybe so! Link to comment Share on other sites More sharing options...
ShelbyCobra826 Posted September 13, 2007 Author Report Share Posted September 13, 2007 Yep, me too. Mine is on the Drivers side and probably about 1/2 more than the passenger side. Will need to take care of that as well. The dealership just called and informed me that one of the clamps appeared to have never been tightened, and when tightened brought the passenger's side pipe up even with the driver's side pipe. They said that the mechanic test drove it (I bet that he did...) and reported no banging or other problems. EDIT: After picking up the car, I can say that it is now right. Very pleased. At first they gave me grief about fixing it, but I pointed out to them that the two SGTs in their showroom had perfectly level pipes (I checked when I dropped the car off last night). Funny, but one of those cars was the one that I originally ordered back during the holidays last year and arrived in April with a non-negotiable $7K ADM sticker...which is now gone. Also, I had them check my rear side marker light while they had the car as the passenger's side unit was not working. They fixed this and said that one of the wires coming out of the harness was being pinched between the bumper cover and the body of the car. Does SAI have to remove the rear bumper cover to stripe it? Link to comment Share on other sites More sharing options...
